Elinx said:It is wise only to calibrate if the range between zero- and max load isn't big enough.Adarsh881 said:.....
So I would like to calibrate the hardware sensor by adjusting the two screws. What should be the no load value when reading of the vlcd5 screen? I'm having the "Tsdz2 open source firmware adapted to vlcd5" installed on my motor. Wiki says about the torque calibration that the no load value should be between 100 and 120, but I think that the value you read from a vlcd5 screen would be different. Is that true? And if so what should be the no load value?
I don't know which values you have now. (ignore the decimal point)
I think the values on the pictures of Chri27.5 are 8bit readings as it was before. (calibrated 250-650 and without calibration 490-620)
Now it are 10bit readings on display. (calculated 100-260 and without calibration calculated 196-248)
A torque range of 160 (10bit) is very good and is a much improvement with the uncalibrated torque range of only 52 (10bit)
A default torque range of 130 to 150 (difference between max and zero load) is a realistic value and don't need hardware calibration.
For v0.20b1 you can insert "ADC range" and "ADC step" (N/digit) with "Advanced torque sensor" setting, if you want to read exact readings on display.
Yes in your case adv. torque adc values 41-140 and adv. cadence value 560 should be fine.Adarsh881 said:.....change the torque sensor to adv. and change the range to 140 instead of 160?....
......step..... gives me in return is 40.3...thats a lot less than 67( actually on the display it said 67.9.. ....
... cadence ... 565 instead of the 505 .....
PeterpDahl said:Since I'm going to install the open Source firmware for the LCD5 in this week, there is one thing that I cannot find a clear answer to.
I live in the EU, so I cannot - legally - use more than 250w and 25kmh. Right, this is where street mode is handy.
However; I cannot find a clear answer as to how to switch between street and offroad? Do i have to go into parameter settings each time to change it - or is there an easier way to change ?
Level 1/eco, push short 2x power/light button.PeterpDahl said:...... how to switch between street and offroad? ..
Elinx said:Level 1/eco, push short 2x power/light button.PeterpDahl said:...... how to switch between street and offroad? ..
The motor will always startup in level 1/eco, so you can change the offroad/streetmode like this:
Power.............. power-power
Elinx said:Yes in your case adv. torque adc values 41-140 and adv. cadence value 560 should be fine.Adarsh881 said:.....change the torque sensor to adv. and change the range to 140 instead of 160?....
You will notice that the support will change, so eventually you must change other level values too.
You must realize this calibration is only needed if you want to read the exact torque value on the display.
Otherwise you don't need it and could do it with the default values.
67 vs 67,9
The readings of the display have a dependency of wheeldiameter setting on display, so a reading 67,9 could have to do with that.
The best accuracy of the display you get if you insert on display-settings the highest wheelsize possible.
This setting is independent of the (right) value you entered in the OSF.
This is what mbrusa (the developer of this OSF version) said about calibrations:
source
G-translate
Calibrations:
"Pedal torque adc step" is not necessary, unless you want to see the exact value of the human power on the display (see manual), leave the default value 67. Someone advised you to use this parameter to increase the assistance, it works but only in Power mode. If you have to increase in all modes, better use "Pedal torque adc range".
"Cadence sensor high percentage" is not essential, put the detected value ..., but leave the advanced cadence mode disabled, I suggest you try it when everything is fine.
"Pedal torque adc range" this is the most important and it is the first to do, start from an intermediate value between that measured 123 and 160, in your case ... then possibly correct more or less. You must check that the assistance is well distributed
on the 4 levels, at the TURBO level it must reach the maximum power (a wattmeter is useful).
Adjustments:
Departure delay: it has already been written that "Start-up assistance without pedaling" must be enabled for an immediate departure and is valid in all modes.
"Assist without pedaling threshold", you set the thrust on the pedals necessary to start the assistance without rotation.
Higher values = less effort, you can try even over 25. Warning this parameter is used only in Power mode and with "Start-up assistance without pedaling" enabled.
"Pedal torque ADC offset adjustment", increases the sensitivity of the torque sensor. Try with values from 5 to 15 or even more if necessary, you will get to the point that a feather on the pedal will be enough to start the engine.
Attention, with too high a value, the motor starts by itself or does not stop when you stop pedaling.
This parameter is used in all modes.
"Motor acceleration", increasing this parameter increases the acceleration of the motor, in the manual there are limits to avoid problems. The original fw gives a blow, not good. If you want to try over the limit, which is 35 for 36V motor and 36V battery, aware of what you do, you can get to the bite too, you can also make the bike wheelie, but then the blue gear says bye bye.
Stop delay: when you change gears to have an immediate stop, you have to stop pedaling for a moment.
By lightening the thrust on the pedals, the motor does not stop, it decreases the speed with a deceleration ramp proportional to the wheel speed. "Motor ramp down additional" only intervenes when the pedals are stopped.
Yes, more accuracy with the torque readings on display. If that is important for you you must calibrate the adc values of the torque sensor.Adarsh881 said:......why Embrusa advises to leave the cadence in standard mode instead of advance mode... I thought the advance mode would give more accuracy?
Also those 4 assist modes I'm curious what they mean. ......
ilu said:Even if you have the option to show the values on, you don't need to wait for them to show, and if you press up or down the value sequence will stop.
vlvuk said:Hello all.
I posted my question in parallel topic but without answer, so I try to ask here.
I have new motor 48V 750W built in December 2019, I ran about 50 km (it was several trips across snow forest) and once I found my motor not working neither from pedals, neither from throttle.
First, I replaced throttle knob to similar one and it started working as it should without problem.
Then I checked Technical parameters and found no response from cadence censor, seems it also dead.
This censor located in controller and has 4 wire: red, black, blue and yellow.
Does anyone know and can explain what kind of hall sensor is it? Usually hall sensors use 3 wire (positive, negative, signal) but as I found in some cases uses 4 wire censors (positive, negative, direction, cadence) - is it our case? I will appreciate for any advice.
I have ordered several different hall censors and will try to fix it - if no success I will order new controller, but it is stupid at least to not try.
Other question - if Torque mode will be working with broken cadence sensor? If yes, I will just change mode.
Thanks to all in advance!
Torque mode should work even with broken cadence sensor, but "Start-up assistance without pedaling" must be enabled and disconnected the speed sensor.barrettrussell said:vlvuk said:...
I am not sure about the cadence relation, however, the hall sensor is a ss41f , and when not working will give you a shutter effect.
Elinx said:Yes, more accuracy with the torque readings on display. If that is important for you you must calibrate the adc values of the torque sensor.Adarsh881 said:......why Embrusa advises to leave the cadence in standard mode instead of advance mode... I thought the advance mode would give more accuracy?
But realize the calibration is only secure till about 30-40kg, because the calibration is lineair with just one value with 20kg.
From about 30kg to max. value this linearity isn't valid anymore.
For a better understanding see the wiki
In all cases you have to adjust the support levels that are best for your use.
Power mode is the most used mode and make use of cadence and torque sensor. The other modes uses one of them.
Some use torque mode for offroad use. Cadence mode will be (temporary) usefull if the torquesensor breaks down.
emtb is a more dynamic mode for offroad use and switch between torquemode and powermode.
You can try all these modes yourself inside level 2 (power/torque/cadence) and level 3 (emtb)
Adarsh881 said:... a few questions about the usage of the vlcd5 display....
Every time I start up the display it takes a few hundred meters of pedaling before the speed is displayed on the screen. Just wondering if that is normal or can I change something in the settings?
I've noticed that the odo correction doesn't function after I'm looking at the data. Any thoughts on that?
I'm curious if there is a way to flash the software without having the extra possibly of changing, or looking at the data from the screen. I'm asking this because I'm building a bike for a friend who is not familiar with computers and it would be good if she could just use the screen in the original stock mode. I'm afraid she might change settings she doesn't want to change etc.
Also any experience on how well this vlcd5 display can handle the rain?
Thanks to all replies in advance!
Explain better I do not understand.slonek said:...
And the second question, is it possible to disable the battery test after changing the mode?
The translation is probably unclear.slonek said:Ok, I understand almost everything
But I am bothered by power assist above 25 km / h and I think the problem may be incorrect switching from street to off-road mode ....
In the configurator at the beginning I have the first maximum speed of 45 km / h and "Start street mode" selected, and in the second, 25 km/h and 250w, "Power limitation on the street" selected.
In the manual, however, I read that the bike starts with the code "E02 - OFFROAD MODE with the default STREET MODE" so it is an off-road mode, but limited by the options "starting street mode" to street mode.
What code in this case, the memory for off-road E02 wheter E04 ?
LEVEL 1 - ECO -> STREET / OFFROAD MODE change of road or off-road mode
and the standard mode of the cadence sensor
or - STREET MODE with the default OFFROAD MODE
E03 - STREET MODE with the default STREET MODE
or - OFFROAD MODE with the default OFFROAD MODE
E04 - STANDARD CADENCE SENSOR MODE
- TORQUE SENSOR CALIBRATION (to be done)
