trunk mounted bike carry racks
bobc186   1 µW
Post by bobc186 » Jun 10 2021 10:36pm
i’ve been researching, a trunk mounted carry rack for my ebike that i am in the process of building....which is my first build.....i haven’t weighed the bike yet,but i’m assuming somewhere, around 45ish pounds......anyway, i drive a 4 door sedan and would like to know, what my fellow e bikers  are using....pictures would be awesome..thanks for looking...
TDB   100 W
Re: trunk mounted bike carry racks
Post by TDB » Jun 11 2021 12:26am
1up is a gold standard for bike carriers. I'm not sure they make trunk mount though. They are usually hitch or roof mount. I'd try to talk you out of trunk mount as they are the least secure/stable.
https://www.1up-usa.com
99t4   100 W
Post by 99t4 » Jun 11 2021 2:19am
Also not a fan of trunk or hatch mount. I have carried plenty of multiple heavy bikes on my Allen brand 3 bike hitch mount carrier. Thickwall steel channel, overspec'd fasteners. Biggest/heaviest was a 65-70 lb. Radpower Radwagon longtail utility e-bike. No problem at all.
dogman dan   100 GW
Post by dogman dan » Jun 11 2021 5:05am
You need a hitch on the car, for a hitch mount rack. The swagman hitch rack is very affordable, yet damn surprising strong.
Its pretty easy to install one yourself, once you order the correct one for your model and year of car. The hitch will come with a neat tool that makes it easy to put the bolt in the frame of your car, and then you just need the wrench to tighten up the bolt.
A very light, less expensive 1 1/4 inch hitch will do just fine, and no wiring unless you actually want to tow a light bike trailer.
https://www.etrailer.com/fitguide.htm
COAR   1 W
Post by COAR » Jun 13 2021 3:41pm
I have a 'hollywood racks' 2 bike hitch rack that was about 50 bucks off craigslist. It's a little ugly but works great. Only downside is it's a little clunky to fold down if you need to access the hatch, but that's a reasonable tradeoff to get 90% of the functionality of a high end rack at 10% of the price.
I'd recommend a hitch rack that holds the wheels (rather than hanging the frame) as they're compatible with virtually any bike and very stable (no swaying). Note: a hitch rack does prevent the parking sensors from working, even without bikes loaded.
Eastwood   100 W
Post by Eastwood » Jun 13 2021 6:07pm
For sure install a hitch and get a sturdy bike rack. I use a cargo rack that holds 500 pounds. But I’m normally hauling too heavy E bikes
