Well I think this year it will note possible to realise!
But I hope to get it running by autumn.
Let´s say due to the fact, that Magnax isn´t able to deliver me the AXF275 because they are now in beta test phase (btw. they are testing there motor since 2016 on a test bench) and telling me pls. ask in 2 month again and I heared this since January last year, I had to change to another motor company! Magnax told me also that their motor will weight about 20-24kg and regarding their last information it´s now 28kg and so on …
Du to the fact of change, the motor type is 10cm bigger in diameter and that will have an influence of the main frame that I will have to extend it!
I had bought the frame in July last year but my friend who has the oppertunity to do this at his company is very busy, so everthing take a while.
But I got good news from motor manufacturer that the motor will be ready for shipping in two weeks!
I also want to create a new bike design with this extension, so it´s no longer a GSXR, even more a DIY custom frame
and also the easiest way to handle it instead of creating a complete new one. I already took the dimensions of the frame and they are compleatly different from left and right hand side!
The frame will be extended about 25cm and as you can see on the picture with the standard frame and the deeper installed handle bar it will be a "tight box" to reach it.
There will also be create a new "fuel tank" where my body will lay down on it.
