Chromotoast
- Joined
- May 12, 2020
- Messages
- 17
Hey friends. Like many of you stuck in quarantine I’ve been thinking of ways to pass the time. I have a bunch of old motors, sprockets, chains etc and I figured I’d convert one of my old bikes into an ebike. I would also like to pedal it, otherwise I’d just strap a brushless motor onto the existing drivetrain and be done with it.
I’ve been thinking of the best way to do this, and ultimately seems like the best way is just to have a dual drivetrain system, one for the pedals and one for the motor that are independent of each other. My bike has a flip flop hub already so I’m sure that makes it much easier to execute what I have in mind. Ideally I’d have the motor drivetrain connected to the freewheel side of the hub and leave the fixed gear side to peddle, but since it’s fixed gear that would just mean the pedals would still turn with the motor engaged which I don’t want, so removing the fixie gear and putting in a second freewheel seems likely what I’d have to do. Anyone have any suggestions that I can pull inspiration from or just general advice?
Thanks!
Thanks!
