HughF said:
You should set up as follows:
Motor current calculation: torque mode
Current ramp: 10a
Assist w/o pedal: enabled
Startup boost: disabled
Startup boost fade: default
Startup boost duration : default
And calibrate the torque sensor, this is super important.
With those settings you should have power from the moment you apply pressure to the pedals/hand cranks, and the assistance will start irrespective of whether you are below the cadence sensor sensing threshold. This is really important to help people get moving and assistance from a start and with a low cadence.
Hugh thanks for the reply,
I'm not doing this just for myself I'm trying to get all the default setup for anyone that has a handcycle. Most of us don't have the time or the ability to calibrate the torque sensor without recruiting someone else to do it for us. So I need to get all the settings working the best they can without the torque sensor calibration and then if they want to get it calibrated they can go from there.
I need these questions answered by you, Casaino, or anyone!
(1) Maximum Battery Current,
No matter how many times I turn it up past 16 amps and no matter what I've tried, once I turn off the system when it turns back on its back at 16 amps.
What do I need to do to keep it at a higher amp setting?
(2) Minimum current value (in ACD steps),
What does a higher number setting do compared to a lower number setting?
I want to make the torque sensor as sensitive as possible!
(3) Torque ACD threshold value,
(4) Coaster Brake ACD steps,
Does a higher or lower number make it easier to pull back?
