stancecoke
- Joined
- Aug 2, 2017
- Messages
- 1,808
sylvain_wm said:I don't know why,
have you checked the stability of the 5V rail? We had often problems with unexpected controller behaviour, when the current on the 5V rail was to high and the voltage dropped. (don't connect a BT-Module to the 5V rail for example, use an extra DC/DC converter)
If the throttle reading is OK, you should try, if uint32_current_target changes, if you twist the throttle.
regards
stancecoke
Edit:
@sdobbie: sylvain_wm provides senseful logging data, so I can help to find the problem. You only say "Mimimi ... doesn't work" and spread around in several parallel threads that the firmware sucks....
