skyungjae said:I bet ASI, in general, would sell a lot more controllers if they didn't go with their orange/blue theme. :lol:
3DTOPO said:skyungjae said:I bet ASI, in general, would sell a lot more controllers if they didn't go with their orange/blue theme. :lol:
Is the case fairly easy to remove? If so, most thermoplastics can be dyed. Unlike paint, it won't scratch off.
To dye plastic, get a pot big enough to contain the part, bring water to a boil, then add some clothes dye like Rit Dye (I recommend liquid opposed to powder dyes). Boil the part until you see the part obtain the color that you want.
sn0wchyld said:awsome - gonna try that with PVC.
3DTOPO said:sn0wchyld said:awsome - gonna try that with PVC.
I think you can just dip PVC in the dye for 30-60 minutes - might not even need to boil it.
You can also use pipe-cleaner mixed with petroleum dye to stain PVC:
https://makezine.com/projects/make-30/stain-pvc-any-color-you-like/
you'd think that...but most of the common ebike motor kit control parts i've run across are styrenes. (throttles, control clusters, ebrake lever mounts (the ones that aren't cast alloys), display casings, battery cases, etc.) sometimes it's abs, which takes heat better, but sometimes it's plain old ps.3DTOPO said:That said, I don't think styrene/polyethylene parts are very common - especially for motorbike/bike parts. :wink:
Alligator turbo and Shimano ho3c are the preferred aftermarket pads.LightBeeCommuter said:Any recommendations on brake pads?
I tried the HO3C pads but found them to be pretty noisy. The HO1A (organic) pads are much quieter and still stop well.X-Nitro said:Alligator turbo and Shimano ho3c are the preferred aftermarket pads.LightBeeCommuter said:Any recommendations on brake pads?
Kauaiguy said:Just installed a new skid plate made from HDPE from a Australia Sur-Ron dealer(https:racespecsurron.com)$65 delivered,seems very solid and should slide over stuff better than the fragile stock skid plate.EA322BB0-B718-49D1-AD45-ADA9294DCD14.jpeg63C0A5A1-1D36-44C0-810C-5DEEE7264457.jpeg
Maybe this helps get you back together?elik1111 said:What's about the part that push the hydrolicc piston?
X-Nitro said:Maybe this helps get you back together?elik1111 said:What's about the part that push the hydrolicc piston?
https://surron.co.uk/collections/accessories?page=3
Remember these china bikes have no real parts supply from the factory, most parts sold are from new bikes being salvaged to sell the parts; & with critical world-wide illness causing interruptions in shipping, now is not a good time to own sur ron needing parts.
