larsb
I put liquid tape on the other connector already before as several wires wanted to slide out on that one. Should have followed the logic
Lol, every bluetooth device I've ever used has been short range, which is all it was designed to be. I feel lucky whenever my BMS connects from the garage to my living room.Okami said:Hi, newbie to bluetooth bms and still havent read whole discussion, but:
Has anyone come up with a way to increase range for the bluetooth?
I tried to mount this bluetooth on multi rotor drone, to properly see voltage levels, but the 'reception' is so bad, that the connection gets broken apart after like 5-6meters..
Has anyone else tested the bluetooth range for these bms'es? The model which im having seems to have really bad range or something is really interfering..
Was hoping for at least 10 meters of range or so..
Not sure whenever to look for other options (to remotely view cell levels) or just find a way how to improve the signal or change to 2.4ghz communication..
This is to see the cells dont go out of whack while in flight and also properly monitor temperature and voltage drop at various loads.
eee291 said:I've had about a 50% failure rate with the PC programmer boxes, so I would suggest buying one or two additional ones.
You can get them separately on Aliexpress just in case:
https://www.aliexpress.com/item/7S-24V-13S-14S-48V-Lithium-Battery-Protection-Board-Static-Balance-BMS-APP-Cell-Display-Smart/32870436486.html?spm=a2g0s.13010208.99999999.350.206e3c001Q0iSG
RV24.1.4
ANT-BMS-24S
WWW.MAYIBMS.COM
eee291 said:You have to connect the B- on the BMS as well, only the balance wires is not enough.
0.11 V it is normal voltage drop after unplug charger. When i charge li-ion to 4,2V , after 1hour voltage drop to 4,18Vartvk said:JBD BMS
I have question when unplugged charger and leave it isolated without connected to other components around 12 hours , the total pack voltage bleeding is 0.11 V (from 81.68V to 81.57V)
Is this normal for this BMS ?
zipoman said:Yes, it is possible change settings only with app. But i cant set max voltage 3,5V for LFP, min 3.65V - I must set this voltage by pc. For li-ion I think no problem with 4.1V max voltage, problem is low value.
Further to my post above dated June 21, 2019, on September 21, 2019, I got the following readings.tmho said:I finally finished my battery pack with the bluetooth BMS. But something strange that I cannot understand why.
I set the no. of cell (14s) and the capacity (13.5AH) of the pack. And I got the following readings from the app.
Voltage of the pack: 51.7V
Capacity of the pack: 7.006AH (52%)
Highest voltage of the cells: 3.691V
Lowest voltage of the cells: 3.688V
Then I started to charge the pack. I saw the voltage and capacity went up gradually and that was normal. After charging for about half an hour, I stopped the charging by unplugging the charger. And I got the following readings from the app which I think should also be normal. (Sorry, I did not take a screenshot)
Voltage of the pack: 55.1V
Capacity of the pack: 9.091AH (68%)
But after that, I found the capacity reading still going up. At about 40 minutes after unplugging the charger, I got the following readings.
Voltage of the pack: 54.1V
Capacity of the pack: 9.530AH (71%)
Highest voltage of the cells: 3.860V
Lowest voltage of the cells: 3.858V
Why the capacity of the pack continue to increase after the charging had stopped? Is something wrong with the app?
PS: so far after the above screenshot, the capacity reading stays at 9.530Ah without going further up.
I just found out why I got such readings. They calculate the capacity (or state of charge) based on the voltage of the cells. From the latest version of the app, I can see that they set 3.405V as 0% and 3.477V as 10%. Therefore, my cells at 3.45V will be treated as 7% (7% of 13.5AH is 0.945AH). I understand such method (state of charge based on the voltage) is not that accurate. However, if somebody know the most appropriate voltages for various state of charge (for lithium ion cells), please let me know so that I can change the settings in the app.tmho said:Further to my post above dated June 21, 2019, on September 21, 2019, I got the following readings.tmho said:I finally finished my battery pack with the bluetooth BMS. But something strange that I cannot understand why.
Voltage of the pack: 50.2V
Capacity of the pack: 6.230AH (47%)
Highest voltage of the cells: 3.590V
Lowest voltage of the cells: 3.588V
After that, I have not used the battery (no charging and no discharging). Today, I have the following readings.
Voltage of the pack: 48.3V
Capacity of the pack: 0.836AH (7%)
Highest voltage of the cells: 3.452V
Lowest voltage of the cells: 3.450V
This time, it seems that the capacity should not decrease by that much even though the BMS may still draws some current during this storage period. Am I correct? Is there something wrong with the app or I did not set the parameters properly?
P.s. My battery is 14S4P. I set the no. of batteries to 14s and the battery physical capacity to 13.5AH. I have reset to factory settings and set 14s and 13.5AH again, but still got the above readings.
There are three factors there, which are only loosely if not barely related to each other.tmho said:I just found out why I got such readings. They calculate the capacity (or state of charge) based on the voltage of the cells.
Thanks eee! I wonder how far the functionality of the 6 digit passcode extends to, but I did get the new software up and running.eee291 said:Hey guys, I thought I'd make an announcement about the updated JBD App and PC programming software.
I know a few guys who don't update and then get issues with the newer Android versions and what not.
Here are the links:
Link to the App and PC soft.
http://www.jiabaida.com/home-1.7-info-id-104-catId-52.html
Direct link to the Zip file.
http://www.jiabaida.com/uploads/soft/xiaoxiangBMS.zip
Some pics:
https://imgur.com/a/lWp3iOA
When trying to connect to your BMS, the App will ask you to make a 6 digit password (there is no confirmation so be careful!)
It looks like you can change a lot more settings than before, looks like most people won't be needing the wonky PC dongle :thumb:
As far as I know, the JBD BMS only shows instantaneous voltage and amperage readings. Wattage on the smartphone app is calculated on the fly I believe, and anything showing capacity levels or mAh are estimated from the current voltage. There are adjustable parameters for what voltage your cells are at for every 20% of their capacity level to adjust that calculation it gives you.SilverLine said:No, just only using the BMS as "charge only".. And connect the main negative wire directly from battery to speed controller. I am aware, that I loose some safety.
But thanks... And its also possible to se how many aH i put back in the battery when charging ?
Does it show how many mAh you put back in each cell ?
