Warning
This has been made by a newbie so incorrect info might be shown, don't assume the info below is right. If you have question post a reply and wait for an expert to assist.
Votol Company
Votol Controllers procued by SiAecosys. SiAecosys is an union of manufactories in electric driving industry, and belongs to Taizhou SIA Trading Co., Ltd that set from QS Factory in 2013year. Currently, more than 80 top factories join SiAecosys, and they are willing to provide customized products and service for international customers who has passion in e-scooter/tricycle/car industry.
SiAecosys focus on organizing member factories together to customize specific e-driving system solution and products for different requirements from customers in the world. Nowadays, SiAecosys has more than 5000 customers from the world and more than 40 customers send inquiry every day.
SiAecosys has sale department, Technology department, Quality inspection department, general accounting department, purchase department and after-sale service department.
Votol Controller types
Table of the different models, voltages, rated current, max current, peak power, dimensions, weight, etc
EM100
- Voltage: 48V-72V (max. 90V).
- Battery Current: 100A (maximum).
- Phase Current: 330A (maximum).
- Flux Weakening Ratio: 200%.
EM150
- Battery Current: 150A (peak).
- Phase Current: 470A (peak).
EM150S
EM150SP
EM200
- Battery Current: 200A (peak).
- Phase Current: 550A (peak).
- Max. Efficiency: more than 92%
- Flux Weakening Ratio: 300% max.
Main Options
- Regeneration
- Regeneration means recovering energy from the motor and putting it back inside the battery. This increases range and can reduce brake wear. It's also used in electric cars and often referred to as 'one pedal driving'.
- Over & under voltage cut off
- A commonly seen option which cuts of the power when the voltage from the battery is higher or lower than certain parameter. This option is made to protect the controller and yourself
- Throttle voltages & responses
- Flux weaking
- An option to increase the topspeed of the motor. The downside is that efficiency will drop and heat will increase to use with caution
- Three speed settings
- An option that enable you to use three different speed settings. This can be done with a switch on the steering wheel for example. This is a great option if you just want to cruise instead of going mental or when someelse wants to try riding for the first time and to let them getting used to the electric power and handling
- Cruise control
- An option to maintain your speed without providing active throttle input
- Reverse
- An option to drive in reverse. This might be handy when you want to back out of a tight spot
Software
- Manuels can be found here: http://www.siaecosys.com/list/?classid=102
- Latest software can be downloaded here:
- How to install the drivers and software can be found here:
- Wiring Diagrams can be found here
Start up
Minimum requirements in order to turn on the controller:
- Elock connected to battery +
Trouble Shooting
Make sure you check the pole pairs and the angle hall settings. Both of these settings need to be matched with the specific motor you are using. Below a table of some more frequently used motors and their corresponding settings
Table: Motor | Pole Pairs | Hall Angle
- Speed is not shown (correctly)
- Controller not recognized in Windows
- It can be a hassle to get it working, in short the following checks/steps need to be taken. More details can be found in the "Software" section of this post.
- Make sure you see "blabla" in the Device Manager"
- Select the same port in the Votol software
- Communication exception, no response
Trouble Shooting
Below some Links to some cool builds that use a Votol controller.
Votol vs
There are plenty of other options to choose from.
The main advantages of Votol are:
The main disadvantages compared to most other controllers are:
Usefull Links
Dominio throttle with Votol
