It is highly unlikely that there is something wrong with offest, simply for the reason because the belt is touching the outside guide flanges on BOTH the small and large pulley.Joachim said:there is only one thing left that can be wrong...the offset from the pulleys is not good.
Dont like to set the compleet wheel/tyres to one side because the pulleys doenst line uop propper when the wheel is 100% straight in the swingarm, when i let the bike roll with loose hands the bike must strace straight! i am not assemble my wheel crooked because the pulleys doenst line up correct, this is crazzy thing to do
If the pulleys line up (100% parallel), then your wheel should be also parallel. If it looks crooked because the tire doesn't stay in middle of the swingarm then probably something is wrong with the wheel itself (rim not laced centered), or something else with the frame or swingarm which would be highly doubtful.
