what multimetre should i choose for present cell mesurement and future home task
sharinginfos   10 µW
10 µW
Post by sharinginfos » Sep 19 2022 12:24am
HI
I like to make a good buy when i do a buying
Atm i only need to mesure voltage but maybe tomorow i will need other functions
i dont want to become an expert on multimeter.
i see 3 choices with like 15 doll difference below
wich should i choose?
i never had to use a multimeter and live in an appartement.
https://www.amazon.ca/KAIWEETS-Multimet ... s9dHJ1ZQ==
https://www.amazon.ca/AstroAI-Digital-M ... C81&sr=8-5
wich one is better for futur application and why
thanks
LewTwo   10 MW
Re: what multimetre should i choose for present cell mesurement and future home task
Post by LewTwo » Sep 19 2022 12:53am
The last one will not measure AC voltage (i.e. what you have in your home).
The second has fuses for both Amp and Miliamps.
It is also likely accurate enough for a beginner.
The more I learn the more obvious the immensity of my ignorance becomes.
Weight Wennie E-Bike https://endless-sphere.com/forums/viewt ... 3#p1173723
Shaft Drive Grocery Getter https://endless-sphere.com/forums/viewt ... =6&t=90718
...and thanks to Justin!
Comrade   1 kW
Post by Comrade » Sep 19 2022 7:04am
sharinginfos wrote:
Sep 19 2022 12:24am
None of those are a good meter by any definition.
E-HP   10 GW
10 GW
Post by E-HP » Sep 19 2022 7:34am
#3 doesn't do AC as mentioned. #1 has too many oddball functions like the temp probe. Might be handy but not needed. #2 covers all of the basic functions you'll need.
4πr^2   10 W
Post by 4πr^2 » Sep 19 2022 9:00am
Not sure what people are considering "#3" - but the third one on the list I see is the "AstroAI" for ~$18. It says and looks like it does AC and DC voltage to me, plus 'the usual' other functions... resistance, conductivity, etc. For general use, I suspect it would be more than accurate enough. You likely aren't going to be measuring amps, and if you do, amp draw on a bike is going to be much larger than most any meter, so you'd probably use a shunt and actually measure voltage across it. So I wouldn't worry too much about amp capacity of the meter.
E-HP   10 GW
10 GW
Post by E-HP » Sep 19 2022 9:34am
4πr^2 wrote:
Sep 19 2022 9:00am
You're right. But, it also uses 9V batteries, which I try to avoid. A few battery changes and it makes up for the price difference with #2.
Comrade   1 kW
Post by Comrade » Sep 19 2022 9:38am
4πr^2 wrote:
Sep 19 2022 9:00am
Most good meters go up to 10A, which is plenty to do some calibration on an e-bike. At 48v that's 480W of power. The point of a good meter is that it is guaranteed to be calibrated. It becomes a reference tool against which other things are calibrated. It's like buying a typical Chinese ruler that is about 1mm off. Everything you measure and build with it will be off. :lol:
LewTwo   10 MW
Post by LewTwo » Sep 19 2022 10:10pm
4πr^2 wrote:
Sep 19 2022 9:00am
Well it does not measure AC Amp's ... but the picture used by the vendor is somewhat misleading, so one has to read the caption closely: "... can not be used to test AC voltage of RECEPTACLE when dial is located in DC current range."
I admit that I quit reading as soon as it got "can not be used to test AC voltage" ... my bad.
No AC.jpg (56.03 KiB) Viewed 511 times
calab   100 kW
Post by calab » Sep 20 2022 12:45am
I'd price compare to keep my hopes high on spendy spendy but this one looks good if the work counted
https://www.eevblog.com/product/bm235/
For our adult toy kid hobby, if you can find a cheap meter that will read 12.34 digits, but any meter $10+ is suitable even if it only read 12.3 digits, just wait until theres a sale and snatch one up, or signal to your fellows with a used dirty Fluke and flex. If one came around, used, for a good price..... why not? Actually I ran across many, decided I had other priorities for the monies.
Mine reads 12.3 digits, and I still balance the cells manually. It kind of sucks to measure 58.8 volts and not 58.78 volts ya know.
Always best to have a minimum of 2 digital multi-meters, and lots of spare fuses and spare 9v batteries, even spare probes.... that fit ;)
I dont know about those links, I wouldnt trust those no-names.
I thought this guy would have something cheaper but this looks to be the cheapest $65aus out of stock :( which is like $40 usd, guess was close its actually $43usd.
https://www.eevblog.com/product/pm300/
amberwolf   100 GW
Post by amberwolf » Sep 20 2022 2:26am
FWIW, the sub-$5 meters like HarborFreight used to give away (still available in a bunch of "brands" on amazon for less than $10) are good enough for just about all troubleshooting on an ebike, given that most of the things one needs to check are of the "is there a voltage and/or does it change" kind of thing, and knowing if it is 3.922v vs 4v isn't important. ;)
They're not truly accurate, as each one measures a bit differently :lol: but once you know how one behaves (such as measuring a few 5v USB chargers' output, etc and seeing if it correctly reads 5.0v, etc)., it's good enough for testing even batteries (balance testing for instance only needs to do relative voltages between groups/cells, to know which ones are off and by about how much).
I still keep a bunch of them around to test things I don't need my ancient Fluke 77-III for. ;)
I also have some of the in-between-quality meters, and for the most part they aren't enough better than the super-cheap ones, except for having MUCH better test leads, to be worth the significant difference in price (sometimes as much as 5-10x that of the super-cheapies). They may have more features, better ergonomics, etc., but they don't do their actual job enough better to be needed for most of the electrical/electronics testing I ever do (which has been quite a bit over the decades).
Current measurements on an ebike will require more than pretty much any of the cheap meters can handle, unless using a clamp-on meter, so it's generally irrelevant what they can test, current-wise, for the most part. (sometimes still useful for testing lighting, DC-DCs, idle current draw, etc).
Beginning of a New Life
Give a listen to my music!
(More here, including experimental)
gobi   1 kW
Post by gobi » Sep 20 2022 7:49am
Before ebikes, I had to read up on lithium battery tech,
I found that I needed to figure dc amps with a CLAMP on meter,
This one does BOTH DC and AC amps (clamp on)
https://www.amazon.com/dp/B07Z398YWF
looks like it was a coupon, that makes it sweeter,
I would suggest this one or similar, clamp on feature ROCKS!
marty   100 MW
Post by marty » Sep 20 2022 10:37am
Doctorbass wrote:
Jan 15 2015 1:43pm
I would go with a FLUKE !!
Solid reputation
Accurate
Well built
That's a one-time buy!
Doc
Doctorbass wrote:
Oct 16 2007 10:29am
Buy a fluke and let you stop bordering you with innacurate cheap DMM :wink:
I know alot about multimeter and i have 9 different in my home lab.
some of those will have different reading because:
some have an internal load (like mastercraft that have a load to test 1.5, 6, 9 and 12V battery) they dont test in floating mode).. they will read lower value and it's the load that make the voltage droping a bit...
-some have cheap DAC and op amp ic and resistors that have tolerence that drift with temperature...
-some are affected by the soc of the battery that power the multimeter!.. a lower 9V battery give often higher reading!!!
-buy a fluke...
buy a fluke...
but a fluke...
Zzzzz zzzz zzzz...
Doc :wink:
Matteo's Mobile Bicycle repair
https://matteosbikerepair.com
marty   100 MW
Post by marty » Sep 20 2022 10:45am
amberwolf wrote:
Sep 20 2022 2:26am
Had a Harbor Freight free multimeter. Tried it. Quality was so low I would call it garbage. After a autopsy, Might be good for a fraction of a penny worth of scrap metal :(
ebuilder   10 kW
Post by ebuilder » Sep 20 2022 10:49am
What Doc said. Fluke for life. That's all. Had others. Weren't as good.
sharinginfos   10 µW
10 µW
Post by sharinginfos » Sep 21 2022 12:42am
hi
thx for the answers,
the fluke are very expensive. the whole point of building my own battery is to save money and have good quality cells i bought used from Drbass prepandemic ill use the multimeter to try to put cells with same voltage in paralle. yes using a cadillac is fun but do i really need that to check the cells and stuff?
i mentionned that it would be nice that the multimeter can be used in home but i never had to use one so far and dont know exacty what feature are needed. Im not going to specialise in electricity battery building after i will have build a safe and fonctionnal battery wich is my goal
what i understand from your writing is tha no1 link has to many options , the no3 is not up to the task
So i guess i have to choose between the no2 and the clamp on
no2 is this the one at 23 dollar
the clamp on is 47 dollar acdc .https://www.amazon.com/dp/B07Z398YWF
I did not know that clamp multimeter existed. not sure when it can be a plus when building the battery and installing the hubmotor and wire.
can you give me hints one wich one would be best? both price are ok for me since i need one hoping it will last me a while
thanks
amberwolf   100 GW
Post by amberwolf » Sep 21 2022 1:16am
sharinginfos wrote:
Sep 21 2022 12:42am
<snip>
Ah, well, since you didn't tell us any of that, we couldn't know to suggest cheaper things. ;)
It would be best if you specified a budget that recommendations should not exceed.
Presumably for your battery build application, it only needs to measure DC voltages up to the max voltage of the battery. What will that be? (how many series cells (groups) will it have?)
Note that if you buy a meter only just capable of this, and need other capabilities later, you'd likely have to spend the same money (and probably more) all over again to get those. But if you never need the other capabilities, it might be a waste of money to spend on them now.
If I had to choose between the two options you linked last, I'd pick the clamp-on meter, as it is only about $7 more than the other, and can do significantly more, including the temperature and high-current measurement options useful for ebike testing. Whether one is really any better than the other, I couldn't say, never having used that "brand".
FWIW, the most commonly used meter modes for ebike troubleshooting are <200 DCVolts, Continuity, 2-20KOhms.
Measuring DCAmps is helpful in various kinds of testing, but usually you'd need to measure 20-30A ranges or higher to be useful; and often only while riding to do the testing under sufficient load--in those cases, a wattmeter is more useful and does more things for the money.
Temperature testing is sometimes useful as well.
AC measurements are almost never needed on ebike testing/troubleshooting, so if a meter doesn't have that function, it's not a big loss unless you think you will use it for household wiring troubleshooting (which I recommend leaving to experienced professionals if you are not yourself experienced at it, unless you first learn enough about it; it's too easy to make a fatal mistake testing or fixing household AC wiring stuff).
sharinginfos wrote:
Sep 19 2022 12:24am
<snipped links>
sharinginfos wrote:
Sep 21 2022 12:42am
<snipped links>
gobi   1 kW
Post by gobi » Sep 21 2022 8:02am
A/C at home - I don't ever need a multi meter for A/C work at home,
I use few items, the main one is a tone touch sensor that detects voltage to confirm if the line has power
2nd - a 3 prong plug to test if the outlet is wired right
3rd - a sounder that I can use to trace back to the main panel an outlet to figure out the breaker I need to turn off etc,
I live in a 50s house that was rewired by Motown's finest Electrical Co - Stevie Wonder's Zap Electrical,
:shock:
Comrade   1 kW
Post by Comrade » Sep 21 2022 10:34am
sharinginfos wrote:
Sep 21 2022 12:42am
They are relatively more expensive, but total cost of ownership is a thing. Initial price is far from the total cost. How long before you need to replace thin cheap leads? How long do the batteries last? What is the probability of it breaking in a non repairable way divided by how many years to you plan to keep? What is the residual/resale value?
A used quality tool is almost always a much better value (=total cost of ownership) than a cheap tool. If you pay retail on new quality tool it still is often a better value.
amberwolf   100 GW
Post by amberwolf » Sep 21 2022 8:58pm
gobi wrote:
Sep 21 2022 8:02am
I guess that's a few steps up from a bobby pin. ;)
sharinginfos   10 µW
10 µW
Post by sharinginfos » Sep 22 2022 10:50pm
im building a 48 v battery with used vtc4
iwould have to verify with my desing but i think it is a 13 s4 p or 14s 4p(14 most probably.
even though i will only use a xiongda 7amps to begin with i want my battery to be able to be working with higher amps for future upgrade so like 60 amps .
amberwolf wrote:
Sep 21 2022 1:16am
sharinginfos wrote:
Sep 21 2022 12:42am
<snip>
sharinginfos wrote:
Sep 19 2022 12:24am
<snipped links>
sharinginfos wrote:
Sep 21 2022 12:42am
<snipped links>
docw009   1 MW
Post by docw009 » Sep 22 2022 11:40pm
I find that an inexpensive multimeter is sufficient for my ebike work, even for testing internal cells on batteries. I have several of the free Harbor Freight meters and a more expensive $20 model. Used to have a Hewlett Packard, but it died.
An RC wattmeter is useful if you're testing batteries. These things are horribly uncalibrated, but once you compare it against an accurate source, it's handy to see what kind of currents are flowing. Also measures peak amps, voltage droop.
https://www.ebay.co.uk/itm/234473396262 ... R571lIntYA
If you're trying to recover cells to build batteries, don't bother. But if you insist, then you probably need a capacity tester to find out how many mah is in that cell. I have a Littokala 500S, but the 500 is cheaper. You might have to ask around to see it it's worth paying for the 500S.
https://www.ebay.co.uk/itm/304576258390 ... BM2pbDie1g
And knowing that the used cells you bought really are 2400 mah isn't enough to tell you that they will work for an ebioke. Your need a series reistance tester like the YR-1035. This is really precise. You can read your cells down to 41.717, or three decimal places.
https://www.ebay.co.uk/itm/195066159044 ... BM_NH7ie1g
It's an endless rabbit hole. I think a good way to get low cost ebike batteries is to buy used packs from a failed scooter/ebike rental company. Quite a few of those in the USA. I've picked up 36V 10AH packs for $25USD that work well, and they are rugged.
calab   100 kW
Post by calab » Sep 23 2022 1:05am
The average punk like me and you, dont need no fancy smansy Fluke meter, at most a $25 meter, if your feeling Big & Rich then say $35, or $40. If you want to flex, buy a used Fluke.
Overclocker   10 kW
Post by Overclocker » Sep 23 2022 1:06am
best combination is an ultracompact "card" type dmm w/ fixed leads so you don't accidentally leave it in the 10A socket :lol:
plus a DC clamp meter. make sure it's DC, cheaper ones can only measure AC
gobi   1 kW
Post by gobi » Sep 23 2022 2:34pm
amberwolf wrote:
Sep 21 2022 8:58pm
gobi wrote:
Sep 21 2022 8:02am
lol, finding the breaker for an outlet is a game of chance!
Op, watch some home electrical repair/upgrade videos and see that tools they use. It is VERY hard to use the test leads when you are on your knees and little chunky like moi.
nicobie   1.21 GW
1.21 GW
Post by nicobie » Sep 23 2022 2:50pm
I agree with AW that a cheap DMM like the one Harbor Freight used to give away is good enough for ebike and home use. That said, I also own a nice Fluke 89 for when I absolutely must have a spot on measurement (which is exceedingly rare).
For me the most important features are;
Auto off
beeps when testing for continuity
good silicone lead wires
clear & large enough display
Ask for it by name.
my eTownie build thread: http://endless-sphere.com/forums/viewto ... =6&t=23701
Magazine article https://www.electricbike.com/nicks-etownie/
