Internal Resistance for pack of LG HG2 cells
garolittle   1 kW
Post by garolittle » Nov 14 2019 1:13pm
Background: I have a 14S/20P pack of LG HG2 cells and need to measure the internal resistance of each cell string. Can I use the process discussed at the 4-minute mark of the YouTube link below except use a 20-olm resistor instead of a 1-olm resistor? Thanks!
https://youtu.be/av38iBxcOgQ
VenomKarts, LLC
VenomKarts.com
Augusta, GA
PaulD   100 W
Re: Internal Resistance for pack of LG HG2 cells
Post by PaulD » Nov 14 2019 2:41pm
To be clear, you want to measure the resistance of each 14S1P string? Or each 1S20P group? Not sure how your pack is configured. Basically, you can estimate current using I = V/R. I usually use 2C current for measuring DC resistance. If your current is too low, the voltage drop is too low and your accuracy isn't great. Obviously you don't want the current to be too high for your test equipment either.
garolittle   1 kW
Post by garolittle » Nov 14 2019 2:49pm
PaulD wrote:
Nov 14 2019 2:41pm
My apologies. Since the 20 in parallel act as a single cell in terms of voltage, I want to measure the internal resistance of each sting of 20
VenomKarts, LLC
VenomKarts.com
Augusta, GA
docware   100 W
Post by docware » Nov 14 2019 5:51pm
garolittle,what is purpose of this pack measurement ?
garolittle   1 kW
Post by garolittle » Nov 14 2019 5:57pm
docware wrote:
Nov 14 2019 5:51pm
I want to verify the BMS data regarding the internal resistance. I have an Orion jr. BMS and it is showing a higher reading than normal. Typical IR for this pack has been .8 to .9 but the recent reading was 2.8.
VenomKarts, LLC
VenomKarts.com
Augusta, GA
garolittle   1 kW
Post by garolittle » Nov 14 2019 5:58pm
I do not believe the 2.81 is correct but I want to double check to be sure. Thanks for any ideas. Gary
VenomKarts, LLC
VenomKarts.com
Augusta, GA
docware   100 W
Post by docware » Nov 14 2019 6:08pm
Measurement on the video has an error about 30 %. New fresh LG HG2 cell should have about 21 - 22 miliohm at 25 °C and 3,85 V, at 4 V may be even little bit higher. I assume that such accuracy is not acceptable for you.
docware   100 W
Post by docware » Nov 14 2019 6:36pm
Got an idea. If you can measure charging current or if you know the charging current, you can calculate internal resistance from the charging current value and voltage difference on the cell. You just need to have DMM with resolution mV or better 0,1 mV and connect to any cell´s balance wiring.
garolittle   1 kW
Post by garolittle » Nov 14 2019 8:13pm
docware wrote:
Nov 14 2019 6:36pm
Hey Sir. Thanks for the great responses. I will try your idea and let you know the results. I have to show my ignorance now ..... What is “DMM”. Also, in the screenshot above, what does 2.81 mean? Miliolms? It is normally .8 - .9. I could not find the unit of measure in the Orion JR manual. Thanks again for all of your help.
VenomKarts, LLC
VenomKarts.com
Augusta, GA
john61ct   1.21 GW
1.21 GW
Post by john61ct » Nov 14 2019 8:21pm
DMM is a Digital Multi-Meter
Getting IR for benchmarking changes from now vs later is very useful.
However, requires using the same calibrated instrumentation, voltage delta, current levels, SoC and temperature in order to be usefully comparable.
In theory it's a single number, but
______
In theory there is no difference between theory and practice. In practice there is.
— Yogi Berra
garolittle   1 kW
Post by garolittle » Nov 14 2019 8:32pm
john61ct wrote:
Nov 14 2019 8:21pm
Roger that and thanks!
VenomKarts, LLC
VenomKarts.com
Augusta, GA
docware   100 W
Post by docware » Nov 15 2019 1:48am
Yes, as john61ct mentioned, tracing of the internal resistance is useful, however requires using still the same conditions (temperature, SOC) and method. Using precise equipment is a must.
2,81 probably means miliohms, 20p LG HG2 should have about 1 miliohm per one paralel group (new fresh cells). Values 0,8 – 0,9 are telling us that inaccuracy of this BMS measurement was 10 – 20 %.
If you want to copy resistor method from video, you need to get at least 1A per cell which is 20A total. 4 V per cell means 56 V total for 14s battery. To get 20 A you need precise resistor 2,8 Ohm, power dissipated on resistor would be 1 120 W !!! Moreover, as temperature of the resistor will go up, the resistance will go up also and real current will be smaller. That is one reason of inaccuracy on the video, unsufficient DMM resolution is another, unsufficient resistor accuracy another, ………
As 1 kW precise cooled resistor is little bit a problem, I suggested method of cell´s voltage difference measurement during charging. I assume that charging current is about 1A per cell.
Resulting accuracy will depends on the current measurement accuracy and voltmeter resolution.
Even if total inaccuracy will be suppose 10 – 20 %, for checking of sudden 300 % rise of IR measurement such method could be sufficient.
Maybe you can borrow DMM with enough resolution and clamp meter or precise shunt for current mesurement.
Hillhater   100 GW
Post by Hillhater » Nov 15 2019 2:03am
Remember, this is a “group” of 20 cells in parallel.
Whilst they stay connected in parallel, you cannot get any IR data for individual cells...only the “group” result
And that can be affected by many other things such as connection integrity (40+ connections per group !) and individual bad cells corrupting the results of measurements
docware   100 W
Post by docware » Nov 15 2019 2:11am
We are not speaking about IR for idividual cells. garolittle wants to verify BMS internal resistance measurement, because it is showing 3 x higher readig than normal.
garolittle   1 kW
Post by garolittle » Nov 15 2019 9:12am
I really appreciate all of the responses. I have learned many things and will use the “charger method” references above. Good point about the individual cells. Also, it is true I am only looking for the IR of the cell string (with 20 in parallel). Either way, I appreciate the responses from both of you. Gary
VenomKarts, LLC
VenomKarts.com
Augusta, GA
john61ct   1.21 GW
1.21 GW
Post by john61ct » Nov 15 2019 12:15pm
Cells connected in parallel can be referred to as a Group
A String always refers to cells or groups connected in **series**
Bank is the highest level, usually a fixed location or tied to a boat or vehicle, at a specific useful/standard voltage, for some reason often not used for propulsion use cases.
"Pack" is widely used for EV / propulsion, can be like "modules" as a physical unit, but can also signify the whole bank, so I generally avoid if that makes things ambiguous. But, OK to use packs to mean "portable bank", as in powerpak, and also "pack-level" charging rather than bulk charging, to distinguish from balance charging or node-style charging via cell-level balance leads.
I use "Modules" for standalone functional units
usually portable, physically self-contained
usually can be used / charged separately
and/or wired in series or parallel to comprise
the main bank, even rotated in and out
Otherwise sub-banks or sub-packs, when xPyS units are further joined in parallel or series to comprise the full Bank or Pack.
john61ct   1.21 GW
1.21 GW
Post by john61ct » Nov 15 2019 12:16pm
can you link to where you bought that pack?
docware   100 W
Post by docware » Nov 15 2019 3:54pm
garolittle wrote:
Nov 15 2019 9:12am
Let us know the outcome Gary.
garolittle   1 kW
Post by garolittle » Nov 15 2019 4:00pm
Yes sir. I will run the test on Sunday and post the results by Sunday night or Monday morning. Thank you again for all of your ideas.
VenomKarts, LLC
VenomKarts.com
Augusta, GA
garolittle   1 kW
Post by garolittle » Nov 16 2019 2:25pm
john61ct wrote:
Nov 15 2019 12:16pm
www.allcelltech.com.
VenomKarts, LLC
VenomKarts.com
Augusta, GA
garolittle   1 kW
Post by garolittle » Nov 16 2019 3:55pm
docware wrote:
Nov 14 2019 6:36pm
So my DMM is very basic. See below. Any recommendations for a good one I can buy to perform this test? Thanks.
VenomKarts, LLC
VenomKarts.com
Augusta, GA
john61ct   1.21 GW
1.21 GW
Post by john61ct » Nov 16 2019 3:59pm
Hmm interesting. I've thought of using potting compound that is thermally conductive with aluminum shell.
But phase changing sure takes things to another level.
Of course best practice is to prevent heat from rising significantly, but some people / use cases just require /accept that.
garolittle   1 kW
Post by garolittle » Nov 16 2019 4:23pm
john61ct wrote:
Nov 16 2019 3:59pm
We strongly recommend AllCell Technologies. Great product and excellent customer service. 8)
VenomKarts, LLC
VenomKarts.com
Augusta, GA
garolittle   1 kW
Post by garolittle » Nov 18 2019 1:33pm
Ok. Part of the mystery was solved. When I use the OrionJr. BMS “Setup Wizard”, I have to select a battery type. Since the LG HG2 was not listed, I chose the other LG cell. That is what caused the “2.81” reading for Internal Resistance”. Last night, I changed it to the Panasonic cell and the reading returned to a more normal IR reading of .96. Apparently, the LC cell that I selected previously was a different chemistry.
VenomKarts, LLC
VenomKarts.com
Augusta, GA
john61ct   1.21 GW
1.21 GW
Post by john61ct » Nov 18 2019 2:08pm
What does the BMS use those data for?
I'm surprised it doesn't read them directly in order to tell the user, rather than the other way around.
Do they update the "library" as new cells come on the market?
