RootedSuperuser
Can you see anything wrong with this pack build?
Please, critique and make suggestions.
eee291 said:is this your battery or is this a "design" you want to copy?
because if it's the former then what's the point of critiquing it?
RootedSuperuser said:eee291 said:is this your battery or is this a "design" you want to copy?
You have nothing to add, no technical critique or engineering suggestions? .... Your just doing a post count bump for yourself?
Apply cold water to the burned area :lol:eee291 said:I'm not the one posting shoddy built fire hazards online and then asking people for their critique.
Seriously, it's like duct taping my bumper on to the car and then asking people for their "technical critique or engineering suggestions".
goatman said:you gotta watch out for those Albertans
so its a house electrician, correct?
looks like 20s3p of lk 26650?
and did the builder ground the battery to the frame?
Even more so in the center of the can end instead of closer to the side.spinningmagnets said:It is very bad form to solder onto the negative ends of the cells.
Solarsail said:Cells appear to be LiFePO4 32650, for a total of about 750Wh -- which is too little for a trail/mountain bike.
Chalo said:If they're the Battery Hookup 6Ah cells, then he has about 1150 Wh (but also about 8.5kg of cells).
Solarsail said:Chalo said:If they're the Battery Hookup 6Ah cells, then he has about 1150 Wh (but also about 8.5kg of cells).
I don't think a 32650 LiFePO4 cell can deliver 6Ah. If it does, it probably is one of those mislabeled Chinese cells. I have assumed 4Ah per cell. Is the 6Ah cell a brand name like A123? Or one of those Chinese re-labeled ones?
