theblindsaint
I'm halfway through a conversion of my bike, finally have all the mechanical issues sorted out and just installed a baserunner+CA3 combo when I'm running into a few problems.
First issue is when I plug in just the 3 motor phase wires to test the motor. No matter which combination for the wires I use, the motor gives a sudden lurch once I apply the and then stops, even when I apply the throttle again. Is it because I'm running without an e-brake? Or is something wrong with my motor?
Second issue is that Using the phaserunner software I cant connect to the baserunner, even though connecting to the CA3 works just fine.
