Solar, wind, hydro and other non-fossil sources of electricity.
John in CR 100 GW
Post
by John in CR » Jul 17 2020 7:27pm
A new friend who want my help building a high powered ebike is also working on a hydroelectric project on his dairy farm that has an electric bill of over $1000/mo. It's up in the mountains at 4,000m of elevation and he has a small river with year-round flow and a whopping 200m of head
. Even with just a 3" pipe he can produce an incredible amount of electricity at the 400gal/hr rate he is planning.
Hopefully he can negotiate a grid tie arrangement where he gets paid for the excess he generates.
john61ct 100 GW
Post
by john61ct » Jul 18 2020 11:32am
very nice!
no spawning fish to accommodate?
Hillhater 100 GW
- Location: Sydney ..(Hilly part !) .. Australia/ Down under !
Post
by Hillhater » Jul 19 2020 12:11am
ES member “craneplaneguy” has reported on his “mini hydro” system for several years. Avery nice to have facility.
Another member ( ? Aussie ? Forget name) has also reported on his DIY mini hydro working with limited head, but continuously outputting 1+kw to a large Pb bank, and also to a experimental “pumped hydro” tank system for storage.
Ideal if you have the land , water, and terrain to enable such a system.
John in CR 100 GW
Post
by John in CR » Jul 21 2020 3:48am
john61ct wrote: ↑Jul 18 2020 11:32am
very nice!
He does have some trout ponds fed with a continuous flow from the river, but no migratory fish to worry about.
999zip999 100 GW
Post
by 999zip999 » Sep 13 2020 3:03pm
What voltage ?
JackFlorey 100 kW
Post
by JackFlorey » Sep 29 2020 1:00pm
John in CR wrote: ↑Jul 17 2020 7:27pm
He should be able to get about 2kW continuous, or about 1300kwhr/month. That should offset about $130 a month at 10 cents/kwhr.
JackFlorey 100 kW
Post
by JackFlorey » Sep 29 2020 1:01pm
999zip999 wrote: ↑Sep 13 2020 3:03pm
What voltage ?
Systems like this often use "wild AC" from generator to rectifier - voltage/frequency determined by RPM and regulated by a MPPT controller.
John in CR 100 GW
Post
by John in CR » Sep 29 2020 10:42pm
JackFlorey wrote: ↑Sep 29 2020 1:00pm
It's been a while since I did the research to confirm his estimate of 6kw continuous as a fairly conservative estimate, but it was more than enough to offset the $1k/mo electric bill for his dairy farm. Note that our 98% green electricity is nationalized, and despite being primarily hydro power, our cost per kwh is almost double your 10 cents. Too bad there's such corruption, because I have pleasant dreams of 2 cents/kwh in the areas supplied by hydro in parts of Canada. If I live long enough to see real global warming, maybe I'll head north to Canada, which would become the new farm belt of the west.
JackFlorey 100 kW
Post
by JackFlorey » Sep 29 2020 11:12pm
John in CR wrote: ↑Sep 29 2020 10:42pm
Hmm. 400 gal/hr is .42 liters per second. Are you sure that's right? That's a pretty small amount of water to run a hydro system with.
John in CR 100 GW
Post
by John in CR » Sep 30 2020 1:13am
JackFlorey wrote: ↑Sep 29 2020 11:12pm
Ah, now I see where I went wrong on the original post. It's 400gpm not per hour. His river and waterfall have real flow, and then we both discounted each thing quite a lot to prove his desired 6kw seemed quite reasonable.
John in CR on Sep 30 2020 8:47pm, edited 1 time in total.
JackFlorey 100 kW
Post
by JackFlorey » Sep 30 2020 3:44pm
John in CR wrote: ↑Sep 30 2020 1:13am
Ah, now I see where I went wrong on the original post. It's 400gpm not per hour. His river and waterfall have real flow, and they we both discounted each thing quite a lot to prove his desired 6kw seemed quite reasonable.
Oh, OK! Definitely agree then.
mu0 1 µW
Post
by mu0 » Feb 21 2021 4:50pm
Genuinely, this is the dream.
Can I ask what country your friend's farm is in?
markz 100 GW
Post
by markz » Feb 28 2021 12:35am
Costa Rica aka "CR" in John in CR is my guess.
Yes, the dream is to own land and to live off the land. However I am not the person to live out in the sticks, I would need to live near a big city even if its out in the country, say 20-40 minute drive to the big city lights. I'd be hesitant to live in a city of a population less then 50 or 75k. But maybe the slow stroll, what I like to call the spanish walk, would be better. Beach would be a must!
mu0 wrote: ↑Feb 21 2021 4:50pm
DogDipstick 10 kW
Post
by DogDipstick » Feb 28 2021 11:19am
Mennonites are building a wheel at the CNC Metal shop we contract. They are good with their plasma cutters, that is for sure.
Lol.....its 25 feet in diameter and gonna do ~20-30RPM on about 1100-1350 Ftlbs of Tq.
Lol at your math, John in CR.
I was very interested, and love these equations. I remember when you post this.
400 GPM yes... 200m head.. 3" pipe...
(Aside : Us or Imperial GPM? Lets assume US;)
200m = 656.168 (Ft)
444.83 GPM = 1 cuFt/Sec
Density is 62.5lbs/Cuft
Pressure available is Head (x) Density of fluid =41,000 Lbs force / square foot
41,000 Lbs force / square foot (x) .89 Cubic foot / sec = (Theoretical work energy available... )
=36,500 Ftlbs / sec.
550 Ftlbs/sec = 1 hp
66.36 horsepower availability that theoretical pipe.
6Kw should not be a problem. lol.
( negating efficiency and whatnot Expect 70-90% with the losses in the pipe ad whaddabing waddabang) )
400USGPM @ 658Ft of head = 50 Theoretical Kw. Realistically ~35Kw NET.
83.1v of Ironhorse XC..
by Chevy
Broke 10 horsies
(..about 85% healed..)..
Waddyamean? You cant tell me how many amperes/Ft.^2 of the plate ?!?!?
1 (pound / second) Horse Power = 338.24 M^2 Kg^2 / Sec^4 (
prove me wrong
(gottenymoem4115thangs?Yall?)
Fabricator @ BSECo. Inc.
markz 100 GW
Post
by markz » Mar 02 2021 5:31pm
Lets assume US
That is always the case.
