Could it be that low? I mean, surely there is more torque at the end of the motor shaft than 2.5 Nm...Miles said:Nope. But it looks like they've used the smallest of the CSK series one-way bearings - nominal rating 2.5 Nm.
oofnik said:Could it be that low? I mean, surely there is more torque at the end of the motor shaft than 2.5 Nm...Miles said:Nope. But it looks like they've used the smallest of the CSK series one-way bearings - nominal rating 2.5 Nm.
Rohloff Speedhub
Max input torque
100 Nm
Miles said:Max. continuous torque from the AF 3210 motor is 2.65 Nm. The nominal rating of these one-ways is 50% of peak capacity, I think - so this should cope with the output torque from the motor shaft of the 3210.
Miles said:Hi Mitch,
Power = Torque x Speed.
So, if the speed of your 3210 motor is reduced by 25:1 in the drive, the torque is multiplied by 25.
Peak output (1 minute) from the 3210 is 500 in/ozs which is 3.53 Nm.
3.53 Nm x 25 = 88.25 Nm (If the drive was 100% efficient..)
So, at every stage in a transmission, torque is pretty much inversely proportional to speed, so that power is constant (minus drive losses).
Is that clear?
MitchJi said:But I think oofnik asked the wrong question:
I think he was planning to mount the one-way on the output of his 4.5:1 first stage which would require:
4.5 x 3.53 = 15.885 so the one-way is a lot less than his requirements.
oofnik said:So, update time.
I made a sprocket adapter to mount a 130mm chainring to a IS 6-bolt brake disc hub using a manual lathe and drill press. Lots of work to get everything centered.
I think it turned out pretty nice. Only problem is those socket head cap screws don't clear the frame by a few thousandths so I'll need to go pick up some button head screws to replace them tomorrow.
That chainring came from eBay for $1.00. The aluminum came from the scrap bin at a local machine shop. Yes, the sprocket's worn, but where else am I going to find a 56T chainring? Especially for that price?
Can you put the mounts a little lower on the seat-tube or make mounts that are offset to place the drive in a slightly different location? Is there more room to go lower if the drive is located further from the seat-tube?oofnik said:I have discovered that the chain line is just barely interfering with my rear V-brake mounts. I don't have a chain to check with so I used a power cord lying around. I just need a few millimeters more. So I may have to mount an idler to pull the chain in a little bit at the top.
Would you explain the problem a little more completely? I am tentatively planning on a 20t to 90t configuration. Do you think that will work?oofnik said:I also went down to an 80 tooth belt rather than the 81 tooth I got from Matt because I couldn't tension it quite all the way.
MitchJi said:Hi,
MitchJi said:Would you explain the problem a little more completely? I am tentatively planning on a 20t to 90t configuration. Do you think that will work?
That may give you a general idea of how much tension you want on your belt.Pretension prevents belt slack-side sagging and ensures proper tooth meshing. In most cases, timing belts perform best when the magnitude of slackside tension is about 10 to 30% that of the effective tension.
MitchJi said:Hi,
oofnik said:I may be able to do that. I don't have a way of making anything up here like I do at home.. no workshop, no drill press, no saws... But I did consider doing that. It's not a bad idea. Only problem is that the distance between the drive and seat post is proportional to the moment (torque) about the clamps, and I would hate for those clamps to slip. But like I said, I only need a few mm, so it might be okay.
1: 2.948 7: 2.894
2: 2.987 8: 3.095
3: 3.038 9: 3.004
4: 2.848 10: 3.090
5: 3.138 11: 3.062
6: 2.741 12: 3.020
The Flair Leg BRACK-IT design provides a secure fit that locks each leg in
place on round poles or mast arms of almost every diameter.
