barbarossa said:
anyways hard to say. I am 1.85m and have both, Frey AM1000 and Frey EX - both in L. Frey EX seems to be a little smaller or lets say "more handy".
As I'm 177cm I think Medium should suit me just fine in that case
barbarossa said:
Additional Charger
-> anyways, the default charger is 3A. you can use any AliExpress charger with DC plug - I take the C300 (also delivered with Frey AM1000) for charging the Frey EX - with 4A (originally it was set at 5A).
I've looked on both AliExpress and Alibaba for a "4a ebike charger" but the options available are staggering:
42v 4A ebike battery charger, 16.8v 4A charger, 12.6v 4A charger, 54.6v 4A charger, 50.4v 4A.... the list goes on and on. The supplied battery is 48V/14Ah. I don't know which is the better suited charger to be honest. Frey are charging US$35 for a spare
barbarossa said:
original rim set twice
Additional wheel set for front/rear w/ cassette, brake discs & Super Moto-X tires
-> Instead I would build a new set with Onyx Hub or go for the DTSwiss 1700(or 1900) - with SRAM cassette and Magura MDR-Ps.
I was quoted US$350 for a complete wheel set but for a "local" chinese manufacturer. I'll take on board your advice and remove the wheel set from my order. Thank you
barbarossa said:
44t is the biggest possible chain ring for Frey EX caused by the massive rear suspension, gear ratio with 40t was way too short for me:
I asked Cecilia about a 44t to be told "I've asked my boss. That's not possible sorry". As to whether that means they don't have a 4t in stock or she doesn't believe it will fit, I don't know
You've given me awesome help. Thank you barbarossa. I love your cockpit configuration by the way.
I am starting to give serious thought to aborting the whole process though.
I'm no closer to completing the order now than I was 8 days ago when I first opened dialogue.
I'm concerned that if Frey are this slow to communicate when I'm trying to spend almost US$5k with them how bad will they be if I have a serious issue in the future!?!?
Thank you for your time
