Exhaust fan on velomobile doubling as propulsion
Things that fly
SaladFish   1 W
Post by SaladFish » Sep 14 2020 6:40pm
If you have a 100w electric exhaust fan at the rear of a velomobile will you get 100w of forward propulsion?
I remember exhaust fans were used in pedal car races before they were banned because the racers were getting an extra 5-6km top speed from their use. They were using rc airplane motors.
I want to know if an exhaust fan could be used as forward propulsion and how efficient it is.
I'm asking in this forum because people here may be familiar with the workings of propellers.
Hillhater   100 GW
Re: Exhaust fan on velomobile doubling as propulsion
Post by Hillhater » Sep 14 2020 7:37pm
I suspect an “exhaust fan” is design optimised for moving air volume quietly and efficiently, and the generation of maximum thrust is not a priority.
If its thrust you want primarily, you would be better off configuring the same power motor with a rpm and propellor purpose designed for maximum thrust at the speeds you will use.
SaladFish   1 W
Post by SaladFish » Sep 15 2020 7:27am
Hillhater wrote:
Sep 14 2020 7:37pm
Yes thrust.
fechter   100 GW
Post by fechter » Sep 15 2020 8:19am
The exhaust velocity has to be much higher than the vehicle speed in order to get any thrust. I don't think the efficiency will be very good compared to driving the wheels. You could use something that looks like an electric ducted fan they use on RC model aircraft and probably get as much as you can get.
topspeed   1 mW
Post by topspeed » Sep 15 2020 10:06am
There may be more to it that meets the eye !
I mean the tail vortices may be reduced by this thrust propellor as well.
Few solar panels/cells could provide 200-300 watts.
e-beach   1 GW
1 GW
Location: Any Los Angeles area beach I am at. Or Santa Monica or possibly the south bay beaches.
Post by e-beach » Sep 15 2020 10:25am
Do a wind tunnel test. Or model it if you can.
. :D :bolt:
Favorite Quotes:
"This is L.A., sugar. There is no 'over the top." Chris Erskine
"At a certain point the entropy wins." Maria Helena Braga
Current Build: ProFlex 757 Expert full suspension. Yescomusa 36v 800w Rear DD, upgraded 10AWG solid core through axle phase wires. 15ah Headway, 1000+ cycles, 80% DOD 30A Tronsung controller.
Past: Trek 4500 Yescomusa 36v 800w front DD.
Liahona, Yescomusa 36v 800w generic front DD.
1992 Trek 800, Yescomusa 800w 36v front DD.
Balmorhea   100 kW
Post by Balmorhea » Sep 15 2020 12:52pm
I doubt you'll get any identifiable amount of thrust from something like that, but you could possibly do some boundary later control, or reduce the low pressure area behind a Kamm tail.
___________
Finish Reconstruction.
Stealth_Chopper   100 mW
Post by Stealth_Chopper » Sep 15 2020 6:37pm
You seem to equate 'fan' and 'propeller', fans are far less efficient than propellers under most conditions.
At equal power: A large diameter propeller will produce more thrust, a fan, less because of the protective duct that surrounds the fan.
Propellers are ancient, like Archimedes Screw, yet efficient.
SaladFish wrote:
Sep 14 2020 6:40pm
Balmorhea   100 kW
Post by Balmorhea » Sep 15 2020 11:18pm
Ducted props avoid vortex losses at the tips.
___________
Post by Stealth_Chopper » Sep 16 2020 10:16pm
So?
& You seem refer to a ducted FAN
Balmorhea wrote:
Sep 15 2020 11:18pm
The propulsive efficiency of a propfan engine is increased by the high bypass ratio achieved using external fan blades. The efficiency boost is maintained even at high speeds because the fan blades are curved like scimitars to prevent shockwave formation on the outer tips of the blades. The increased propulsive efficiencies translate into overall propulsive efficiency gains of as much as 20-25% over turbofans.
Balmorhea   100 kW
Post by Balmorhea » Sep 16 2020 11:23pm
Stealth_Chopper wrote:
Sep 16 2020 10:16pm
So?
Call it what you will. The terminology is more a judgement call about blade aspect ratio than anything. But just like wings, prop blades have tip vortex losses, and just like winglets, propeller ducts can minimize or even eliminate these.
___________
The Toecutter   10 kW
Post by The Toecutter » Sep 17 2020 7:57pm
SaladFish wrote:
Sep 14 2020 6:40pm
The only way that happens is if the blades of the fan are 100% efficient and the motor driving it is 100% efficient. You might get the motor to be around 95% efficient if you are careful in your selection thereof, but the blades are going to run up against the Betz coefficient, which in theory is about 59% efficiency, but in practice, you will be lucky to get 30-40% efficiency.
Then you have to account for any drag of the air being exhausted out and what it runs up against.
You'll be lucky to get 25W of forward thrust from a 100W exhaust fan.
However, the cooling of the rider from said fan may more than make up for it by allowing the rider to sustainably generate more power without overheating, but that isn't something that could be readily modeled because rider physiology and ergonomic needs are so widely variable.
If the goal is to use the fan for rider cooling, a hole and the fan could be placed at the front of the velomobile where the high pressure stagnation point of the airflow will be found, and with proper consideration of airflow in the velomobile, the air could be vented out at the rear of the velomobile, providing effective cooling, while very slightly reducing drag. The Milan SL has a vent in the rear that is functional, and the DF velomobiles have a front air intake at the stagnation point.
