So, its my first post but Ive been reading ALL of this thread... first and most important I must say that new 4th generation Votol EM-50/100/150/200/250/300 has NEW firmware (.bin) that behaves differently, in older votol (still in stock) the values in flux and % slots were put the same and was about double voltaje settings, BUT in these 4t gen boards only left side means what you think it means, right side is for other adjustments like jitter (timing of frequency, used to adjust the motor: when you hit it too low the motor spins suddenly, if you go to far the motor vibrates half throttle, the adjust range is 100-1200 and its usually right around 300n you notice the motor starts spinning real smooth and slow, with no fluctuation) this jitter is the second or right slot box of sport mode flux weakening, if u leave it at 0 motor wont start..
And so, many things changed and the problem isnt defective controller or bugy software.. the problem is that these people designing this hard stuff are real CHINESE people, and the info is lost along the way.. even inside Votol company..
I will do a real manual for this sh*t and ensure we all know what every part of this software does.. I even know how to use the calibration section of software and I must say EVERYTHING in this software works and works fine, and its hi-tech also..
I do have the new firmware update (bin file) at least one of it, and I would like to have the older one or a newer one, so.. hi to all of you, and replay so i know this thread isnt dead, any questions to me I'll answer no problem.. salute
