casainho said:
buba said:
Casainho and others, should there be an error code when user has the assist level or assist multiplier set to anything other than zero and motor power limit set to zero and also tries to ride the bike. Maybe only displayed for a short duration such as 5-10 seconds?
I think the default value does not help, if it was something like 1000 watts, then this would not be an issue.
Also, when the power limit is hit, there is not indication to user and that should no be an error message. Maybe short blink power field like 20% of time off, like 200 ms off and 800 ms on.
Okay good, in short, no error code necessary. If it becomes a problem later on we can set the default power to 250 watts as suggested by btslo and/or write a function that flashes the power reading if at power limit as you suggested.
dameri said:
buba said:
May I ask if a couple of users can take a look at the Advanced Technical Data under sub menu 2, ADC Pedal Torque Sensor, and report what the resting value is...
Thank you all!
I will do that tomorrow. Now battery and man is loading from 54 kms ride. Beta 7 is working fine.
I think I will also get used to new logic.
That sounds great! Hope you charge up nicely!
Thank you!
thineight said:
Hello Buba, here my results.
Pedals horizontal, no force applied - menu 9 - submenu 2 : reading --> 48/49
Zero assist and easy ride with hard gear on flat garage: reading --> 70-71
Zero assist with soft gear on garage ramp: reading --> 78
Hope this helps.
I really appreciate that you took the time to do the tests!
Thanks, thineight!
thineight said:
Buba, I guess we spoke about this some time ago, but I do not remember the conclusion.
Regarding the walk assist, it is beneficial to have a sort of "lock" of the walk assist in order not to require the DOWN button to be pushed constantly. In fact it is hard not to slip off with the finger on a steep hill.. and the walk assistance will stop.
In fact when the "lock" is active the walk assist is started just holding the DOWN button and after you can release it, the bike will keep on walking beside you. Simple press on UP or DOWN button (or brake if magnetic sensors are installed) will stop the walk assistance.
This logic is applied also on marcoq fork for the stock display and it works very well.
Do you think we have chance to have it on the LCD3 display or the memory is over?
I understand completely.
Let me list some improvements planned for the Walk Assist function long ago:
* Acceleration of power. Walk Assist in its current state should always be activated when already walking as it has a very high acceleration. But with a "soft start" function it will be really smooth even from a complete stand still.
* Closed feedback loop controlling the motor rotation. This feedback loop would ensure more consistent operation and would ensure same speed regardless of state of charge. The wheel speed could also be used but it is not advisable due to the low resolution and inertia.
* Power limit safety. This limit would cut or lower the power in certain situations where it is necessary. Ensuring user safety and protection of the drive train.
* Locked Walk Assist. This would be the aforementioned functionality of locked Walk Assist with no button press. This would operate until user presses a button, the brakes or if there are abnormal levels of resistance, or lack thereof, in the system.
* No Load Cuttoff. If the user falls or the wheels are in the air the system would deactivate.
I have no problems with walk assist as it is now because I am familiar with the power levels I set. It is slower and smoother than the original firmware implementation. But could be even better with the mentioned improvements.
We can definitely look at this after the stable 0.19.0 and then make the Walk Assist even better for the next version. Then we could also implement the "no-button" Walk Assist if it ends up being really safe!
I strongly disagree with this because walk assist as it is now is very dangerous. I even didn't told to my son when he had to push his bicycle hardly on mountain because it is dangerous: very fast and strong start and possibly high speed. You can't know the speed until you start so it is always a guess.
Sad to hear you feel that it is that dangerous. The default values on the lower assist levels should be really, really, slow. And all other values can be lowered and adjusted to fit any bike and weight. But I agree that there are improvements to be made. Such as those I mentioned above.
