List of small hatchback cars
Re: List of small hatchback cars
All good suggestions. Except not too sure about "rev the engine".LeftieBiker wrote: ↑Feb 08 2021 7:38pmYou could have a failing starting motor, or bad/dirty connections in the starter circuit. Check the tightness of the connections at the starter, solenoid if it's not mounted right on the starter, and the battery ground. I know you have good battery voltage, but here is a good routine to follow when shutting the car off. (I would try to disable whatever setting runs the lights after the car is off.)
* Turn off heater blower
* Turn off stereo if it's aftermarket.
* Turn off headlights.
* Gently press the gas pedal to slightly rev the engine to about 2-3,000 RPM for 10-20 seconds.
* Let it drop back to idle, then immediately shut the engine off.
This will counter the tendency of cars with small engines to drain the battery slightly at shutoff.
As to turning the headlights off. That would require rewiring my brain.
Re: (I would try to disable whatever setting runs the lights after the car is off.)I leave the headlight switch in the auto position. Got a plastic bottle cap on the photocell so lights are always on when driving. Remembering to turn lights off and on is more then my brain can handle.
Believe me. I have tried. Been reading the owners manual for days. More expensive models have a Multi-Information Display. Mine just has a radio.
I copy:
Headlight Auto OFF Timer
Changes the length of time the exterior lights stay
on after you close the driver’s door.
60sec/30sec/15sec*1/0sec
Need the Multi-Information Display to change those settings. Could buy that Multi-Information Display part and who knows what else and rewire the dashboard.
Also wondering about cutting a wire to stop the headlights from coming on when I open the drivers door.
Took the battery to https://shop.advanceautoparts.com/ Says 340 CCA on the battery. Tester said 295 CCA and 13.06V
Put battery back in car. Should have wiggled the battery terminals before removing battery. They might have been loose but I am not sure. There was no visible corrosion.
Cleaned battery posts and terminals with a green scrubby and little wire brush. Put em back together with Vaseline all over. Hopefully that was the problem. Will also try prayer.
- LeftieBiker 100 kW
2000 to 3000 RPM isn't going to hurt it, or even make much noise. You do it to bring the alternator speed up into its optimum range, to charge the battery a bit before shutting the car off. Just remember to let it drop to idle before turning it off, or you may dump some raw gas into the catalytic converter.All good suggestions. Except not too sure about "rev the engine".
2018 Nissan Leaf SL with Pro Pilot
2009 Vectrix VX-1 Maxi Scooter W/ 18 Leaf modules
2018 Magnum Metro with noisy motor
2019 GreenBike folder
2019 3 wheel 36 volt scooter
How safe are small hatchback cars?
https://cars.usnews.com/cars-trucks/safest-small-cars
However, I'd take into consideration the build quality and resale value, only stick to Toyota, Nissan, Honda, and their equivalent high-end brands if they even have "small" cars to begin with Infinite (Nissan), Acura (Honda), Lexus (Toyota).
Because the lesser quality brands have cheap production methods with failure prone components. Why waste your money?
If your going to be buying a used car then by all means who cares what the vehicle looks like because its already going to be a late-late model, but why should paint be peeling off a vehicle that is 10 years old? Why should transmissions fail at 100k? Why buy a new Chevrolet for $20k when you can buy a Toyota for $28k. The difference of $8k is nothing. And if it is something then maybe you cant afford that car, maybe you should look for a 5 year old vehicle, and perhaps maybe not a domestic, maybe a Toyota, Honda or Nissan and maybe then you'd still have to go back to 8 or 10 year old vehicle.
Oh Markz,
Think you might have responded to a spammer? What spammer's do is reply to random posts on forums. Then latter when they hope no one is looking, they edit their post with a link to whatever they selling.
Links make the search engines rank them higher to get to the first page of results.
Links like this.
Endless Sphere - Index page
Links like this.
- Dauntless 100 GW
I suggest on top of that to stick to cars with cheap parts. I don't know today, but historically Honda's are expensive while the Mazda's are cheap. On top of that if the model sells better, there's more likely to remain an ongoing parts depot if the brakes are changed, etc. And a good aftermarket. It's easier to get aftermarket parts for the Ford Mustang than to get OEM.
- Arthur C. Clarke
- Arthur C. Clarke
I kind of had that feeling, but I decided to rant about what I had to say any ways.
It kind of bugs me to see the defects in various vehicles that are 8+ years old. Most build them to last days past the warranty period.
Paint flaking off is a common failure.
Recently these daze I have been looking at crash tests on youtube.
It is very interesting to see the wide variety of safety even amongst the imports. The one that sticks out is the Toyota Sienna minivan which was a horrible crash envelope.
I wouldnt be to enthusiastic about driving a small car, or even a mid size car when most vehicles on the road are big trucks and suv's. That is especially so with older small/mid cars with their lesser then ideal crash quality aspects. Newer stuff has the better technology.
Cheap parts is a good, but also its good to have lots of space inside the engine compartment. You have to take off less stuff when replacing an alternator or thermostat. Some vehicles its very compact engine compartment, having to take out half the stuff just to replace simple parts. I always thought Kia's and Hyundai's were decent quality, I know they made heeps and bounds better quality then 10 years ago. There is a guy on youtube called Scotty, unique character, mechanic. Talks about how you should stay away from Hyundis. But if you had $30k to lease, finance or buy, then I'd say look at Toy's or Hon's or Nissans, rather then a Chevrolet, even if you have to buy those imports used. But if I have $5k to spend then buy whatever is mechanically sound. Don't take the dealerships word that its been inspected, and most importantly dont take the sellers word that somethings been done without receipt proof.
marty wrote: ↑Feb 11 2021 7:43amOh Markz,
Dauntless wrote: ↑Feb 11 2021 4:00pmI suggest on top of that to stick to cars with cheap parts. I don't know today, but historically Honda's are expensive while the Mazda's are cheap. On top of that if the model sells better, there's more likely to remain an ongoing parts depot if the brakes are changed, etc. And a good aftermarket. It's easier to get aftermarket parts for the Ford Mustang than to get OEM.
Forgot to say - Checked water level in battery. [Yes I know its not water in there. WEAR SAFETY GLASSES] Water was about 1/4 inch above what ever is inside the battery. Think water level is good.
Been driving. Me and Henry have a pretty good relationship. Who is Henry? Honda Fit named Henry Fit. Me and Henry listen to each other. Usually starter sounds happy. Car is not fixed
EricTheCarGuy explain this better then I can.
Are there headlight lamps/bulbs that use ultra-low wattage but put out lots of lumens?
Compare LED house lamp lights to old school 60w incandescent bulbs, tbh I prefer the old school bulbs and dont care for the money savings on the electricity.
- Dauntless 100 GW
- Arthur C. Clarke
- Arthur C. Clarke
Those sound expensive. For those that want to be cool with blue'ish headlight beams, would be the same ones to install a rear wing or lower a vehicle.
I have an interesting efficiency hack.
Some companies make teflon based lubricants meant to be used in automotive oil, power steering fluid, gear boxes, etc.
This can produce some solid proven gains in efficiency and engine life. Transmissions with this additive are know to run significantly cooler, indicating a drastic reduction in friction.
Considering how absolutely nasty Teflon is, i wouldn't want to use it in my engine oil for sure, as i don't know of a proper way to dispose it; but perhaps it could make it's way into the used oil supply chain, and produce better fuel economy for someone buying cheap oil? i don't know.
However, the fluid replacement interval for a transmission is 100,000 miles, so a half quart of Teflon being discharged from a car twice over it's life is not much of an environmental toll.
Might be worth a horsepower or two.. and a small gain in MPG.. which matters in a car like mine that has 103 horsepower, lol.
My first major build: 1.6kW 8T MAC motor on a Trek 4500 MTB.
Monster MTB: Leafmotor 1500w @ 4kW on a Turner O2 full suspension.
The monster scooter: Heavy duty Cannondale semi recumbent - under construction.
Blue Dream: Maxaraya FS semi recumbent and high efficiency mid-drive - under construction.
HID lights are cool and can have a fantastic light output/tone. They don't have to be done all ricer-like, and tend to use less power.
In fact as we speak, i'm basking in one that's oriented towards producing UV rays.
The output is something like 2 times greater per watt versus an average incandescent.
Could drop ~50 watts continuous off your alternator load and free up a single MP ( monkey power ).
- Dauntless 100 GW
Ever heard of Slick 50? Teflon additives in the engine have never made a good reputation. And I understand the government has cracked down on claims that it's a good thing. But Slick 50 is still in business, so I don't know what to say.
https://www.latimes.com/archives/la-xpm ... story.html
https://www.fluoramics.com/wp-content/u ... _52-54.pdf
- Arthur C. Clarke
- Arthur C. Clarke
What do the professional engine builders have to say about additives and teflon?
I watch a transmission shop on youtube who tear down lots of transmissions. One video showed that whatever additives the customer added, extremely damaged the seals and gaskets. The shop could not tell the viewers which additives were used but added whatever the additive was, stunk real bad. Every seal ended up being oversized.
Channel name was Precision Transmissions out of Amarillo, Tx
https://www.youtube.com/c/PrecisionTransmission/videos
Headlights on with ignition
My goal here is to have headlights and parking lights come on when key is in run position. That it that's all. All lights on all the time for safety.marty wrote: ↑Feb 14 2021 9:39amHaving headlights come on because I am too stupid to turn headlight switch to the off position does not help. Headlights come on when opening the drivers door and exiting car. Headlights come on when I press the button on the key to open the doors.
Really really want to disable this 15 second headlight timer. 15 seconds is what I think the headlight delay timer is set for. Should measure it.
Think that having headlights and parking lights come on when car is off is not doing anything good with battery.
Preliminary plan.
CUT BLK B10
CONNECT TO LT GRN M3
Looks like the MICU Multiplex Integrated Control Unit is what I think MICU stands for. This contraption is doing all the thinking as to when the headlights come on.
Thanks to someone named marty we can all look at wire diagrams and repair information here.
2019 Honda Fit. Wiring diagrams
HEADLIGHT SWITCH
0) OFF
1) PARK
2) AUTO
3) HEAD
Wondering why nothing is connected to ● 2
If I am comprehending wire diagrams correctly? MICU decides when the headlights and parking lights should be allowed to come on. BLACK wire.
LT GRN at connector M3 is hot when ignition key is in ON position.
Would ya all like a fuse in the black wire? 10A?
I've looked extensively into this and not found any fatal flaws with using PTFE other than the environmental considerations.
It was interesting to read tufoil's website. They are more specific about the properties of their additives than any other manufacturer i've seen.
Liqui-moly from ceratec seems more environmentally friendly, but doesn't appear to deliver notable gains in many tests i've seen.
Re: Headlights on with ignition
CORRECTION BLK B10 wire. Copy from:marty wrote: ↑Feb 18 2021 11:13amMy goal here is to have headlights and parking lights come on when key is in run position. That it that's all. All lights on all the time for safety.marty wrote: ↑Feb 14 2021 9:39amHaving headlights come on because I am too stupid to turn headlight switch to the off position does not help. Headlights come on when opening the drivers door and exiting car. Headlights come on when I press the button on the key to open the doors.
Preliminary plan.
CUT BLK B10
HEADLIGHT SWITCH
0) OFF
1) PARK
2) AUTO
3) HEAD
2015-19 ELECTRICAL Electrical System - Testing & Troubleshooting - Fit
COMBI SW GND (LT)
Ground for combination switch
Less than 0.2V at all times
It's a ground. That explains why it's black. Going to need a relay.
Will it smoke?
I have come to the conclusion that I have no idea what I am doing when it comes to electricity. This Multiplex Integrated Control Unit MICU is not helping anything. This will not stop me from completing this project! Headlights on with ignition. Lets continue. Disregard all past posts. Think I was being stupid. Controlling the - input on light switch is what I did on my last car. 2003, electricity was simpler back then.
AUTOMATIC LIGHTING CONTROL UNIT-SENSOR
This is a photocell in the center at top of dashboard below the windshield. I keep a bottle cap on it so lights stay on all the time with the combo headlight switch in the AUTO position. Problem is that with light in ON mode, headlights and parking lights come on when I press button on key to open the door. Headlights also come on when you open drivers door when car is off. Think that all these lights are draining the battery.
Yes I know that the solution to this issue is to simply turn the lights off. So then how do I remember to turn them on?
Take a look. how does a photocell work ?
After 1 minute of study, I would say more light makes more volts.
PUR / Purple wire, Terminal 2, Terminal name TSUN, What the frock does TSUN stand for? The SUN is that big hot thing in the sky. It makes light.
PUR / Purple wire 0.2V when its dark. 4.9V in bright light. Use a relay. If ya been hanging out at:
https://www.the12volt.com/relays/relaydiagrams.html
Ya familiar with these relays. Think they were originally used in Chrysler? Cut the Purple wire. Using relay, Wire it so when ignition is in RUN position, Purple wire gets cut. Where does this Purple wire go? Not seeing it in all the drawings? To the unknown? I need a picture. OK here goes a picture. Will it smoke? Will this work?
After thinking about this? If I thinking correctly? At night things will be exactly as they are now.
- Dauntless 100 GW
The question is of efficacy. I remember it used to be something like 50 times the price of a quart of oil. And nobody can prove it actually DOES anything.
- Arthur C. Clarke
- Arthur C. Clarke
They have proven that these fluids work actually. The biggest indicator is significantly lowered heat in all the tests in gearboxes. And in the case of the transmission, a ~$30 bottle every 100,000 miles which provides even a 1% gain in fuel economy over time is very economical.
Most importantly, PTFE reduces friction in cold conditions, so it will have a huge impact when the car is cold. This reportedly has a big impact in transmission longevity.
Drivetrain losses in a car are in the 15% range. The transmission is probably ~10% of that loss. So the transmission is a sizeable target.
