Ianhill
- Joined
- Sep 25, 2015
- Messages
- 2,871
Id be looking to load test them cells sag under load so how much voltage deflect you get per amp applied etc amd also check its heat output by doing a IR measurment you should have an idea of the losses to expect.
Ive done a bit of digging on the bms front and found active balancing and resistive balancing.
Active balancing acts quicker its equalizing the voltages the battery degrades a fraction less so they say, there's far less heat created moving energy to one cell rather than a resistor and heatsink so i found by having a read about.
I'm happy my resistive bms will suit its purpose its in a basic brushed ride and the most i want from the display is basic shunt functions and been just 1 cell in the pack balancing wont be to heavy anyway.
I found a jikong 24s 2amp active balance bms 200amp so ill be having a play around with that ive got a chargery so i can run upto 88.8v nominal for some real serious shit.
