I just want to post a thank you to Casianho and any other developer involved. This is an amazing upgrade to an already great piece of hardware.
I have a TSDZ2 mounted to an Xtracycle Edgerunner and it is nearly perfect now.
The open source firmware with an LCD3 display gives me the flexibility to make the assist so natural it is like an extension of my legs. It is especially good on a cargo bike where you need varying assist and smoothness is more important than pure output.
After reading many pages of tech info and opinions, I decided to go for it. I was satisfied with the stock firmware, but I always like adding a new skill to my set and flashing firmware with an ST Link is right up my alley.
I hope I can save everyone on the fence the effort and say to UPGRADE if you can.
1. High cadence performance is so much better. I can actually get power at my 90rpm cadence.
2. Ramp up is much slower, on default settings. It feels more natural and will hopefully spare my drivetrain for a while.
3. The volt meter is very helpful. Battery bars on stock displays are worthless. I ride big hills so mileage is not the best indicator of battery capacity.
4. Customization of assist is great. I ride with my daughter as a passenger and my wife on a normal bike. I can tone down the assist to make a level field. I also boost is to the max when I am solo with lots of cargo.
5. I can set a true 10 amp max. I live in a hilly, hot, desert city and don't want to cook the motor. I feel safe with 480 watts all day. I tested the max amps with stock firmware with a meter and it went to 15 regardless of settings.
My advice is to just go for it.
The display is simple to flash. Just plug in the pins and go. Erase the old and flash the new.
The motor took some tinkering. I built a harness from a speedometer extension, but ended up using bare arduino wires directly to the pins. I think shorter cables helped.
To connect the display, I used the WIKI and soldered the wires to the pigtail cut from the stock LCD5. Now it is plug and play. The wire diagram was correct for my unit. YMMV.
Heat shrink tubing is your friend! Clean cabling ties it all together.
