L.E.S said:
Any reason why not some type of foam? or is it the obvious that it is quicker using materials nearby? (or maybe a kink for hot glue) :lol:
Thank you, I haven't really looked in to how to use foam for something like this. And I don't hove any experience in it. I have seen it used when a guy made his own car body from scratch.
I think my way is easier for small parts like this, and when I have a few given points where it should fit. But I don't really know.
I think it will be hard to get a good surface on foam?
hannesd said:
i can't help but looking at those wires coming out of the motor.
if they won't have some sort of a strong cover, they will be kicked off in no time when riding a track.
also have you thought about this bike will be covered in mud ,are all those components really waterproof, for a power washer?
There will be a cover for the wires, I just haven't got to that point yet.
Yes, I am expecting it to be covered in mud and power washed regularly.
Thats part of why I put every electric part possible in the battery box. I will probably drill small drain holes in the bottom of the battery box, so it will be possible for water to get out if I get some in there. There will be holes for a few wires, a button and some screws so I am not sure if everything will be absolutely water tight. And then there is the joint between the bottom and top to get water tight too.
I have small drain holes in both the batteries, the box with the bms and the box with the display on the ktm. And that has been covered in mud and power washed for two seasons so far. It has been more or less under water once without problems with any of that. However, I haven't opened up the batteries so I dont know how they look inside.
I have gotten water in the motor on the ktm, but I think that will be less likely on this. Here the shaft seal will be protected because I have the primary reduction in oil where the shaft ends.
With a cover over the wires to the motor they will be protected from direct hits with the power washer. The rest of the motor seems to be well sealed.
I expect the controller to be well protected, it is ip66 classed. It will also be protected with a cover over the wires, so that will help with direct hits from the power washer too.
I expect to have some problems with switches, I have that on the ktm. I havent found any good, waterproof ones.
But I haven't chosen switches for this bike yet.
Is there something in particular that you think wont take some mud and a power wash?
