Fair enough, Thanks for the infominimum said:Unfortunately not, was busy trying to contain the mess.Chambers said:Did you happen to take any pics of the process?
I recall reading that thread a few years ago - Will have another scan for anything cyclone/in-runner specific, Thanksamberwolf said:A few people here have potted the stators of various motors. Justin's thread here
https://endless-sphere.com/forums/viewtopic.php?t=48753
has some testing on that.
I am pretty convinced that it's a good idea so if no one else posts a vid before I get to it I will. I don't think it will be too difficult but you never know.Tommm said:I want to do it too. Next guy doing it please do it on video, explained for dummies.
yeah I hear ya,Skaiwerd said:Chambers
I’m reluctant to check on my 12f from necular. Seems like it’s always wait. All I want is auto learn and adjustable regen brakes. No one in the industry reading what people want to compete with necular? I’ll give them my business, yes virus I know, but this waiting makes is almost not worth it. Anyone else except for power velocity, company seems iffy, or sabaton etc that I may never get working correctly? I’m sure nuclear is awesome but I may never get my hands on one.
That was me before I got my nucular.Chambers said:I read somewhere someone was having issues with the PV controller and cyclone motor.
Skaiwerd said:This looks like a good store from AliExpress. I know to look for power, ground and signal for adjustable regeneration braking. Some of these controllers you can get the bluetooth dongle and a display. Just think they are underrated as volts times amps is 3-4 times what the rating really is like how qs motors are rated.
Anyone with a entrepreneur sprit will know a steel frame, rigid ok, 1 1/2” fork compatibility, to match this motor will be a good seller. Or the start of a nice custom ebike. I’m talkin dual chain version here.
I’m thinking nuc may be making their oem customer(s) the priority now as the virus slowdown has them in catch up mode and they probably want to preserve that stream of bulk orders. Meaning they need a USA distributor to ensure some confidence in them.
Tommm said:I am using the bac2000 on mine. It is quite happy.
Also I noticed there is less heat vs the square wave yuyangking when lugging it at low power levels, so PAS at very low power levels could be doable. I think it might be due to the wave form being able to deal with the motor being between two positions for a longer time.
Only issue is the hall sensors aren't working, I read the kellys only work when powering the halls from 12v instead of 5v, the asi does have a 12v wire but I personally can't be bothered for the moment.
Do you have any pics of your ASI setup Tommm?Tommm said:I am using the bac2000 on mine. It is quite happy.
Chambers said:Do you have any pics of your ASI setup Tommm?Tommm said:I am using the bac2000 on mine. It is quite happy.
Chambers said:I meant on your bike - just curious how it looks because they are an odd shape
Tommm said:Chambers said:I meant on your bike - just curious how it looks because they are an odd shape
https://ibb.co/album/VwPWg2
It is right next to motor. Huge blue transparent speaker cables connecting each way. It is mounted with cable ties in a way it is flexible but self correcting. A blow to any corner or side will cause the controller to pivot a little in its direction, then pull back to position. That way nothing is breaking or going loose after. The controller isn't significantly wider than the battery box, 105 vs ~115, and is wrapped the same way with cf vinyl.
I had my old big controller mounted in the rear between wheel and seat tube. Now it is home to a bottle cage. For water or tools. Pic taken at full compression.
Got around to put the mini heatsinks all over the motor. They have thermal adhesive pads but not meant for outdoor use. Some zipties spliced in, they are conducting heat and motor is happier.
Chambers said:Thanks for the pics - it's always interesting to see how different people attack problems, That actually blends in pretty well.
Did you do the heat-sinks at the same time as the controller swap? Would be interesting to see what difference one or the other separately vs both together makes to the temps.
Chambers said:Any battery configuration gurus watching?
I'm trying to figure out the best way to group the cells +/- 20s 8p cyclone coaxial battery.JPG
Chambers said:I had an idea for the battery connections - Copper carries current better than Nickel and I don't like the idea of multiple layers of spot welds (I still may end up doing it though :lol: )
My idea is to create a Copper-Nickel combined sheet for the series connections as below - Obviously the sheets would have to be made to shape this is just the concept...
Tommm said:Chambers said:I had an idea for the battery connections - Copper carries current better than Nickel and I don't like the idea of multiple layers of spot welds (I still may end up doing it though :lol: )
Make sure it is compatible with whatever cell holders you plan on using, a lot of them poke out up in the 4 corners of each cell. Also the cell insulator stickers, possibly something else too, your cells might rub against the cutout of the copper holes.
How do you plan on connecting the two sheets? If it is spot weld, you are still doing multiple layers, just with 3 different materials.
Thanks, I was thinking about mounting the shock to the top tube too. Not sure what you mean about the battery?GP-tech said:Hey Chambers, great looking bike and mint design skills!
looking forward to see the prototype running. Maybe consider mounting the shock to toptube(less stress for the mainframe) and the rearend pivot piont in the seattube(mentioned before) with the full width of your frame(thats the weak point of an monolink rearend).
Keep in mind that spotwelds should be forcefree at the connections by design(cut and stepdown bend, like bosch packs).
