I need help refining my battery charging procedure on a light weight prototype e-motorcycle I made. It is similar in scale to the LMX and Sur-Ron. Like my fenders?
My battery is essentially 5 "Mighty Mini-Cubes" from Luna Cycle wired in parallel. Each Mighty Mini has its own built in BMS and I've tied them together using XT 90 connectors. These are 14S, 2P units and here's a link for all the data:
https://lunacycle.com/52v-mighty-mini-c ... -3-pounds/
To charge the Mighty Minis I've been disconnecting them from one another and individually charging all five batteries before reconnecting. What a pain! I want to safely speed up my charging process while not harming the batteries or myself. Clearly this battery set up is the result of me getting impatient and just ordering something that had built in BMS for safety, good power output and could be made fit in my frame... this is not the way one would do a production bike. Regardless, I want to make the most of what I have. To figure this out I need help from someone with far more knowledge than me about batteries. My main questions are:
1. Can I just leave them connected together in parallel and plug my two chargers into two of the five charging ports and let all five charge up that way? Safely? I mean if they are all connected wont they all just charge up or will the battery management systems prevent that? I'm using the Luna Cycle smart charger that is recommended for this battery. If I can just leave them connected I might even buy another charger so that I can get the recharge done in two cycles instead of three..
2. If I must continue to disconnect them and then charge individuals can I just disconnect the positive or negative (but not both) terminals or must I completely disconnect each battery from the pack?
By the way, maybe this is the wrong section on the forum for this question but I wonder if anyone can help me with throttle response issues. I've adjusted the thing as much as possible and it still feels kind of like an on off switch. I let a wheelie master friend of mine have a go. He can wheelie anything for days and is a master of the downhill slow wheelie but he confirmed my throttle is just not what it needs to be. It's too on/off. No subtle control. Any ideas? I have a Kelly KEB7280 controller. Did I pick a bad controller?
Thank you,
Stefan
