70V-ish PSU advice
Archive of useful information. This is not a discussion area.
drebikes   100 W
70V-ish PSU advice
Post by drebikes » Jan 23 2022 9:09am
Hi all,
I'm looking for a AC mains to DC power supply of about 70V (min 66V) to power a 360W FRNSI DC6006L adjustable PSU. I'm not sure what is the maximum it can take, need to open it up, but spec says 70V. I have to assume it has 80V caps, but I'll check.
After googling, ebay and alibaba, looking at the prices of what is labeled as PSU, I was disapointed in the pricing - even if they offer more settings than I need. Now I'm focusing on 16-17s 4.2V chemistry battery chcargers. There are of course lots of possibilities, but I'm not looking at professional stuff, quite the opposite. I'm looking for ideas, thoughts advice, my level is amateur electronics diyer.
No need to click on the links below, that are some non-crazy things I think might work, but not sure. Here's some things I found:
*https://www.ebay.com/itm/383760177980?h ... Sw54NduoGU seems it might do the job, but there's no isolation between input and output stage that I could detect
*https://www.ebay.com/itm/234167124238?h ... Sw~hNdJrBu a 17s battery charger
*https://www.ebay.com/itm/353558615336?h ... SwuChg38BM much cheaper but 16s battery charger
Since I only need a constat DC feed, are battery chargers my best shot?
Cheers from polar Scandinavia
dominik h   100 W
Re: 70V-ish PSU advice
Post by dominik h » Jan 23 2022 12:30pm
A battery charger turns off after charging is finished.
Just buy two 36V LED sources like meanwell elg or hlg nd put them in series.
drebikes   100 W
Post by drebikes » Jan 23 2022 2:01pm
dominik h wrote:
Jan 23 2022 12:30pm
Thanks dominik, that looks like a great shout. When they say 36V, I suppose they actually mean 36V, not some weird range like for li-ion cell packs, right?
john61ct   100 GW
Post by john61ct » Jan 23 2022 2:10pm
Yes, for LI chemistries the distinction between a PSU and charger is the auto-termination of the charge cycle based on a "smart" judgment of the target battery being Full.
Without that there is greater risk of harm, reduced longevity from overcharging and even fire.
A great charger example is Grin Satiator
#7205 "36V-84V" outputs 20-103V, 4-5A (360W)
About $300
If you know of a reliable (not cheap Chinese) HVC circuit, your FNIRSI DC6006L PSU will perhaps be just as good.
2x Mean Well HLG-240H-36 in series as input.
But by the time you're done how much money saved.
Kluge of components cobbled together rather than all in one.
And lower reliability, shorter lifespan.
Why do you think that's needed, on your final output unit?
dominik h   100 W
Post by dominik h » Jan 24 2022 6:14am
Meanwell HLG or ELG 36 means 36v at the output. And it is also adjustable in a small range.
john61ct   100 GW
Post by john61ct » Jan 24 2022 2:28pm
dominik h wrote:Meanwell HLG or ELG 36 means 36v at the output. And it is also adjustable in a small range.
The point is, two in series to act as a 70V source feeding the OP PSU.
Adjust from 36V to 72V ,not so small
https://www.meanwell.com/Upload/PDF/HLG ... H-SPEC.PDF
But my reco is the Satiator.
m3vuv   100 W
Post by m3vuv » Sep 12 2022 4:35am
most 36v chargers,eg10s normaly output 42v,ive used 2x 36v chargers in series a few times to charge a 20s pack.
