I have most of the parts hear or on there way. Not as much battery space as I would like. I ordered th 3000w/5000w- Peak power rear hub motor kit with a 29 inch wheel. I had to modify the swing arm to fit. It came out nice but the bike will sit high. I had to special order the front wheel, should be hear in a few days. It required a 20mm axle and needed to be heavy duty for the weight. The front fork is a DNM USD-8 downhill inverted. I haven't ordered the Battery yet. A bit confused there. I still have a Race Face Chester Crank Arms coming.
