kWeld - "Next level" DIY battery spot welder
spinningmagnets   100 GW
Re: kWeld - "Next level" DIY battery spot welder
Post by spinningmagnets » Jul 23 2019 4:50pm
The kWeld works quite well on 0.20mm nickel. How many amps do you intend to pull from each cell?
eikido   10 W
Post by eikido » Jul 23 2019 5:04pm
I'm quiet sure i will be fine with 0.15x7-8mm but if 0.2mm is easy for the kweld, why not go with 0.2mm directly?
I'd probably never hit more than 10amps per cell. I guess i will be somewhere 3-5 amps.
And you never know, all of a sudden I start building batteries for power tools which requires a lot of current.
:D
tatus1969   1 kW
Post by tatus1969 » Jul 24 2019 3:08am
eikido wrote:
Jul 23 2019 5:04pm
One good reason: less thick nickel means less required energy, which means less thermal stress for the battery.
Resistance is futile - We Are The Watt.
eikido   10 W
Post by eikido » Aug 06 2019 8:17am
I have about 50cm 4AWG pure copper cable on the input.
Should i shorten them because of inductance? What is the downside of worse inductance? I'd rather not because of the size of the car battery :)
What a wonderful piece of welder :)
tatus1969   1 kW
Post by tatus1969 » Aug 07 2019 3:49am
eikido wrote:
Aug 06 2019 8:17am
Thanks 8) I am explaining the theory behind wire inductance in detail in the kWeld operating manual, please have a look in that. In short words, it is inductance (to be precise: the magnetically stored energy in it) that puts stress on the welder's power switch, not current. Longer cables are allowed, but you need to configure kWeld accordingly for continued reliable operation.
flippy   1 MW
Post by flippy » Aug 07 2019 2:51pm
for the average person you can just do this: induction = magic.
probably true for quite a lot of electrical enginerds as well.
the shorter the cable the better the magic can flow.
Lithium beats liquid dinosaurs.
tomjasz   10 GW
10 GW
Post by tomjasz » Aug 07 2019 7:46pm
rescinded offer
Headrc   100 W
Post by Headrc » Aug 07 2019 8:40pm
If you are offering the Kweld for a donation of $50 to a foodbank I will take it ....
flippy   1 MW
Post by flippy » Aug 08 2019 3:23am
How does the performance lack exactly? Just curious as i have the latest version. Coming from a malectrics welder is certainly more rubust. But also triple the price ifyou get the kcap upgrade.
Stuff like overheating is solved with a simple fan, just like most welders need, especially the transofrmer based ones need massive airflow. I modded the case to hold 2 small noctua fans so its silent and gets positive airflow across the power components.
eikido   10 W
Post by eikido » Aug 08 2019 8:57am
tatus1969 wrote:
Aug 07 2019 3:49am
eikido wrote:
Aug 06 2019 8:17am
Super! Found it and read it! So what the cable length parameter does is to limit the current in the whole system. Good thing is the calculations are based on the thickness of the cable and my cables are like super thick so i'm extra protected. :D
Thanks again.
tomjasz   10 GW
10 GW
Post by tomjasz » Aug 08 2019 12:45pm
flippy wrote:
Aug 08 2019 3:23am
How does the performance lack exactly? Just curious as i have the latest version. Coming from a malectrics welder is certainly more robust.
I'm not a power user. From here on I'll only be building 10s4p-6p packs. I have a JP and a JP backup. If i'd have waited I'd have added the latest KWeld. I'm just a nOOb when it comes to soldering and flashing electronics. I hate running Windoze on my MAC so updating is a nuisance.
Tatus has been FANTASTIC. I have no bone to pick with his great work. It's my lack of skill. And at nearly 70, and a mild stroke, I'm not a steady hand.
It just seems to spend more for something I don't need seems, well, silly. AND I have several Vruzend kits.
Headrc wrote:
Aug 07 2019 8:40pm
Got your message. Will dig it out this weekend. Left my PayPal address, and a preferred email address. You can PayPal me Freinds&Family and I provide a receipt for the donation, OR you can provide me a receipt or cancelled check to your local food bank. Shipping would be nominal. I think it's under 13oz and can go First Class with delivery confirmation. Around $4.00
flippy   1 MW
Post by flippy » Aug 09 2019 10:08am
Or better: buy the food and bring it to them.
tomjasz   10 GW
10 GW
Post by tomjasz » Aug 09 2019 11:56pm
flippy wrote:
Aug 09 2019 10:08am
Likelystill availableas I don’t include foot switch and probes. Jeebus fellas here want free lunches...
john61ct   100 GW
Post by john61ct » Aug 10 2019 12:36pm
PM sent
frnandu   1 mW
Post by frnandu » Aug 10 2019 1:50pm
I'm getting "REMOVE SHORT" at start, any idea what may cause this? (the electrodes are not touching)...
Been working fine for few months, and now this....
eee291   100 kW
Post by eee291 » Aug 10 2019 2:17pm
viewtopic.php?f=14&t=89039&p=1417408&hi ... e#p1414802
I had the same issue once, diode melted.
frnandu   1 mW
Post by frnandu » Aug 10 2019 3:22pm
my diode seems fine
flippy   1 MW
Post by flippy » Aug 11 2019 3:16am
desolder the diode ans see if it goes away. but i would just order new diodes anyway.
dont run it without a diode.
frnandu   1 mW
Post by frnandu » Aug 11 2019 4:42am
If I disconnect the fuse (from the electrode side) and connect it again it stops giving "REMOVE SHORT" and it welds without problems.
Any other ideas?
flippy   1 MW
Post by flippy » Aug 11 2019 5:05am
most likely is that the diode is starting to break down. and is starting to leak current.
wihtout looking at the sensing circuit you migt want to wait for a answer from the designer.
tatus1969   1 kW
Post by tatus1969 » Aug 11 2019 6:45am
frnandu wrote:
Aug 11 2019 4:42am
Any other ideas?
Please do not trigger welding pulses without a replacement in place, this diode is protecting the switching MOSFETs from inductive kickback energy that those cannot handle reliably. If you PM me then I can send you a replacement diode, or I can do that repair for you but this would cause a lot of shipping overhead. If you want to source that diode by yourself: https://www.digikey.com/products/en?keywords=F8157CT-ND Older boards have a different (smaller) diode, the one in the link is beefier and can withstand abuse longer.
There are a few common situations that can cause this diode to fail:
- if you feed external voltage into the electrodes, this can happen when welding your battery, and accidentally touch different poles of that.
- if your power wiring around the welder is more than one meter in total (e.g. you are using long wires to the battery), and you haven't dialed in the extra length through the welder's menu. I explain the reason for this in the welder's user manual, it's a bit hard to explain. The keyword is inductive kickback.
frnandu   1 mW
Post by frnandu » Aug 12 2019 2:46pm
tatus1969 wrote:
Aug 11 2019 6:45am
frnandu wrote:
Aug 11 2019 4:42am
Any other ideas?
Thank you Frank for the advice.
It seems to me that I have the bigger and it doesn't look damaged.
Is this "REMOVE SHORT" error cause only possible if this diode is somehow damaged (even if it looks ok)?
If so, can it be easily replaced with an ordinary soldering iron?
I need to order from you new electrodes, so if indeed I should replace this diode for stopping the error, maybe you can send me a replacement together with the electrodes?
tatus1969   1 kW
Post by tatus1969 » Aug 13 2019 4:37am
frnandu wrote:
Aug 12 2019 2:46pm
It is not always easily noticable when these components crack, sometimes the black top only lifts up very slighlty above the large metal tab at the one end. There are other possible reasons for this message, but I now realize that I haven't read your initial post correctly. You say that you had removed and connected the fuse and that it then worked. I somehow had read that you had removed the TVS diode, which is why I gave that warning. This is a completely different situation, and I am thinking about this right now as I haven't had this before... A few questions:
- you actually removed and replaced the fuse while the system was powered from the battery, right?
- are you sure that you have never accidentally touched something on the logic board with one of the electrodes?
- are you sure that you haven't applied external voltage to the electrodes?
- can you once measure the voltage across the electrodes, a) hafter having powering the system, and b) after you have removed+replaced the fuse?
frnandu   1 mW
Post by frnandu » Aug 13 2019 5:04am
tatus1969 wrote:
Aug 13 2019 4:37am
Yes, while having power from the battery I slightly disconnected the electrode side of the fuse and then connected it again, and the error went way.
tatus1969 wrote:
Aug 13 2019 4:37am
Since this is a shared welder between a few people in my city I cannot say 100% that someone did these or not.
tatus1969 wrote:
Aug 13 2019 4:37am
Sure, I will in the evening measure and write back to you.
Thanks for the support.
eee291   100 kW
Post by eee291 » Aug 13 2019 6:37am
In that last pic it looks like someone touched the brass with one of the electrodes. :?
If you get it fixed and still plan on lending it to people then I recommend getting a case for the welder.
