wturber
I guess the more parts that are moving in a system, the greater the more places for fingers to get mangled.
On a rear hub motor I have found PAS less dangerous than my twist throttle. Under throttle only I have inadvertently twisted the throttle while not on the bike and it gets out of control fast in that situation. With PAS, it is hard to accidentally enable power
Of course, with any system the safe thing to do is disconnect power when fiddling with gears, chains and such. It's the same thing I do with power tools (circular saws in particular). If you are throwing chains on a mid drive, then maybe something is flexing under load?
