daenny   10 mW
Re: TSDZ2 mid drive -- Flexible OpenSource firmware for TongSheng TSDZ2 mid drive motor
Post by daenny » Dec 19 2019 3:26am
Minatauro wrote:
Dec 14 2019 1:21pm
Hi,
I just swapped out a broken torque sensor for a brand new one, however, there is no assistance from the motor now when peddling. The vlcd5 is fine and has no error codes. I tried the walk assist to test the motor and that is not working. If the display is working does that mean the controller is ok? The torque sensor is new and the wires seem to be ok on it. I can't figure out why it's not giving assistance. Had anyone experienced this before?
I am experiencing something similar. I am on beta 0.20 from buba's Google Drive. I was running it for about 2000km without any problems.
Since two days, the display starts up correctly, but sometimes the lights do not come on (I have the setting that the lights should be on after start). When this is the case, also the motor does not start at all. Voltage, cadence and speed readings are working. I can change the assist levels. But when I switch the lights, only the display light switches, and no motor assist whatsoever, also no walk-assist.
I do not have e-brakes, but today I saw once that the e-brake sign was shortly on. Could that be the reason?
In other cases, the e-brake sign was not on at all, and the motor had the same behaviour.
Sometimes, after a while the lights come on and then the motor also works as expected for the whole trip until I shut it down again.
A couple of questions:
If, for some reason the e-brake pin is giving the wrong reading during bootup, could this lead to the described behaviour?
Could we add a function to disable the ebrakes completely in the software?
Is there any other thing which could prevent the motor to give assistance?
Another theory is that there is something in the code, i.e. could it be that there is a buffer overflow or similar? I will re-flash the bike this weekend to check if that is the case.
Current build:
GSM Woosh Middrive, with VESC controller, color LCD Display and Teensy ForumsController:
https://endless-sphere.com/forums/viewtopic.php?t=84042
obcd   100 W
Post by obcd » Dec 19 2019 5:32am
It used to be a feature in the motor firmware for debugging. When one of the E-brakes is activated during powerup of the motor firmware, it will not power the motor. You can single step trough the motor firmware for debugging with that.
I assume the display controls it's own backlight and also sends a command to the motor controller that turns the light output on.
I have no idea if this part of the firmware is also disabled when it detects a brake situation during bootup.
casainho   10 GW
10 GW
Post by casainho » Dec 19 2019 5:56am
daenny wrote:
Dec 19 2019 3:26am
Minatauro wrote:
Dec 14 2019 1:21pm
Hi,
That issue of no lights and no motor assistance should not be related to brake sensor. Still, yes, it is on the list since long time ago to be able to disable some sensors on the display and keep the system work, mainly because sensors can fail while we are riding far from home.
I think no lights and no motor assistance are really connected due to how the hardware works. I am being slowly working again on the motor controller and I will revise this, I think there should be a way to solve this.
I would say that maybe this issue happens to you because the ambient temperature is now colder than before??
- TSDZ2 OpenSource firmware
famichiki   100 W
Post by famichiki » Dec 19 2019 6:46am
In v0.19 the brake sensor behaviour seems to pause the motor, rather than fully reset all operations. When the brake is applied in ebike_app.c (around line 316) what other parameters could be (re)set to ensure this?
I've tried setting ui8_g_duty_cycle = 0 or decrementing it, but get a hard motor shut off when otherwise the brake operation is quite smooth.
Code: Select all
 // let's force our target current to 0 if brake is set or if there are errors
  if(ui8_m_brake_is_set || ui8_system_state != NO_ERROR) { ui8_m_adc_battery_target_current = 0; }
casainho   10 GW
10 GW
Post by casainho » Dec 19 2019 7:50am
famichiki wrote:
Dec 19 2019 6:46am
Code: Select all
What are you trying to achieve??
famichiki   100 W
Post by famichiki » Dec 19 2019 8:02am
casainho wrote:
Dec 19 2019 7:50am
To fix the motor overrun and strange kick of power sometimes after stopping pedalling. Right now I need to wait a few seconds after stopping pedalling to change gear smoothly. However momentary braking cuts power instantly and smoothly. The problem is that after releasing the brake the overrun can restart, and also can still get that strange kick. So when I grab the brake I want to totally forget whatever other calculations are happening and reset the motor.
casainho   10 GW
10 GW
Post by casainho » Dec 19 2019 10:46am
famichiki wrote:
Dec 19 2019 8:02am
casainho wrote:
Dec 19 2019 7:50am
Good.
Would be great if after you can share with us your discoveries so I can improve next firmware version.
mctubster   100 W
Post by mctubster » Dec 19 2019 2:32pm
famichiki wrote:
Dec 19 2019 8:02am
casainho wrote:
Dec 19 2019 7:50am
Which firmware? Do you have boost assist on? Is this occuring and the 10? seconds after starting riding?
famichiki   100 W
Post by famichiki » Dec 19 2019 6:37pm
I really don't have much knowledge of this code or embedded processors so am struggling to figure things out.
I only have the VLCD5 display, and have tried Marcoq's and Ackmaniac's forks and Demion's branch. All are based on v0.19 and all have some issues present. It happens with or without boost assist. Stancecoke gave me some suggestions in the VLCD5 thread but that either didn't improve things or caused a hard cut out and loud click which felt like it may damage the motor.
viewtopic.php?f=30&t=98281&start=550#p1514160
The overrun can be quite long, I can count the seconds out... one one-thousand, two one-thousand... Then the kick of power will sometimes suddenly come after the motor has stopped running. I can't remember if I mentioned it in this thread, but sometimes the motor never cuts and it continues propelling the bicycle until the main power is forcefully cut off. There are a few others in the VLCD5 thread with the same problem.
The brake works very quickly due to being on an interrupt and cuts the power so smoothly. I wish the PAS detection worked the same way. But if the motor is in an overrun state, if you quickly apply and release the brake the motor will return to the overrun. Braking should reset and shutdown everything until pedalling is detected again.
I know development is focused on 0.20 now but if anyone could provide some assistance I'd really appreciate it. I'd like to do a quick workaround of tapping the brake to kill the overrun and reset the motor.
So, how to stop the motor from resuming where it left off before the brake was applied?
I think this what happens when applying the brake...
brake.c
brake is set = 1
Code: Select all
BitStatus brake_is_set(void)
  if (GPIO_ReadInputPin(BRAKE__PORT, BRAKE__PIN) == 0)
    return 1;
Code: Select all
void EXTI_PORTC_IRQHandler(void) __interrupt(EXTI_PORTC_IRQHANDLER)
  if (brake_is_set())
    motor_controller_set_state (MOTOR_CONTROLLER_STATE_BRAKE);
motor.c
ui8_m_duty_cycle_target = 0;
Code: Select all
void motor_set_pwm_duty_cycle_target (uint8_t ui8_value)
  if (ui8_value > PWM_DUTY_CYCLE_MAX) { ui8_value = PWM_DUTY_CYCLE_MAX; }
  // if brake is active, keep duty_cycle target at 0
  if (ui8_motor_controller_state & MOTOR_CONTROLLER_STATE_BRAKE) { ui8_value = 0; }
  ui8_m_duty_cycle_target = ui8_value;
ebike_app.c
Code: Select all
Is this all that happens?
There must be something else going on that immediately sets ui8_m_duty_cycle_target and/or ui8_m_adc_battery_target_current back to their previous state after the brake is released, but what?
famichiki   100 W
Post by famichiki » Dec 19 2019 6:55pm
Double post
casainho   10 GW
10 GW
Post by casainho » Dec 19 2019 9:40pm
famichiki wrote:
Dec 19 2019 6:37pm
I think you did understand the code. I hope you get the issue.
daenny   10 mW
Post by daenny » Dec 20 2019 9:17am
casainho wrote:
Dec 19 2019 5:56am
It is indeed much colder now and my bike is outside in the shed. But I tried again today where it is quite mild (10 degrees Celsius) and still in did not start.
Is there anything that I can try to eliminate certain issues? I use the bike for my daily commute to work and not having a motor support is not the worst, but I really need the lights. I will reflash this weekend just to be sure.
Current build:
famichiki   100 W
Post by famichiki » Dec 21 2019 4:00am
mctubster wrote:
Dec 19 2019 2:32pm
Just wondering why you are asking those specifics, is there a known similar problem with boost enabled?
daenny   10 mW
Post by daenny » Dec 21 2019 9:20am
daenny wrote:
Dec 20 2019 9:17am
I just did a reset to factory defaults and reconfigured everything to the same way as before (except the odometer). It seems to work now again. I turn the bike on and almost immediately the light turns on and the motor support is working. I will see how it holds up.
I was looking through the advanced technical data, the torque reading is now 135 idle up to 240 under load. I thought that previously it was much lower... What are reasonable readings for the torque sensor?
Could that also explain the bike not starting, i.e. that the torque sensor is slightly damaged or giving bad readings, leading the bike not being able to calibrate or something?
Maybe the torque sensor is also sensitive to cold? Does anyone have a similar experiences?
EDIT: I was too quick :(.. Now it did start up, but again with 10-20 seconds wait...
Current build:
casainho   10 GW
10 GW
Post by casainho » Dec 21 2019 4:39pm
I am being working on the next firmware version, both on motor and on display. The main new feature will be the torque sensor full calibration and here is my torque sensor values (X axis shows kilograms weight on the left and right pedals and Y axis the torque sensor ADC value).
We can see it is not linear and even worst, from time to time, I think we will need to recalibrate the torque sensor because it gets worst/gets less sensitive. We will be able to input on the display, the delta measured values of torque sensor ADC and kilograms weight.
And to make all this, the configurations data that flows from display to motor controller will increase a lot, so, I had rewrite a new communication protocol. Now, the display asks for the motor controller firmware version at startup and only works if is the expected version. Also, the configurations are then sent from the display and the motor will not work until receive them.
The new communication protocol is working well and the next step I will do is to add the torque sensor calibration configuration menu. I really expect to have this new version of firmware on the next Friday day 28. And this is only for 850C display for now, as we have currently some issues with the code of SW102 and that should be solved as soon as the geeksvile developer is available again to work at it.
dameri   100 W
Post by dameri » Dec 22 2019 5:55am
casainho wrote:
Dec 21 2019 4:39pm
Thank you so much for your efforts to improve osf :bigthumb:
izeman   100 GW
Post by izeman » Dec 22 2019 6:08am
@casainho: You man are awesome!! You know what: I got several working ebikes, and I know just bought a TSDZ2 to try your amazing work, and install it on one of them :) And I will send a payment as well. This work needs to be supported! Thank you.
thineight   100 W
Post by thineight » Dec 23 2019 4:38pm
casainho wrote:
Dec 21 2019 4:39pm
Good stuff casainho. I will stay tuned for the development, even if I admit that current v0.20 with LCD3 is really good and hard to beat.
I have just one question: there is a lot of effort in modeling the non linearity of the torque sensor and obviously we lose a lot of "resolution" after the first linear segment because we need a lot more kg on the pedal, compared with the 1st linear segment, to increase 1 unit in the torque sensor.
I see from your chart that you have about 20 kg each pedal available in the first linear segment (same as mine from my summer readings), I do not have numbers on top of my head but what is the force we average put on the pedals going uphill on a proper low gear? Are we most of the time in the 1st linear part or in the 2nd?
Thanks and.. Merry Christmas to everyone in the forum!!
MTB KTM Ultra 29" - City bike DAYTONA 28"
famichiki   100 W
Post by famichiki » Dec 23 2019 7:38pm
In v0.20 what is the difference in how advanced cadence mode works vs standard mode and why is calibration required?
mctubster   100 W
Post by mctubster » Dec 23 2019 9:00pm
thineight wrote:
Dec 23 2019 4:38pm
If you work backwards using math and are reasonably fit, say you are outputting 200W at 80RPM = 23.87Nm of torque. Using .17m lever length that gives you 14.32KG of pedal force (on average, ie across both pedals.)
So I would say you are generally operating below 20KG unless you are standing on the pedals, which you only do for low RPM high torque and not for high power. So the sensor assuming calibration for the lower range 0-20KG is pretty good unless you are standing on the pedals so to speak.
Cheers
casainho   10 GW
10 GW
Post by casainho » Dec 24 2019 3:17am
mctubster wrote:
Dec 23 2019 9:00pm
We can see on the graphs that a value after 10kgs, the torque sensor measures half the value, so, it is very no linear almost at start.
I can do 200 watts on average but about 400 if I press the pedals on a climb for some minutes, even without standing on the pedals. And the peak peak values measured are about 1.4x times more than the average, so yes, I am on the no linear part almost always.
thineight wrote:
Dec 23 2019 4:38pm
My idea to to merge the v0.20 good features over the time.
There are things I don't like, like the emtb, because it masks this no linearity of the torque sensor.
With torque sensor full calibration, the output of the sensor are linear kgs/pounds (also correct calculation of human power!!), then, on top of that, the emtb can be added all will be more predictably and easy to understand the values, also the emtb curve points being setup directly on the display.
michih.   100 mW
Post by michih. » Dec 24 2019 4:25am
Can I adjust the volt display on the kt LCD3? It shows 1 volt too much.
Mfg Michael
btslo   10 W
Post by btslo » Dec 24 2019 4:42am
Try adjusting the battery internal resistance value.
thineight   100 W
Post by thineight » Dec 24 2019 5:04am
famichiki wrote:
Dec 23 2019 7:38pm
If I remember correctly v0.20 counts also the moment when the magnets goes far from the sensor (valleys), not only when it approaches (peaks) like the std mode. In such way you practically double the resolution of the PAS.
Not sure why the calibration is needed, I assume to properly determine the "best distance" between the readings, because I assume they are not just half the peaks distance.
Hope it's clear enough.
michih.   100 mW
Post by michih. » Dec 24 2019 9:35am
btslo wrote:
Dec 24 2019 4:42am
I try it, but there is no diffrent.....
