1abv said:
Soo I've lowered my rear pressure from 15 to 12 psi with the Bridgestone, the sidewalls on that tire are crazy stiff.Ideally Ide like to find another moto tire with a softer sidewall.. lowering the pressure did help a lot with the ride. and at some points I was going at full clip through fist sized rock gardens... That and backing out the compression.. im going to get my shock rebuilt soon anyway may play again with the shims and see whats what..Really looking for as much compliance on small and fist sized rocks don't really care about bottoming resistance and big hits.
Try to find a shim combo that gives you high speed compression and slow rebound options. On our bikes, we really don't need dual circuits for compression, infact, with hub motors, its more important to precisely control the speed of the rebound over everything else.
