Speedict neptune lite
AlexTM   1 mW
Re: Speedict neptune lite
Post by AlexTM » Jul 29 2020 6:39am
WOW what a scare, ok I put 10 and everything OK.
Thank you.
I don't know if I keep trying, it gives me an error:
Device is unavailable, please power on and connect
AlexTM   1 mW
Post by AlexTM » Jul 30 2020 4:59am
Sorry for my ignorance, I am very bad with English.
I can't install version 117, do you have a lot of changes?
I think I'll stick with 1.1.07
Another thing, how does balancing work? Cell 8 has a high voltage rise, I put it in balance mode for a long time, but I don't notice much difference.
What is the correct way to do it?
speedict   10 kW
Post by speedict » Jul 30 2020 7:50am
AlexTM wrote:
Jul 30 2020 4:59am
let focus firmware upgrade issues first, what's the issues on firmware upgrade ?
Danny
Speedict Technology - Drive . The . Future http://www.speedict.com | http://www.facebook.com/speedict.technology
AlexTM   1 mW
Post by AlexTM » Jul 30 2020 8:18am
Hello, I follow the steps of the PDF.
I copy 48KB .Bin file into the firmware directory.
I load it from the application, and it gives me those screens that I put.
It looks like it disconnected from the bluetooth, but I'm not sure.
I have tried many times and it always gives me that failure.
speedict   10 kW
Post by speedict » Jul 30 2020 8:27am
AlexTM wrote:
Jul 30 2020 8:18am
please remove the .bin from firmware directory and download this version instead
1.1.6
https://drive.google.com/file/d/1GC_v3R ... sp=sharing
Danny
AlexTM   1 mW
Post by AlexTM » Jul 31 2020 4:53am
Hi Danny, thanks for your help.
I have tried 1.1.6 and I cannot get it either.
I have tried it with 3 different devices that I have at home and with none I get it.
Can it be wired directly?
AlexTM   1 mW
Post by AlexTM » Jul 31 2020 5:00am
Another option I can think of is to remove it from the plastic case with which it is lined, in case the bluetooht signal is too weak
I edit:
I removed the plastic cover and I have tried again and nothing.
The strange thing is that I download the file from the post before the link that you put me, that does not work.
I did the usual procedure and there if I saw a load percentage until I finished inserting the file, the rare thing is that I got a version that does not correspond to the name.
And by placing the 15 cells, it shows that something is charged, right?
speedict   10 kW
Post by speedict » Jul 31 2020 6:56am
AlexTM wrote:
Jul 31 2020 5:00am
do you mean 1.1.17 or 1.1.16 ?
AlexTM wrote:
Jul 31 2020 5:00am
load percentage ? do you mean this ?
Screen Shot 2020-07-31 at 7.52.49 PM.png (22.92 KiB) Viewed 251 times
AlexTM wrote:
Jul 31 2020 5:00am
can you explain more ?
Danny
AlexTM   1 mW
Post by AlexTM » Jul 31 2020 7:55am
speedict wrote:
Jul 31 2020 6:56am
AlexTM wrote:
Jul 31 2020 5:00am
AlexTM wrote:
Jul 31 2020 5:00am
AlexTM wrote:
Jul 31 2020 5:00am
Danny
Yes, I mean 117, the first and only time I managed to load was 117, and that screen came out indicating that the new version is being recorded.
But the version that was recorded is not 117, it is 01.01.07 from 2020-01-15 my version was earlier, and when this was loaded, 01.01.07 erased all my previous configuration and placed 15 cells.
I ask, could it be that the file I downloaded was not 117?
is a silly question.
Sorry for my English
AlexTM   1 mW
Post by AlexTM » Jul 31 2020 8:00am
speedict wrote:
Jul 29 2020 5:20am
AlexTM wrote:
Jul 29 2020 5:15am
Hello, my name is Alex, I have had the Neptune 15 for almost a year, I bought it to get an extension of the Turbo levo.
Due to personal problems I could not finish it until now, and the Neptune15 seems fantastic to me.
The firmware I have is 01.00.10, but I see that there are new updates, but they do not appear on my device, how can I update to the latest version?
please download both firmware and upgrade guide for the latest firmware upgrade.
1.1.7
https://drive.google.com/open?id=1gFDga ... GCwp3rj2sV
firmware upgrade guide
https://drive.google.com/open?id=1IDJO2 ... udQIdmDqcV
AlexTM wrote:
Jul 29 2020 5:15am
Another thing, see if you can help me, I use the Blevo program to control this with the Turbo levo, but the Neptune's Bluetooth does not recognize me, so there are parameters that I cannot control, do you know if someone has got?
Regards.
sorry about that since Neptune can work and communicate directly with Android device.
Danny
this link does not work, it gives download error, I downloaded it from the previous post
speedict   10 kW
Post by speedict » Jul 31 2020 8:05am
AlexTM wrote:
Jul 31 2020 8:00am
can you tell me your purchase date and name on transaction ? we would like to check what's the default firmware on your Neptune 15
Danny
AlexTM   1 mW
Post by AlexTM » Jul 31 2020 8:10am
OK, I look it up and tell it to you.
Thank you
speedict   10 kW
Post by speedict » Jul 31 2020 8:27am
AlexTM wrote:
Jul 31 2020 8:10am
Thank you
checked your current firmware is updated, the latest version is 1.1.7 not 1.1.17 (it's typo when create for beta user last time).
we will amend its version number and description, sorry about that.
we can focus on your charging issues now.
Danny
AlexTM   1 mW
Post by AlexTM » Jul 31 2020 9:06am
Perfect, so I'm in the latest version, fantastic
My question is:
What is the ideal way to balance the cells, in my specific case I have cell number 8 that is much ahead of the others, and I want to balance it, I enter the loading screen, I give it to balance and see how it works on the cells, I leave it for a long time but I don't see that I can balance them.
Is it necessary to change the value of cell balance delta, or configure it in some way to make balancing more effective?
speedict   10 kW
Post by speedict » Jul 31 2020 9:34am
AlexTM wrote:
Jul 31 2020 9:06am
My question is:
if you want to balance only, you can connect only balance wire, not need to connect main discharge wire or connect with charger.
1. then go to DATAVIEW page, check your current CELL DELTA value e.g. 0.35v
2. then go to OPTION -> CHARGE -> OPTION, change the CELL BALANCE DELTA (MV) e.g. 100
3. click on the top right corner x icon back to CHARGE page, press the BALANCE button, you can start BALANCE only job, just leave it over-night, or stop and check after 2 hours, you should see the CELL DELTA value decrease.
Danny
AlexTM   1 mW
Post by AlexTM » Jul 31 2020 9:38am
Thank you very much Danny, that's it.
A pleasure to deal with you.
speedict   10 kW
Post by speedict » Jul 31 2020 9:41am
AlexTM wrote:
Jul 31 2020 9:38am
Don't hesitate to contact us again :)
Your application is 10 cells ? what's your speed controller model ? VESC for skateboard ?
Danny
AlexTM   1 mW
Post by AlexTM » Jul 31 2020 9:45am
It is an extender for a Turbo levo, specialized.
with 21700 5000mah cells
10s2p
speedict   10 kW
Post by speedict » Jul 31 2020 9:48am
AlexTM wrote:
Jul 31 2020 9:45am
10s2p
OK thx for your info.
Danny
AlexTM   1 mW
Post by AlexTM » Sep 14 2020 6:17am
Hello, I need help, I have changed my phone for a more modern one, the model is Xiaomi Mi note 10 pro, and I cannot link the neptune 15 via bluetooth, I have tried all kinds of configurations but there is no way, my wife has the Xiaomi redmi note 9s and i can't link it either.
The Mi note 10 pro has Android 10, and the Redmi note 9s Andoid 9
I can only link with Bluetooth with the Xiaomi redmi note 4 and with the Xiaomi Mi5, with these there is no problem.
Is it because of the version of Android that is more modern?
Any suggestion?
speedict   10 kW
Post by speedict » Sep 14 2020 8:10am
AlexTM wrote:
Sep 14 2020 6:17am
Any suggestion?
We have Android 10 device without issues, look like both XIAOMI with version 9 and version 10 has bluetooth stack problem, what's redmi note 4 and Mi5's Android version ?
Danny
AlexTM   1 mW
Post by AlexTM » Sep 15 2020 9:06am
Hello, I already found the solution, it is incredible but it is true, in version 9/10 of android you have to have the bluetooth activated and also the GPS, amazing, I discovered it when installing an application to pair the bluetooth, and it asked me to connect the GPS.
I did the test and managed to connect my device and my wife's too.
well, fixed.
speedict   10 kW
Post by speedict » Sep 15 2020 9:22am
AlexTM wrote:
Sep 15 2020 9:06am
well, fixed.
Hi Alex,
thanks for your information.
on version 9 and 10, it's requested LOCATION permission on first time running Neptune client, if you're ignored it then you need to grand it manually, do you remember XIAOMI has prompted for permission request ?
Danny
IMAGE 2020-09.jpg (27.5 KiB) Viewed 88 times
AlexTM   1 mW
Post by AlexTM » Sep 16 2020 4:31am
Yes, I had the uvication permission activated, and it only works if I activate the GPS.
