bzhwindtalker
You may want to check if halls are fine under the debug menus, there are individual hall status.
Do another auto setup with the battery full. I’ve had a couple of mis attempts with auto setup. The battery was at 75%. At 100% it worked correctly. Also make sure your best config is loaded before starting.Cowardlyduck said:Thanks for chiming in!bzhwindtalker said:Unfortunately not possible for streel legal ones due to the homologation, only 14-118T is possible.
However we are also testing polychain GT carbon for hopefully longer life.
Best regards, Adam
Ok, fair enough on the homologation.
I still have one 15T left if anyone wants it...after that I guess it will still be possible to get them made as one off's, but that won't be cheap!
I am interested in the carbon belt. Let us know when they are available for ordering!
Something that's come up for me recently is my motor seems to be stuttering under heavy load. I vaguely recall this being an issue for someone else previously, but can't recall the solution. It only stutters briefly once or twice during acceleration. I've played around with the acceleration limits, battery lvc, and a few other settings, but can't seem to fix it.
I tried running another motor auto setup, but that just resulted in the whole motor no longer working, so I reverted. Any ideas?
Cheers
Best regards, Adam
i already order 3 polychain carbon belt for cheap price in usa 1 guy sel out the belts in his stock need to go away, it is not the same belt then ore friend have (poly chain carbon v is the old generation , i order the newer generation of this carbon belt , lucky to buy for cheap 35 dollar for one belt .Cowardlyduck said:Thanks for chiming in!bzhwindtalker said:Unfortunately not possible for streel legal ones due to the homologation, only 14-118T is possible.
Best regards, Adam
Cheers
croydon said:i already order 3 polychain carbon belt for cheap price in usa 1 guy sel out the belts in his stock need to go away, it is not the same belt then ore friend have (poly chain carbon v is the old generation , i order the newer generation of this carbon belt , lucky to buy for cheap 35 dollar for one belt .Cowardlyduck said:Thanks for chiming in!bzhwindtalker said:Unfortunately not possible for streel legal ones due to the homologation, only 14-118T is possible.
Best regards, Adam
Cheers
about the stuttering does it happen in flux weakening ?
15T is awsome on my bike i test for the first time with my new setup , it is awsome.
Cowardlyduck said:Thanks again for the suggestions on re-trying auto-detect on the motor. I tried a few more times and eventually it managed to get it right.
Bit of a worry it takes so many tries, but at least it's working again now.
Cheers
I would say the next best customisable, feature rich controller after Adaptto is the Nucular, so not so dissimilar really...although I could never get my Adaptto's running perfect, in the end close enough was good enough.Rix said:I know its like comparing apples to watermelons, but I had to run 3 auto detect cycles on my Adapto to get a combo of settings that allowed the motor to perform really well with out heating things up.
Grantmac said:Lightweight motorcycle with pedals vs powerful ebike.
I actually wouldn't want a concentric drive, especially not shared with the pedals. You lose the ability to control squat.
Simonten said:For me any more power than the LMX 64 for peddling is redundant.
I like to feel like I am peddling which is why i took the throttle off my bike so its only pedal assist.
I wished that mode 1 had a speed limit of about 35K instead of 28k. I mainly use power level 1 unless i want to fly up a fire road.
I have to use level 3 down hill because of the speed limit cut off. Not because i need the extra power.
