Hi,
I'm setting up a KT controller and LCD8H with a geared 60V 1000W motor. And little bit problem with motor's magnets count.
For P1 setting,
I have told the motor has 8 magnets and reduction gear ratio is 1:23. So is it just 23 X 8 magnets equals 184 and input in P1 setting value is 184?
But I'm not sure if the motor only have 8 magnets. Actually, which magnets that I should count? Magnets on the body? I saw somewhere in the motor have 2 places of magnets but I'm forget where I saw this.
deeph
For P1 setting,
The P1 settings are a motor characteristic parameter where: P1 = Motor Gear Reduction Ratio × Number of Rotor Magnets Rounding to a full number is necessary. The P1 setting ranges between 1 and 255.
deeph
