Show off your Ebike creation here.
trackebike   10 mW
Re: Your Creation's Before & After Pics
Post by trackebike » Sep 19 2020 5:18pm
ZeroEm wrote:
Sep 19 2020 3:55pm
If your controller is in the bag, would find a way to get it out in to the air.
You just gave me a good idea for an ebike saddle bag. A saddle bag where the controller forms the bottom of the bag, with only it's heatsink exposed.
ZeroEm   100 kW
Post by ZeroEm » Sep 19 2020 5:40pm
That would be great. I forget it's not as hot in other parts of the world as down here in South Texas. Heat is always on my mind.
Don't ride as far as I want yet but would like to do a 700C recumbent and keep the weight down. Make it as clean as your build.
abundans cautela non nocet
2019 Performer E-Trike 9w/km
2013 Nissan Leaf S 7 bars 331.5w/KM
Tommy L   100 kW
Post by Tommy L » Sep 20 2020 8:15pm
Framed Alaskan 26”
17” frame
Fat bike
BBSHD 46t (42t Lekkie being shipped)
Lekkie buzz bars 160mm with left crank offset to correct Bafang motor “Q factor”
Micah Tolls BMS 52v 14s 30amp continuous
Tesla Model 3 cells - 0.1mm copper 0.2mm nickel Kwelder
Moosetreks triangle bag
52v nominal 25ah 1.26kw
http://www.rawvelocity.com
- 4th Hoolagan FS Mtn 9C-2810 with 128v nom 9.2ah A123 40S40P(1.2Kw) - Lyen 18Fet 4115 - 77.8kph :)
http://endless-sphere.com/forums/viewto ... =4&t=39480
- 3rd Catrike 700 Bionx PL350 Velo build
http://www.youtube.com/watch?v=rYdnkaAhVtI
- 2nd 150lbs Pusher Trailer
http://www.youtube.com/watch?v=Q1qTc4sjORY
- 1st Sears NS mtn bike - Rigid 10a drill 800rpm - 2 12v AGM - 1000 watt inverter - 600w dimmer for throttle, wicked torque!
48.2mph/77.8kph Club
duzzd   1 µW
Post by duzzd » Oct 01 2020 6:29am
Hello everybody,
I am new here and I believe that this is the right place to introduce myself.
I can see a lot of beautiful bicycles here, I hope you will like mine.
I am from Serbia and I can say that I'm highly inspired by Vintage electric bikes, so I decided to make one of my own.
First, I bought old frame that could be remodeled how I wanted. Then, after a lot of metal work I can present to you my ebike.
Some of the specification are:
- 500w motor
- 48v 10Ah battery
- 26" tires 2.35"
- top speed 35Km/h
- hard tail (front suspension)
- autonomy around 30 kilometers
- hand crafted, hand painted
- alarm inside the box
- key start
- LED lights
thundercamel   1 kW
Post by thundercamel » Oct 01 2020 4:40pm
Very nice work!
My Ebike builds - Existing bikes, affordable motor kits, self built 14s6p batteries - Now with more recumbent!
ZeroEm   100 kW
Post by ZeroEm » Oct 01 2020 4:43pm
Nicely Done!
duzzd   1 µW
Post by duzzd » Oct 03 2020 6:04pm
Thanks :D
Jaded   100 mW
Post by Jaded » Oct 03 2020 6:23pm
duzzd wrote:
Oct 01 2020 6:29am
- 500w motor
- 48v 10Ah battery
- 26" tires 2.35"
- top speed 35Km/h
- key start
- LED lights
Ooh that's sharp, I really like the aesthetic of that bike a lot! Nice build!
karlInSanDiego   10 mW
Post by karlInSanDiego » Oct 23 2020 11:37pm
2002 Greenspeed GLR w/BBS02
Before:
After:
Building GreenSpeed GLR Trike - Bafang 750W Midmount BBS02
andychrist   100 µW
100 µW
Blutus, my dual 500W Bafang hub motor Ecumbent Cargo Bike
Post by andychrist » Nov 28 2020 3:48pm
Can you guess which is Before and which one’s After? ;-)
Bought the RANS Stratus XP XXL on BROL Classifieds, without wheels or seat for a significant reduction on price + shipping.
https://flic.kr/s/aHsmSjMFd4
No PAS, just dual half-twist throttles (and two separate displays!)
Limited the top speed to 12m/20kph because over that I’m either riding level ground or coasting so don’t need assist. With the two 52V 21Ah Luna DireWolf battery packs concealed under the seat, on assist level 1 the range is well over 100 miles fully loaded in hilly terrain and likely around 200 otherwise. Can tow more than 100lbs extra (bike itself + panniers and trailer weigh ~125lbs, I’m about 180 warmly attired) up the steepest grades at 10.9mph, which is about four times faster than I could make it alone (if at all.)
Have lids for the 6-Gallon blue buckets, but first need to drill holes through their sides for the power cables (just picked up the 7/8” 22mm hole saw) then line with Dow insulation board for the winter. And of course gotta tidy up the cables, waiting on more 12AWG stranded copper. Planning to coil up the excess harnesses and conceal with an Xmas wreath (no kidding!) and wrap all the rest of the exposed wiring along chopper bars and around controller boxes in blue tinsel as a festive holiday disguise. :P
Oh, and also building a matching blue Igloo 48Q trailer from a Wikes kit. Local box stores all out of the 1” square profile aluminum tubing I need for this project, so could be a while.
Will post back upon completion.
Thanks for looking!
Climbo42   1 µW
Post by Climbo42 » Jan 10 2021 9:28pm
Image bought this bike about a month ago, striped it down to this. Had an idea to make and all wheel drive bike with lights. Has brake lights, indicators, high beam and some illuminating underlights. Image
e-snail   1 µW
Not quite there yet but...
Post by e-snail » Jan 16 2021 5:22am
  • DIY frame, springer fork and saddle
  • 52V battery
  • BBSHD
  • Nexus-8 (not as hub)
Audisport09   10 W
Post by Audisport09 » Jan 29 2021 2:49pm
Before:
Screen Shot 2020-09-02 at 11.48.27.png (2.2 MiB) Viewed 1491 times
After
https://www.youtube.com/watch?v=_8eurhe ... e=youtu.be
My second COVID lockdown folding bike build. Its comically small.
Folding Steel frame
1000w 16’’ Hub motor
Arctic Hunter Crossbody Bag
Lotus Quick Release Bracket
Turnigy lipo 20ah 12c 18s Battery
Maxed out Sabvoton Controller 200A
chuyskywalker   10 W
Post by chuyskywalker » Feb 02 2021 10:15pm
Audisport09 wrote:
Jan 29 2021 2:49pm
No kidding, lol!
Looks like a blast though :)
Theodore Voltaire   10 GW
10 GW
Post by Theodore Voltaire » Feb 02 2021 10:27pm
I never cared for a bicycle seat. I like this set up a lot better.
Elektrosherpa   100 W
Post by Elektrosherpa » Feb 10 2021 5:09pm
OK, here are my before-after-after-after pics.
This was the original, a folding bike from the 1960s:
I converted it to a "folding mountain bike" in the late 1980s by adding a 5 gear hub and strengthening the frame by some welding.
30 years later I added a suspension fork.
10 years later I added the front hub motor (350W) and a 36V/15Ah battery.
First attempt-battery+controller on a rear rack:
photo_2020-07-24_19-05-35 (2).jpg (348.16 KiB) Viewed 1316 times
Final state (battery+controller in the middle section):
Stealth_Chopper   100 W
Post by Stealth_Chopper » Feb 10 2021 5:34pm
Bravo,
I can tell you like it!
Me too!
moonkagliwicee   10 mW
Post by moonkagliwicee » Mar 11 2021 2:06pm
Evspark lite 60v 105A
TDB   100 W
Post by TDB » Mar 15 2021 12:46am
Before:
Kinda... Over time I replaced a lot of parts.
New Ti Frame:
Now the only original parts from the Bianchi are the brake/shift levers. When I get a set of levers I'll put that bike back together.
After:
My commuter...
Oil cooled Bafang G311 standard wind in a 20" wheel, Baserunner, 2x 52V 24Ah EM3EV batteries (+Satiator), Cycle Analyst. Pedal first with PAS ring (no PAS), minimum speed of 8kph and inline brake cut-offs.
Keeping it legal for this part of the world... 200W maximum (240W electrical). Hard limit in the controller.
HrKlev   100 W
Post by HrKlev » Mar 16 2021 6:09pm
Before:
After:
Hubdrive as middrive, with torque sensing EMTB build: viewtopic.php?f=6&t=107622
6x6 conversion: viewtopic.php?f=34&t=109567
10 GW
Post by Theodore Voltaire » Mar 18 2021 10:10am
HrKlev, that's a nice clean look. Very good attention to detail.
Audisport09   10 W
Post by Audisport09 » Mar 18 2021 11:38am
chuyskywalker wrote:
Feb 02 2021 10:15pm
Audisport09 wrote:
Jan 29 2021 2:49pm
No kidding, lol!
It is, fitted 16'' tyre. Feel more stable at speed now
silvocross   100 W
Post by silvocross » Mar 26 2021 1:47am
Here the final results of my enduro build starting from a Specialized Enduro EVO:
Motor: TSDZ2
Battery: 12S3P 21700 --> 650Wh
BR
Silvio
http://www.progettosilvio.com
If the facts don't fit the theory, change the facts
[A. Einstein]
Dward05   1 µW
Post by Dward05 » Apr 02 2021 9:43am
Sun Baja Cruz7 steel frame 3.5 “ tires
Added BBSHD 48v 13.5 ah battery and rear rack
Bike took the 100 mm BBSHD very nicely, good chainline, motor centered in frame. No headaches to the install process, feels incredibly solid on the road. Mainly used to ride around local beach areas with my son in a kids seat that attaches to the front stem or both my kids love riding in the tow behind kids trailer
This is the first Ebike I’ve put together, actually, first ebike ive ever rode for that matter. Within the first few pedal strokes I was grinning ear to ear like a madman, totally hooked
Dward05   1 µW
Post by Dward05 » Apr 03 2021 11:34am
Motobecane Hal Boost Eagle 27
I just got into mountain biking last year. My knees aren’t so good so the option of an electric motor made it possible. I paid $1699 from bikesdirect. Seemed like a decent price.
[attachment=1]1D7CB75A-9B53-43E8-B4DD-41641442C8C6.jpeg[/attachment
I added the 100 mm BBSHD w/42t chainring and 52v 12ah battery. 27.5x3.00 tires
The bike rides very well off road,it works great in all 12 gears. In highest gear I can pedal comfortable up near 30 mph.
Only 2 things that bother me are the battery not fitting within the triangle and the motor hanging a little low. This thing has been insanely fun to ride. And no, it looks close but, the tire doesn’t hit the battery when the fork is compressed.
