Rix
100 TW
KarlJ said:what size is the stock post? Mine has a carbon one and its stuck hence i'll have to cut / chisel it out and replace.
31.8mm is the diameter. It maybe 31.6mm, now I cant remember what I mic'd it at.
Rix said:I love dropper seat posts, you will wonder how you got along with out it. Get the shortest one though. Can't chop the bottom of them to shorten.
Rix said:KarlJ said:what size is the stock post? Mine has a carbon one and its stuck hence i'll have to cut / chisel it out and replace.
Theodore Voltaire said:Rix said:I love dropper seat posts, you will wonder how you got along with out it. Get the shortest one though. Can't chop the bottom of them to shorten.
I'm with you about a short post. Fox offers the shortest one I've seen, which is 4". Even on the rare occasions when I lift my seat to pedal, I only raise it 3 or 4".
I'm preparing a list of excuses, I mean important reasons, to justify why I need a to spend over $300 on a seat post, for the supreme ruler, buffy.
Theodore Voltaire said:Thanks Rix, that looks like a real good one, but too late for this project. I already ordered a Fox 4" external one on eBay, plus a $50 Fox remote lever. Apprently for $300 you don't get no stinkin lever, or a cable, that's extra.
It gets good reviews though, and I have a lot of room under the seat tube because my shock doesn't have a remote reservoir. I'll be able to push the post all the way down. As a matter of fact I need the post to be sticking out below the frame tube, because my taillight is hardwired, and right now it's mounted under the seat. I'll need to relocate it somewhere else, and I'm planning to use the lower part of the seat post that'll be sticking out down there.
Rix said:Tech question for everyone. Back from a ride, burned 1391 watts. Went to charge the battery, and the charger would shut off after a couple of seconds. Popped off the cover on the frame, and while I was checking the battery charge wires to make sure it was plugged in, the charger started charger. So I was wiggling the charging wires around and discoverd I had a short coming out of the frame mounted 3 prong plug, looks like the mircophone plugs on my dads Peavey Amplifiers. So as I am wiggling wires connected to the frame mounted plug, the charger kept going on and off. So I unscrewed the 2mm allen bolts, pulled the plug out of the frame, cut the heat shrink, and holy shit, the plastic connectors was melted. I think its a simple fix. I want to wire the connectors to the battery directly to the charger. Problem is, the charger wires are not colored red and black wires, it has blue and tanish almost yellowish wires. The tanish yellowish wire plug into the the #1 prong post, and the blue plugs into the #2 prong post. #3 doesn't have nothing. Does anybody know which wire between the blue and tanish/yellowish wire is positive. I have alot of my tools and stuff in a rent a storage and don't have access to my test light. What my intentions are is to just wire the plug connecor directly to the charger and charge that way. Got a friend coming in from Austalia and got to get this up and going by Wednesday morning for a ride in Yosemite. Any and all advise is appreciated.
Rick
Rix said:So that red wire that was cut has nothing to do with the charging. The cut red wire just unrestricted the power. Most likely your XLR plug on the bike is melted. Some where between page 150 and 250 in this thread, I posted a pic of what mine looked like. I had to change to Anderson units to get my charger to work.
Rix said:Rix said:Tech question for everyone. Back from a ride, burned 1391 watts. Went to charge the battery, and the charger would shut off after a couple of seconds. Popped off the cover on the frame, and while I was checking the battery charge wires to make sure it was plugged in, the charger started charger. So I was wiggling the charging wires around and discoverd I had a short coming out of the frame mounted 3 prong plug, looks like the mircophone plugs on my dads Peavey Amplifiers. So as I am wiggling wires connected to the frame mounted plug, the charger kept going on and off. So I unscrewed the 2mm allen bolts, pulled the plug out of the frame, cut the heat shrink, and holy shit, the plastic connectors was melted. I think its a simple fix. I want to wire the connectors to the battery directly to the charger. Problem is, the charger wires are not colored red and black wires, it has blue and tanish almost yellowish wires. The tanish yellowish wire plug into the the #1 prong post, and the blue plugs into the #2 prong post. #3 doesn't have nothing. Does anybody know which wire between the blue and tanish/yellowish wire is positive. I have alot of my tools and stuff in a rent a storage and don't have access to my test light. What my intentions are is to just wire the plug connecor directly to the charger and charge that way. Got a friend coming in from Austalia and got to get this up and going by Wednesday morning for a ride in Yosemite. Any and all advise is appreciated.
Rick
RhombusB52, above is my original post. See pics here. https://endless-sphere.com/forums/viewtopic.php?f=6&t=23996&start=3650
Theodore Voltaire said:I may have just solved all my braking troubles with new pads. I think the cheap ass pads I've been buying for a few years were the problem. These are the new ones.
https://www.ebay.com/itm/4-Pairs-High-Quality-Bicycle-Disc-Brake-Pads-For-Magura-MT2-MT4-MT6-MT8-DK-17/152952367953?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Theodore Voltaire said:Lalalalala, I love my bike, I love my bike, I like my bike, I love my bike, I love my bike,
KarlJ said:Theodore Voltaire said:Lalalalala, I love my bike, I love my bike, I like my bike, I love my bike, I love my bike,
Where can i get those mudguards?
