How about a 3D printer section?
Petg is just difficult to stick, but once you have a system worked out it won't be an issue. Here is what I do for rPetg on a glass bed.
1. Raise bed temp for first layer. I do +10c (75c).
2. Reduce Z offset (more like .07mm instead of .1mm).
3. Slow down first layer.
4. All else fails, a bit of glue stick around bits that like to pull off ( through holes, etc...)
If I use a lot of that purple glue stick I can get it to stick ok on my glass bed. I bought a tube of magigoo that I will be trying today. I've been setting the Z offset at one paper layer (~.07mm) for PLA but am using 3 pieces of paper in order to get a decent looking first layer test print. The bed temp I've set at 75*C.
I'm getting a ton of stringing but am starting to think that's just the nature of PETG and will just have to live with it as increasing both retraction length and speed didn't help at all. Lowering hotend temp helped a little but probably at the detriment of layer adhesion.
I'm liking the strength of the cf/PETG that I got from filaments.ca. They say to print it with a hotend temp from 200*-240*C. I've been having success with 210* but am going to try hotter temps for better layer adhesion.
I'd like to thank everybody for the advice. I'm slowly starting to get the hang of it. I'm starting to think that 3D printing is as much an art as it is a science. :mrgreen:
With a PEI printbed PETG and TPU stick too well.
I was never satisfied with the evenness of glue stick coatings. Misting unscented aquanet is much easier, faster and more even. It only takes a very thin coating, not even complete coverage. Just a misting. At $2 a can (Walmart) it lasts a very long time. I've only used 2 oz of the 11 oz contents in more than a year. Saves me a lot of isopropyl as well. I don't spray every print cycle with PLA, with PETG or TPU need to spray a bit more often. It also helps to let the printbed cool before removing prints.
One more thing - I never touch the print surface with fingers (except when washing it). Only clean tools. Touching the print surface with finger oils causes a lot of adhesion problems and there's no reason to. After a few print cycles re-mist. After a few spray cycles wash off the printbed with water and a drop of detergent, rinse well, let it dry, and re-mist. This is smooth PEI on spring steel. I no longer need to sand the PEI or use the occasional acetone on it. I've been using the same PEI for several years and many hundreds of prints.
carbon fiber pla from filaments.ca
at 235C to 240C it was rough and loose fibers on the print
some filaments are cf powder and some are carbon fibers but it wasnt stated on the website
prints good at 230C
took a picture of some fluff
heat resistance
i assume strength will be added getting rid of brittleness
i wanted stiff, rigid, strong and heat resistant and uv resistant, easily printed
https://filaments.ca/collections/3d-filaments/products/ecotough-pla-2-0-heat-resistant-carbon-fiber-1-75mm
this roll comes at 0.8kg, this print is 761 grams
while reading its specs it also says it weighs less than pla, i dont know if that means i get more in meters. i think this print needs 270 meters
find out in 2 days if i have enough when the print is finishing.
like to find a sealer for it, havent looked yet
i looked at strength testing on yt and 100% infill seems stronger than 50% infill patterns
i added outside walls, angles and holes for strength but had to go to 80% infill to cut weight.
heard we're getting blasted from the sun and my lights are flickering quite a bit, hopefully the power stays on but should see the northern lights tonight :D
frign nozzled jammed 30hrs into it.
little annoyed but once off the plate
this filament is a beast
feels like slab of aluminum
i have another roll but im going to order a 0.6mm hardened steel nozzle and try again
no comparison to the sunlu pla cf
It looks like when I'm indoors this winter, I will have some time to finally unbox my 3D printer.
What drawing programs are you all using? And/or recommend?
I think you mean a stack of thin sheets of some janky variety of aluminum, stuck together with tape.
spinningmagnets said:
It looks like wen I'm indoors this winter, I will have some time to finally unbox my 3D printer.
im using freecad, its good for quick little items but for bigger designs if a mistake is made you cant just go back and fix it without something breaking. its fixable but its easier to just delete and start over, ive probably deleted 40hrs of design :evil:
this video explains it, read the comments
https://www.youtube.com/watch?v=QSsVFu929jo
going to try the realthunder branch of freecad, supposed to fix that problem
https://www.youtube.com/watch?v=p_ZEry2wTfg
Fusion 360 is a good balance between capability and usability. Serious engineering outfits use solidworks, but many small companies do use it and I believe it's free for hobbyists.
https://www.autodesk.co.uk/products/fusion-360/pricing
It may just be in the UK, but I don't see the "free for hobbyists" pricing.
Which is why I went for FreeCAD. Open Source, works well on Linux. Pretty capable. Work around the drawbacks, or submit fixes - joy of open source.
https://www.autodesk.co.uk/products/fusion-360/personal
https://www.autodesk.com/products/fusion-360/personal
It's free.
It's free.
Fascinating. I looked at every option for clicking on links on this site, and none of them ended up at this page.
I eventually found it through searching for "personal use", and following two linked knowledge articles.
But based on what is available through the normal site interface, they want you to pay, and do not present any hint that you may qualify for a free license. Not open and honest behaviour, in my view.
Which printer did you end up getting?
It was a gift two years ago, and I actually don't remember which model.
Sometimes I feel like I have three jobs. When I retire, maybe I can squeeze some fun projects in between the two remaining jobs...
