ASI BAC Controllers Europe Vendor
wakko   100 µW
100 µW
Re: ASI BAC Controllers Europe Vendor
Post by wakko » Aug 24 2020 2:51am
EDIT: Martin has replied now. Sent a PM to Martin but not had a reply yet. Is he still active?
jonnydrive   100 W
Post by jonnydrive » Aug 25 2020 1:03pm
Asi Bac 855 just buy from Martin, superfast shipping and serious seller!
Suggested! :bigthumb:
ps. asi requires strong learning curve compared to other controlller (ie. kelly, cyclone, votol) but seems a way better at least as interface and tunable parameters.
I broke kelly 300amp controller simply writing parameters via Bluetooth during motor spin......ASI seems a lot more reliable until you not flash old version parameters in to the controller. If you do that, like I did, you brick the controller!!
okp   100 kW
Post by okp » Sep 06 2020 3:08pm
PM sent ! I'll go BBSHD / EggRider v2 / ASI 855 for my Coast Cycle upgrade Buzzraw
okp   100 kW
Post by okp » Sep 07 2020 4:02pm
Already got a reply from Martin this morning. I'm waiting for his next reply and will be ordering from him.
I confirm so far he's a 5 stars guy to do business with.
wakko   100 µW
100 µW
Post by wakko » Sep 12 2020 10:29am
Some info for anyone thinking of buying an ASI controller. I bought an ASI BAC 855 from martin (no problems at all btw) but I found that the bluetooth module in the controller wasn't appearing in the Bacdoor channel list. After emailing back and forth with Martin and some testing with different phones/tablets it looks like the Bacdoor app doesn't work with Android 10. I have a Samsung 9+ and there seems to be a permissions issue. I've tested it with Android 5.1 and 7.1 and it works in both versions.
john61ct   100 GW
Post by john61ct » Sep 12 2020 4:47pm
For me a non issue! eventually such issues are likely to soon get fixed
Meantime even high quality older Androids can be easily bought for peanuts.
wakko   100 µW
100 µW
Post by wakko » Sep 15 2020 1:40pm
That's true. Certainly no shortage of old phones around.
Tommm   100 kW
Post by Tommm » Sep 15 2020 2:03pm
john61ct wrote:
Sep 12 2020 4:47pm
wakko wrote:
Sep 12 2020 10:29am
Guys listen up.
IF YOU HAVE ANDROID 9 OR NEWER YOU MUST HAVE LOCATION ENABLED IN ADDITION TO BLUETOOTH FOR IT TO FIND DEVICES IN APPS!!
Hertzelz   100 mW
Post by Hertzelz » Sep 16 2020 7:01am
wakko wrote:
Sep 12 2020 10:29am
I have the Sammy Note 10+ with Android 10 and BacDoor does work, but the browsing / saving parameter file doesn't
lqbweb   1 W
Post by lqbweb » Sep 19 2020 8:57am
guys, what is the preferred dashboard interface for this controller? eggrider, apt, or ca v3? Thank you!
jonnydrive   100 W
Post by jonnydrive » Sep 21 2020 11:57am
Hertzelz wrote:
Sep 16 2020 7:01am
wakko wrote:
Sep 12 2020 10:29am
Realme x2 with android 10 works perfectly...
jonnydrive   100 W
Post by jonnydrive » Sep 21 2020 12:04pm
:warn: :warn: :warn: Do not flash 5.x config to new asi as I did. Now I have a fancy brick. :warn: :warn: :warn:
I am trying to have some support form Martin but no luck for now.
Someone know if with the PC ASI Software is possible to un-brick the controller?
thanks
j
wakko   100 µW
100 µW
Post by wakko » Sep 21 2020 1:48pm
I guess there's no harm in trying. You can't brick it more.
wakko   100 µW
100 µW
Post by wakko » Sep 21 2020 1:50pm
Guys listen up.
[/quote]
Doh! Should have konwn to try that. I've now tested it on my Samsung 9+ with location turned on and it works.
john61ct   100 GW
Post by john61ct » Sep 21 2020 5:40pm
lqbweb wrote:guys, what is the preferred dashboard interface for this controller? eggrider, apt, or ca v3? Thank you!
CAv3 is not a dashboard, only external info, has no access to controller data.
Electroenduro   1 µW
Post by Electroenduro » Sep 23 2020 4:09pm
Hello, i need BAC4000 in Russia, do you have it in stock?
Sur-ron 2020
ykrop4ik   10 µW
10 µW
Post by ykrop4ik » Sep 25 2020 6:36am
Cannot do even the hall sensor motor identification.
Surron, bac 8000 version 6.012. The wheel is shacking moves a bit, motor makes weird noise.
Does anyone have a good advise for me?
Hertzelz   100 mW
Post by Hertzelz » Sep 25 2020 4:14pm
jonnydrive wrote:
Sep 21 2020 12:04pm
thanks
j
i already bricked 2x BAC8000 just by clicking on Run on motor calibration, then the bluetooth disconnected and the controller red light is on, but not reachable or response even from pc.
how yours happen?
canarispott   1 µW
Post by canarispott » Sep 28 2020 7:37pm
have sensor pass this controler?
