Newb 57 years old here and looking to convert my Fat Bike with 100mm BB.
I ride all year round not very far from my home, never over 15 km's in summer in the city (lot's of stop and go) and less than 7 km's in winter (in a park, single trail ridding on snow, mostly flat terrains, no hills).
I'm looking for a part time assist motor when in need, like coming off from a dead stop and/or going thru deep snow. Top speed is not a factor, torque is.
Since I have a small knee problem, I know that Fat Bikes have already a bad Q Factor and that does not help my knee problem but hey, I love riding my Fat Bike!
That's why I'm looking for a Mid Drive that would not add to the Q Factor of my bike.
Any suggestion?
Mid Drives kits suggestions which will not affect the Q Factor?
Re: Mid Drives kits suggestions which will not affect the Q Factor?
For a 68mm BB shell the square taper axle is 112 mm long and this translates to a crank arm separation of 155mm which is about 20 mm to short to fit a Cyclone 3K (motor & axle end). See photo.
Options for mid drive kit with no change in Q-factor would be:
1) find a kit that the motor & pulley of the kit fits in less space than 155mm
2). with modification one could move the motor within the triangle beyond the crank arm rotation space.
You have 32mm BB shell length longer than a 68mm shell. I find you need about 20 mm beyond a 68 mm BB shell making for 88mm to fit a Cyclone 3K.
Adding a Cyclone 3K to a fat bike with an BB axel length of 100mm fitted properly would preserve your Q-FACTOR if you have normal bowed outward pedals cranks.
You may have trouble finding/adjusting the specific axle length & bearing locations to both add kit sprockets and preserve Q.
