harrisonpatm
- Joined
- Aug 8, 2022
- Messages
- 821
Trying to get my head around the battery amperage coming from my motorcycle. Pure sine wave inverters pull varying amounts of amperage from a battery to simulate sine wave. And that this may affect amp readings, because the actual amp draw may experience peaks of, say, 40% more than what's being read.
I have two ways of reading battery current. I have my JKBMS Bluetooth app that shows amp draw digitally. I don't know for sure, but I assume it's via a hall shunt within the bms, and the readings refresh 3-5 times a second. Not great, in my opinion. Plus I don't like to have my phone out while riding. In addition, I also use an old-school analog ammeter with a needle gauge on my instrument panel, which uses a shunt on the negative connection between the battery and the controller. I like this because the refresh rate is continuous, I can immediately see amps rise when I throttle up or climb a hill.
Trouble is, on the occasions when I use both my phone and ammeter on short rides to diagnose something, i tend to see some battery amps peaking higher than what the analog ammeter is showing. This concerned me for a bit, I didnt like like idea that one of my instruments was that inaccurate. Then I realized that the BMS was always the higher reading, and it was showing it in peaks, usually around 40 percent of what the ammeter read. Then dropping off.
So my question is, is a motor controller basically an inverter? If so, I would guess that the higher amp readings that I occasionally get from my BMS are actually the peak current "waves", which are like snapshots of the actual variable amp draw that the controller is pulling off the battery, because the BMS is only refreshing a few times a second. And since my needle analog amp gauge refreshes continuously, it can't show those peaks, but is better at averaging out the amps being pulled.
For my birthday this year, I need to gift myself a dc clamp ammeter, then I can clamp one of the battery wires during a ride and have a 3rd way of checking amps. Until then, does my theory sound somewhat accurate? Thanks in advance.
