I have been a long time lurker, and almost everything I know about electric bikes, I have learned here.
That being said, I am in the planning stage, nearing the start of sourcing components stage of an open source velomobile that I would like to build, then release the plans for under a general public license.
Because It is going to be open source, I would like to include as many off the shelf components as possible, and have no machined parts be used, if possible. I would also like to use suspension, so the options for a front end, with minimal fabrication are rather limited.
I considered a lot of different options, but I am most strongly considering using a long travel golf cart lift kit as the front end.
I know this might sound ridiculous to some. Basically, I want this to be a human-powered electric hybrid vehicle. I am planning on using a 72V system, a High power hub motor on a moped rim in the rear, with DOT tire, and as narrow as possible golf cartwheels on the front, or a small four bolt car rim and tires If I can find some to fit. The details are well thought out, and I will forgo them for now, but feel free to ask if you are interested. In my mind, these kits are designed to take abuse and designed to hold much more weight than my application, but I still wonder if this will be sturdy enough, or If I should fabricate my own custom suspension, or borrow a design from a dune buggy or go-kart.
