My new stealth type build
Show off your Ebike creation here.
Santacruz   100 W
Post by Santacruz » Aug 05 2020 4:20pm
This is the finished bike I have been building for over a year.
I made all the frame and rear swing arm. (I copied various sections from different Chinese models and improved them - That should balance things out :D )
Modified 3K turbo motor (+Hub sink and statorade), 22s5p 26650 battery pack, 300amp BMS, automatic insulation check / pre-charge, Sabvoton svmc96120.
Side panels are real carbon fibre, controller housing 3D printed in PETG. Oval chain wheel. 19" rear and 26" front wheels. Hyd disc brakes 205mm front, 180mm rear. Floating discs with heat sinks.
I will upload some of the build pics at a later time as there are a lot to sort through.
Skaiwerd   100 W
Re: My new stealth type build
Post by Skaiwerd » Aug 08 2020 6:43pm
I’d trim your seat post. I know it won’t hit as is just looks funny. It’s non stealth with the logos and graphics and color scheme. I know this is a personal preference, just not for me. Otherwise great ride!
Santacruz   100 W
Post by Santacruz » Sep 18 2020 1:00am
Skaiwerd wrote:
Aug 08 2020 6:43pm
Saddle post is a Hyd dropper, so it is not possible to cut it down.
