casainho said:updated configuration menus buttons (thanks to Jeroen Brosens j0bro)
Thanks for the update!
Does this configuration require a new wiki? I don't understand what was changed..
Let me add my impression regarding the cruise function present on beta5.
I set up the function that keeps the actual speed, it works but I noticed that the motor continues to switch on and off trying to mantain that speed.
Let me explain myself better: I understand that the motor gives power to reach the target speed (e.g. 160W), then after this speed is reached or maybe overcame the motor stops (down to 0W) not to increase the speed, then it switches on again because the speed drops.. off.. on.. off.. and so on.
Take it as a nice to have feature, not absolutely a must, but maybe it is beneficial to change the logic by iteratively search a wattage that allows to keep the target speed +/- 5%, instead of going from zero to maximum many times.
If you consider the suggestion applicable, I will open an issue on GitHub to keep it in mind for the future.
