Vesc hgltech 75v 200amps
Yer bike busted? tell us all about it here.
tailele   1 µW
Post by tailele » Mar 20 2021 12:00am
Good morning bus, i m news, and i m trying ti build a e-bike with this vesc... Now i connect motors, One rear and One front correctly...but i miss to connect the throttle and the brake. Really the throttle works, but the brake not verry well.
I connect :
Throttle , Red to 5 v , black to gnd and signal to ADC
Brake , One cable on ADC 2 and the second cable to 3.3v..
I m wrong ? I don t find a wrong diagram so for me It Is difficult. Thanks a lot
Hayds13   100 mW
Re: Vesc hgltech 75v 200amps
Post by Hayds13 » Mar 20 2021 6:54am
This might help....Ebike Throttle and Brake Connect to VESC and Parameters Setting Tutorial | Flipsky
https://www.youtube.com/watch?v=44qoVyJf-uk
district9prawn   1 kW
Post by district9prawn » Mar 20 2021 7:08am
You should connect the throttle 5v to the vesc 3.3V supply. This way you will keep the signal value below the maximum of 3.3V.
Neu 8057 6kW left hand drive hardtail with 18 fet Vesc: viewtopic.php?f=6&t=96754
