Viewing post history: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
This page shows all versions of the post, starting with the most current version.
Current post: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
Postby Lyen » Tue Mar 16, 2010 6:16 pm
These are newly hand assembled Infineon 9 FET controllers I am selling, they are new and never used. It is originally designed for long distance commute in the San Francisco area. It is also best to be used on electric bikes with smaller wheels such as those 16" to 20" wheels found on most folding bikes & scooter style ebikes for more speed. For those who owns battery packs with 10-15Ah in capacity this is the controller for you to avoid getting the battery management system circuitry (BMS) tripped or experience power protection shutdown enabling due to insufficient current flow (low discharge rate) available from the battery and low amperage designs in most 10-15Ah capacity battery packs.
The controller is like a wolf in sheep's skin because it is under tuned in order to optimize for long range. There are lots of potential and features you can unveil and twist as you go. You can program functions such as enable power regeneration, regenerate braking, pulse width modulation, low voltage cut-off, interface with a Cycle Analyst, and others. You may also add an USB to RS232 serial adapter and connect to the computer for tuning. (Electronics knowledge is required to unleash the potential however)
One unique feature of this controller is that it has an additional speed sensor circuitry built-in with an extra blue wire for output. It is to be used with the scooter style electric bike and electric scooters that have a speedometer in the dashboard. As of April 5th, 2010 the speed sensor wire has been embedded and integrated with the green wire on the CA connector since they both can share the same function now. More practical and less confusion as suggested by previous buyers. :)
If you look carefully in the photos, you will notice this version also uses lock washers to secure the FETs internally and the heat transfer bar outside to place tension against a nut after tightening. It is also to help prevent the nut from loosening. The FETs will get overheated and damaged when detached from the heat-sink which used to be the case from the previous designs.
* For the extremists, you may double and possibly triple the current output to make it a mighty wonder by adding braids wires (http://www.radioshack.com/product/index.jsp?productId=2062744),add solders to beef up the circuit board traces and shunt. It may also be needed to upgrade to larger capacitors, gauge wires for both the battery and the phase wires to the motor. However, if you are going to use a 9C (Nine Continent) motor, It is recommended to maximize the current output at 65A due to the thinner gauge wires being used with the hub motor. There is a potential that any current & voltage combination higher than the current 72V @ 65A will melt the phase wires in the hub motor and cause potential damage. A good observation and one that I think plays a big part in showing why the small 9 FET controllers can seem to pack such a punch when modded. The gate drive circuit in the Infineons I have looks to be pretty similar, certainly the 18 FET circuit doesn't look like it can provide much more gate drive than the 9 FET circuit. My guess is that this is one of the reasons why a well-modified 9 FET controller will seemingly run at upwards of 60 to 70 amps without getting hot; the 9 FET drives the FET gates harder and therefore more efficiently. On my list of things to do one day is acquire some really big FETs and see just what a 9 FET controller can do. I think that, fitted with external FET wiring and shunt, it would easily be capable of running at 65A or more, reliably.
Below is the specification:
Model: EC-094310-LYEN EDITION
Start immediate controller
Chipset: XCKJ8B116A (same chipset being used as in the 18 FET controller)
Circuit board version: EB209-A-3
9 x genuine IRFB 4310 MOSFET N-CH 100V (tested up to 110V before damage) for more information about the FET, click the link below:
http://parts.digikey.com/1/parts/1021134-mosfet-n-ch-100v-140a-220ab-irfb4310.html)
Large 100V 470uF Chengx capacitors equipped (http://dgfoley.en.alibaba.com/product/262853773-209597704/Large_electrolytic_capacitor_CD293_LP_.html)
72V battery optimized (for higher or lower voltage & current such as 24V-100V, you may need to change the resistor network to avoid damage to the LM317 linear voltage regulator)
30A is the current rate (for higher current, you may need to beef up the trace, shunt, and reprogram it via the software)
Low voltage cut-off: 62.5v
Battery and motor phase wires gauge size: 12AWG (High voltage capable wires equipped)
Dimension: 4.84" x 3.4" x 1.75" (123mm x 87mm x 45mm) plus mount extensions
Total weight: 445 gram
In case you want to upgrade it later on to became Methods-proof and Doctorbass-proof, you may need to upgrade the FETs to 4110 to achieve higher current as well as voltage above 100V. We have a friend here Steveo who do awesome controllers upgrade for a fee. :)
I have only 50 made since I am busy working on my other ebike projects. My intention for selling at such low price is to share the fun with other ES forum members instead of making them jealous. :wink: I finally understand why Methods mentioned the cost of labor is steep after all this and I have to agree with him from now on. These controllers are not generic controllers. I have every single one serialized. Quantity is limited, buy it now and upgrade later once your piggy bank is filled up if needed. :lol:
$89 USD free ground shipping in the United States & Canada. For other locations, please PM or email me at LYEN@HOTMAIL.COM. I accept PayPal, cash or money order. The controllers will be shipped out from me in San Francisco, California, USA. I will provide a tracking number and ship it out as soon as I have received the fund.
For only $10 more, I can include the the following:
1. CA connector
2. Regenerative enable/disable (Enabled simply by connect the wires together without the need to open the case)
3. USB-TTL 5 pin connector (for use with the USB-TTL adapter that is sold separate)
I also have the USB-TTL adapter for adjust and alter the controller settings on your computer. It has the extra 5 pin plug and a "SEND" button. It is also compatible with Windows XP/Vista/7 32/64 bit operating system (real 32/64bit drivers). $15 with purchase, $20 if purchase separately.
You may click on the PayPal Buy It Now link below. For accessories, please send money via PayPal or send me a private message for the total price. Thanks!
https://www.paypal.com/cgi-bin/webscr?c ... MY46WP98CG
If you are not satisfy with the results or if it is too fast for you, you may send it back to me within 30 days in an unmodified condition.
Update: Jan 28th, 2015 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 1/21/2013: 49 left (buyer bought 1 from Saint-Petersburg, Saint-Petersburg, Russia )
Quantity updated as of 1/31/2013: 48 left (buyer bought 1 from Merkez, KÜTAHYA, Turkey )
Quantity updated as of 3/13/2013: 47 left (buyer bought 1 from Portland, OR )
Quantity updated as of 3/18/2013: 46 left (buyer bought 1 from Frankston, Victoria, Australia )
Quantity updated as of 3/25/2013: 45 left (buyer bought 1 from Bologoye, Tver, Russia )
Quantity updated as of 4/1/2013: 44 left (buyer bought 1 from Calgary, Alberta,Canada )
Quantity updated as of 4/18/2013: 42 left (buyer bought 2 from Cardiff, United Kingdom )
Quantity updated as of 5/3/2013: 40 left (buyer bought 2 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 5/9/2013: 39 left (buyer bought 1 from Viseu, Portugal )
Quantity updated as of 5/11/2013: 38 left (buyer bought 1 from Toronto, Ontario, Canada )
Quantity updated as of 6/7/2013: 37 left (buyer bought 1 from Manhattan Beach, CA )
Quantity updated as of 6/13/2013: 36 left (buyer bought 1 from Erie, PA )
Quantity updated as of 6/13/2013: 35 left (buyer bought 1 from Oakland, CA )
Quantity updated as of 6/18/2013: 34 left (buyer bought 1 from Philippi, WV )
Quantity updated as of 6/18/2013: 33 left (buyer bought 1 from Sylling, Norway )
Quantity updated as of 6/21/2013: 32 left (buyer bought 1 from Thomasville, GA )
Quantity updated as of 6/22/2013: 31 left (buyer bought 1 from Unionville, Ontario, Canada)
Quantity updated as of 7/7/2013: 30 left (buyer bought 1 from Korea, Seoul, South Korea )
Quantity updated as of 7/27/2013: 29 left (buyer bought 1 from Philadelphia , PA, United States )
Quantity updated as of 8/11/2013: 28 left (buyer bought 1 from Philadelphia , PA )
Quantity updated as of 8/15/2013: 27 left (buyer bought 1 from Porta Westfalica, Neesen, Germany )
Quantity updated as of 8/19/2013: 26 left (buyer bought 1 from Portland, OR )
Quantity updated as of 8/20/2013: 25 left (buyer bought 1 from Avellino, Montoro Inferiore, Italy )
Quantity updated as of 8/23/2013: 24 left (buyer bought 1 from SURREY B.C., Canada )
Quantity updated as of 8/23/2013: 23 left (buyer bought 1 from San Francisco, CA, United States )
Quantity updated as of 8/31/2013: 19 left (buyer bought 4 from Philadelphia , PA, United States )
Quantity updated as of 9/1/2013: 18 left (buyer bought 1 from Torvastad, Norway )
Quantity updated as of 9/19/2013: 17 left (buyer bought 1 from New York, NY, United States )
Quantity updated as of 9/25/2013: 16 left (buyer bought 1 from Rancho Cordova, CA, United States )
Quantity updated as of 9/27/2013: 15 left (buyer bought 1 from Moscow, MO, Russia )
Quantity updated as of 9/29/2013: 14 left (buyer bought 1 from Kirn Dunoon , Scotland, United Kingdom )
Quantity updated as of 10/2/2013: 13 left (buyer bought 1 from Stream wood, IL, United States )
Quantity updated as of 10/8/2013: 12 left (buyer bought 1 from Toms River, NJ, United States)
Quantity updated as of 10/31/2013: 11 left (buyer bought 1 from Izhevsk, UR, Russia)
Quantity updated as of 11/14/2013: 10 left (buyer bought 1 from Valbonne, France)
Quantity updated as of 11/17/2013: 9 left (buyer bought 1 from Pretoria, Gauteng, South Africa)
Quantity updated as of 12/24/2013: 8 left (buyer bought 1 from Tel Aviv, Israel)
Quantity updated as of 1/6/2014: 7 left (buyer bought 1 from stockton, CA, United States)
Quantity updated as of 1/23/2014: 6 left (buyer bought 1 from Fremont, CA, United States )
Quantity updated as of 1/29/2014: 5 left (buyer bought 1 from Garden Grove, CA, United States )
Quantity updated as of 8/28/2014: 4 left (buyer bought 1 from land o lakes, FL, United States )
Quantity updated as of 10/14/2014: 3 left (buyer bought 1 from Manhattan Beach, CA, United States )
Attached are the pictures of the controller. Please allow time for the images to load
For a comparable actual value of controllers using the IRFB4310 MOSFET,check here > http://www.ebikes.ca/store/store_controllers.php and here > http://www.electricbikekitz.com/product_info.php?products_id=47
Additional accessories (prices are reflected with controller purchase only. Please contact if you are interested to buy without controller):
$15 throttle (full/half/thumb) with mated left rubber grip (very good quality) (ebikekit retails @ $36)
$19 cruise control (manually installation required)
$15 three way speed switch (manually installation required)
$15 PAS - Pedal Assist System add-on (manually installation required)
$15 electric brake levers a pair
$29 motor/controller hall/phase/throttle tester
Edited by Lyen on Wed Jan 28, 2015 6:19 pm.
Items For Sale
Please sign up here and donate your marrow to save life.
Lyen
Revision 36: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: June 22nd, 2014 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 12/29/2012: 49 left (buyer bought 1 from Bell Gardens, CA )
Quantity updated as of 1/19/2013: 48 left (buyer bought 1 from Vladivostok, Primorskiy kray, Russia )
Quantity updated as of 1/21/2013: 47 left (buyer bought 1 from Saint-Petersburg, Saint-Petersburg, Russia )
Quantity updated as of 1/31/2013: 46 left (buyer bought 1 from Merkez, KÜTAHYA, Turkey )
Quantity updated as of 3/13/2013: 45 left (buyer bought 1 from Portland, OR )
Quantity updated as of 3/18/2013: 44 left (buyer bought 1 from Frankston, Victoria, Australia )
Quantity updated as of 3/25/2013: 43 left (buyer bought 1 from Bologoye, Tver, Russia )
Quantity updated as of 4/1/2013: 42 left (buyer bought 1 from Calgary, Alberta,Canada )
Quantity updated as of 4/18/2013: 40 left (buyer bought 2 from Cardiff, United Kingdom )
Quantity updated as of 5/3/2013: 38 left (buyer bought 2 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 5/9/2013: 37 left (buyer bought 1 from Viseu, Portugal )
Quantity updated as of 5/11/2013: 36 left (buyer bought 1 from Toronto, Ontario, Canada )
Quantity updated as of 6/7/2013: 35 left (buyer bought 1 from Manhattan Beach, CA )
Quantity updated as of 6/13/2013: 34 left (buyer bought 1 from Erie, PA )
Quantity updated as of 6/13/2013: 33 left (buyer bought 1 from Oakland, CA )
Quantity updated as of 6/18/2013: 32 left (buyer bought 1 from Philippi, WV )
Quantity updated as of 6/18/2013: 31 left (buyer bought 1 from Sylling, Norway )
Quantity updated as of 6/21/2013: 30 left (buyer bought 1 from Thomasville, GA )
Quantity updated as of 6/22/2013: 29 left (buyer bought 1 from Unionville, Ontario, Canada)
Quantity updated as of 7/7/2013: 28 left (buyer bought 1 from Korea, Seoul, South Korea )
Quantity updated as of 7/27/2013: 27 left (buyer bought 1 from Philadelphia , PA, United States )
Quantity updated as of 8/11/2013: 26 left (buyer bought 1 from Philadelphia , PA )
Quantity updated as of 8/15/2013: 25 left (buyer bought 1 from Porta Westfalica, Neesen, Germany )
Quantity updated as of 8/19/2013: 24 left (buyer bought 1 from Portland, OR )
Quantity updated as of 8/20/2013: 23 left (buyer bought 1 from Avellino, Montoro Inferiore, Italy )
Quantity updated as of 8/23/2013: 22 left (buyer bought 1 from SURREY B.C., Canada )
Quantity updated as of 8/23/2013: 21 left (buyer bought 1 from San Francisco, CA, United States )
Quantity updated as of 8/31/2013: 17 left (buyer bought 4 from Philadelphia , PA, United States )
Quantity updated as of 9/1/2013: 16 left (buyer bought 1 from Torvastad, Norway )
Quantity updated as of 9/19/2013: 15 left (buyer bought 1 from New York, NY, United States )
Quantity updated as of 9/25/2013: 14 left (buyer bought 1 from Rancho Cordova, CA, United States )
Quantity updated as of 9/27/2013: 13 left (buyer bought 1 from Moscow, MO, Russia )
Quantity updated as of 9/29/2013: 12 left (buyer bought 1 from Kirn Dunoon , Scotland, United Kingdom )
Quantity updated as of 10/2/2013: 11 left (buyer bought 1 from Stream wood, IL, United States )
Quantity updated as of 10/8/2013: 10 left (buyer bought 1 from Toms River, NJ, United States)
Quantity updated as of 10/31/2013: 9 left (buyer bought 1 from Izhevsk, UR, Russia)
Quantity updated as of 11/14/2013: 8 left (buyer bought 1 from Valbonne, France)
Quantity updated as of 11/17/2013: 7 left (buyer bought 1 from Pretoria, Gauteng, South Africa)
Quantity updated as of 12/24/2013: 6 left (buyer bought 1 from Tel Aviv, Israel)
Quantity updated as of 1/6/2014: 5 left (buyer bought 1 from stockton, CA, United States)
Quantity updated as of 1/23/2014: 4 left (buyer bought 1 from Fremont, CA, United States )
Quantity updated as of 1/29/2014: 3 left (buyer bought 1 from Garden Grove, CA, United States )
Edited by Lyen on Sun Jun 22, 2014 1:22 am.
Items For Sale
Lyen
Revision 35: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: December 14th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 11/8/2012: 49 left (buyer bought 1 from Sydney, New South Wales, Australia )
Quantity updated as of 11/21/2012: 48 left (buyer bought 1 from Nottingham, Nottinghamshire, United Kingdom )
Quantity updated as of 12/7/2012: 47 left (buyer bought 1 from Võru, Võrumaa, Estonia )
Quantity updated as of 12/27/2012: 46 left (buyer bought 1 from Tjodalyng, Norway )
Quantity updated as of 12/29/2012: 45 left (buyer bought 1 from Bell Gardens, CA )
Quantity updated as of 1/19/2013: 44 left (buyer bought 1 from Vladivostok, Primorskiy kray, Russia )
Quantity updated as of 1/21/2013: 43 left (buyer bought 1 from Saint-Petersburg, Saint-Petersburg, Russia )
Quantity updated as of 1/31/2013: 42 left (buyer bought 1 from Merkez, KÜTAHYA, Turkey )
Quantity updated as of 3/13/2013: 41 left (buyer bought 1 from Portland, OR )
Quantity updated as of 3/18/2013: 40 left (buyer bought 1 from Frankston, Victoria, Australia )
Quantity updated as of 3/25/2013: 39 left (buyer bought 1 from Bologoye, Tver, Russia )
Quantity updated as of 4/1/2013: 38 left (buyer bought 1 from Calgary, Alberta,Canada )
Quantity updated as of 4/18/2013: 36 left (buyer bought 2 from Cardiff, United Kingdom )
Quantity updated as of 5/3/2013: 34 left (buyer bought 2 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 5/9/2013: 33 left (buyer bought 1 from Viseu, Portugal )
Quantity updated as of 5/11/2013: 32 left (buyer bought 1 from Toronto, Ontario, Canada )
Quantity updated as of 6/7/2013: 31 left (buyer bought 1 from Manhattan Beach, CA )
Quantity updated as of 6/13/2013: 30 left (buyer bought 1 from Erie, PA )
Quantity updated as of 6/13/2013: 29 left (buyer bought 1 from Oakland, CA )
Quantity updated as of 6/18/2013: 28 left (buyer bought 1 from Philippi, WV )
Quantity updated as of 6/18/2013: 27 left (buyer bought 1 from Sylling, Norway )
Quantity updated as of 6/21/2013: 26 left (buyer bought 1 from Thomasville, GA )
Quantity updated as of 6/22/2013: 25 left (buyer bought 1 from Unionville, Ontario, Canada)
Quantity updated as of 7/7/2013: 24 left (buyer bought 1 from Korea, Seoul, South Korea )
Quantity updated as of 7/27/2013: 23 left (buyer bought 1 from Philadelphia , PA, United States )
Quantity updated as of 8/11/2013: 22 left (buyer bought 1 from Philadelphia , PA )
Quantity updated as of 8/15/2013: 21 left (buyer bought 1 from Porta Westfalica, Neesen, Germany )
Quantity updated as of 8/19/2013: 20 left (buyer bought 1 from Portland, OR )
Quantity updated as of 8/20/2013: 19 left (buyer bought 1 from Avellino, Montoro Inferiore, Italy )
Quantity updated as of 8/23/2013: 18 left (buyer bought 1 from SURREY B.C., Canada )
Quantity updated as of 8/23/2013: 17 left (buyer bought 1 from San Francisco, CA, United States )
Quantity updated as of 8/31/2013: 13 left (buyer bought 4 from Philadelphia , PA, United States )
Quantity updated as of 9/1/2013: 12 left (buyer bought 1 from Torvastad, Norway )
Quantity updated as of 9/19/2013: 11 left (buyer bought 1 from New York, NY, United States )
Quantity updated as of 9/25/2013: 10 left (buyer bought 1 from Rancho Cordova, CA, United States )
Quantity updated as of 9/27/2013: 9 left (buyer bought 1 from Moscow, MO, Russia )
Quantity updated as of 9/29/2013: 8 left (buyer bought 1 from Kirn Dunoon , Scotland, United Kingdom )
Quantity updated as of 10/2/2013: 7 left (buyer bought 1 from Stream wood, IL, United States )
Quantity updated as of 10/8/2013: 6 left (buyer bought 1 from Toms River, NJ, United States)
Quantity updated as of 10/31/2013: 5 left (buyer bought 1 from Izhevsk, UR, Russia)
Quantity updated as of 11/14/2013: 4 left (buyer bought 1 from Valbonne, France)
Quantity updated as of 11/17/2013: 3 left (buyer bought 1 from Pretoria, Gauteng South Africa)
Edited by Lyen on Sat Dec 14, 2013 7:09 pm.
Items For Sale
Lyen
Revision 34: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: December 5th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Edited by Lyen on Thu Dec 05, 2013 5:44 pm.
Items For Sale
Lyen
Revision 33: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: November 7th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 11/2/2012: 49 left (buyer bought 1 from kitchener, Ontario, Canada )
Quantity updated as of 11/2/2012 : 47 left (buyer bought 2 from Ekaterinburg, Sverdlovsk Oblast, Russia )
Quantity updated as of 11/8/2012: 46 left (buyer bought 1 from Sydney, New South Wales, Australia )
Quantity updated as of 11/21/2012: 45 left (buyer bought 1 from Nottingham, Nottinghamshire, United Kingdom )
Quantity updated as of 12/7/2012: 44 left (buyer bought 1 from Võru, Võrumaa, Estonia )
Quantity updated as of 12/27/2012: 43 left (buyer bought 1 from Tjodalyng, Norway )
Quantity updated as of 12/29/2012: 42 left (buyer bought 1 from Bell Gardens, CA )
Quantity updated as of 1/19/2013: 41 left (buyer bought 1 from Vladivostok, Primorskiy kray, Russia )
Quantity updated as of 1/21/2013: 40 left (buyer bought 1 from Saint-Petersburg, Saint-Petersburg, Russia )
Quantity updated as of 1/31/2013: 39 left (buyer bought 1 from Merkez, KÜTAHYA, Turkey )
Quantity updated as of 3/13/2013: 38 left (buyer bought 1 from Portland, OR )
Quantity updated as of 3/18/2013: 37 left (buyer bought 1 from Frankston, Victoria, Australia )
Quantity updated as of 3/25/2013: 36 left (buyer bought 1 from Bologoye, Tver, Russia )
Quantity updated as of 4/1/2013: 35 left (buyer bought 1 from Calgary, Alberta,Canada )
Quantity updated as of 4/18/2013: 33 left (buyer bought 2 from Cardiff, United Kingdom )
Quantity updated as of 5/3/2013: 31 left (buyer bought 2 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 5/9/2013: 30 left (buyer bought 1 from Viseu, Portugal )
Quantity updated as of 5/11/2013: 29 left (buyer bought 1 from Toronto, Ontario, Canada )
Quantity updated as of 6/7/2013: 28 left (buyer bought 1 from Manhattan Beach, CA )
Quantity updated as of 6/13/2013: 27 left (buyer bought 1 from Erie, PA )
Quantity updated as of 6/13/2013: 26 left (buyer bought 1 from Oakland, CA )
Quantity updated as of 6/18/2013: 25 left (buyer bought 1 from Philippi, WV )
Quantity updated as of 6/18/2013: 24 left (buyer bought 1 from Sylling, Norway )
Quantity updated as of 6/21/2013: 23 left (buyer bought 1 from Thomasville, GA )
Quantity updated as of 6/22/2013: 22 left (buyer bought 1 from Unionville, Ontario, Canada)
Quantity updated as of 7/7/2013: 21 left (buyer bought 1 from Korea, Seoul, South Korea )
Quantity updated as of 7/27/2013: 20 left (buyer bought 1 from Philadelphia , PA, United States )
Quantity updated as of 8/11/2013: 19 left (buyer bought 1 from Philadelphia , PA )
Quantity updated as of 8/15/2013: 18 left (buyer bought 1 from Porta Westfalica, Neesen, Germany )
Quantity updated as of 8/19/2013: 17 left (buyer bought 1 from Portland, OR )
Quantity updated as of 8/20/2013: 16 left (buyer bought 1 from Avellino, Montoro Inferiore, Italy )
Quantity updated as of 8/23/2013: 15 left (buyer bought 1 from SURREY B.C., Canada )
Quantity updated as of 8/23/2013: 14 left (buyer bought 1 from San Francisco, CA, United States )
Quantity updated as of 8/31/2013: 10 left (buyer bought 4 from Philadelphia , PA, United States )
Quantity updated as of 9/1/2013: 9 left (buyer bought 1 from Torvastad, Norway )
Quantity updated as of 9/19/2013: 8 left (buyer bought 1 from New York, NY, United States )
Quantity updated as of 9/25/2013: 7 left (buyer bought 1 from Rancho Cordova, CA, United States )
Quantity updated as of 9/27/2013: 6 left (buyer bought 1 from Moscow, MO, Russia )
Quantity updated as of 9/29/2013: 5 left (buyer bought 1 from Kirn Dunoon , Scotland, United Kingdom )
Quantity updated as of 10/2/2013: 4 left (buyer bought 1 from Stream wood, IL, United States )
Quantity updated as of 10/8/2013: 3 left (buyer bought 1 from Toms River, NJ, United States)
Quantity updated as of 10/31/2013: 2 left (buyer bought 1 from Izhevsk, UR, Russia)
Edited by Lyen on Thu Nov 07, 2013 5:39 pm.
Items For Sale
Lyen
Revision 32: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: October 24th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Edited by Lyen on Thu Oct 24, 2013 5:47 pm.
Items For Sale
Lyen
Revision 31: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: October 10th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Edited by Lyen on Thu Oct 10, 2013 6:08 pm.
Items For Sale
Lyen
Revision 30: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
I have only 45 made since I am busy working on my other ebike projects. My intention for selling at such low price is to share the fun with other ES forum members instead of making them jealous. :wink: I finally understand why Methods mentioned the cost of labor is steep after all this and I have to agree with him from now on. These controllers are not generic controllers. I have every single one serialized. Quantity is limited, buy it now and upgrade later once your piggy bank is filled up if needed. :lol:
1. CA connector
Update: September 19th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 11/2/2012: 45 left (buyer bought 1 from Stockholm, Solna, Sweden )
Quantity updated as of 11/2/2012: 44 left (buyer bought 1 from kitchener, Ontario, Canada )
Quantity updated as of 11/2/2012 : 42 left (buyer bought 2 from Ekaterinburg, Sverdlovsk Oblast, Russia )
Quantity updated as of 11/8/2012: 41 left (buyer bought 1 from Sydney, New South Wales, Australia )
Quantity updated as of 11/21/2012: 40 left (buyer bought 1 from Nottingham, Nottinghamshire, United Kingdom )
Quantity updated as of 12/7/2012: 39 left (buyer bought 1 from Võru, Võrumaa, Estonia )
Quantity updated as of 12/27/2012: 38 left (buyer bought 1 from Tjodalyng, Norway )
Quantity updated as of 12/29/2012: 37 left (buyer bought 1 from Bell Gardens, CA )
Quantity updated as of 1/19/2013: 36 left (buyer bought 1 from Vladivostok, Primorskiy kray, Russia )
Quantity updated as of 1/21/2013: 35 left (buyer bought 1 from Saint-Petersburg, Saint-Petersburg, Russia )
Quantity updated as of 1/31/2013: 34 left (buyer bought 1 from Merkez, KÜTAHYA, Turkey )
Quantity updated as of 3/13/2013: 33 left (buyer bought 1 from Portland, OR )
Quantity updated as of 3/18/2013: 32 left (buyer bought 1 from Frankston, Victoria, Australia )
Quantity updated as of 3/25/2013: 31 left (buyer bought 1 from Bologoye, Tver, Russia )
Quantity updated as of 4/1/2013: 30 left (buyer bought 1 from Calgary, Alberta,Canada )
Quantity updated as of 4/18/2013: 28 left (buyer bought 2 from Cardiff, United Kingdom )
Quantity updated as of 5/3/2013: 26 left (buyer bought 2 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 5/9/2013: 25 left (buyer bought 1 from Viseu, Portugal )
Quantity updated as of 5/11/2013: 24 left (buyer bought 1 from Toronto, Ontario, Canada )
Quantity updated as of 6/7/2013: 23 left (buyer bought 1 from Manhattan Beach, CA )
Quantity updated as of 6/13/2013: 22 left (buyer bought 1 from Erie, PA )
Quantity updated as of 6/13/2013: 21 left (buyer bought 1 from Oakland, CA )
Quantity updated as of 6/18/2013: 20 left (buyer bought 1 from Philippi, WV )
Quantity updated as of 6/18/2013: 19 left (buyer bought 1 from Sylling, Norway )
Quantity updated as of 6/21/2013: 18 left (buyer bought 1 from Thomasville, GA )
Quantity updated as of 6/22/2013: 17 left (buyer bought 1 from Unionville, Ontario, Canada)
Quantity updated as of 7/7/2013: 16 left (buyer bought 1 from Korea, Seoul, South Korea )
Quantity updated as of 7/27/2013: 15 left (buyer bought 1 from Philadelphia , PA, United States )
Quantity updated as of 8/11/2013: 14 left (buyer bought 1 from Philadelphia , PA )
Quantity updated as of 8/15/2013: 13 left (buyer bought 1 from Porta Westfalica, Neesen, Germany )
Quantity updated as of 8/19/2013: 12 left (buyer bought 1 from Portland, OR )
Quantity updated as of 8/20/2013: 11 left (buyer bought 1 from Avellino, Montoro Inferiore, Italy )
Quantity updated as of 8/23/2013: 10 left (buyer bought 1 from SURREY B.C., Canada )
Quantity updated as of 8/23/2013: 9 left (buyer bought 1 from San Francisco, CA, United States )
Quantity updated as of 8/31/2013: 5 left (buyer bought 4 from Philadelphia , PA, United States )
Quantity updated as of 9/1/2013: 4 left (buyer bought 1 from Torvastad, Norway )
Quantity updated as of 9/19/2013: 3 left (buyer bought 1 from New York, NY, United States )
Quantity updated as of 9/25/2013: 2 left (buyer bought 1 from Rancho Cordova, CA, United States )
Edited by Lyen on Thu Sep 26, 2013 6:57 pm.
Items For Sale
Lyen
Revision 29: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Quantity updated as of 10/13/2012: 44 left (buyer bought 1 from Dana point, CA )
Quantity updated as of 11/2/2012: 43 left (buyer bought 1 from Stockholm, Solna, Sweden )
Quantity updated as of 11/2/2012: 42 left (buyer bought 1 from kitchener, Ontario, Canada )
Quantity updated as of 11/2/2012 : 40 left (buyer bought 2 from Ekaterinburg, Sverdlovsk Oblast, Russia )
Quantity updated as of 11/8/2012: 39 left (buyer bought 1 from Sydney, New South Wales, Australia )
Quantity updated as of 11/21/2012: 38 left (buyer bought 1 from Nottingham, Nottinghamshire, United Kingdom )
Quantity updated as of 12/7/2012: 37 left (buyer bought 1 from Võru, Võrumaa, Estonia )
Quantity updated as of 12/27/2012: 36 left (buyer bought 1 from Tjodalyng, Norway )
Quantity updated as of 12/29/2012: 35 left (buyer bought 1 from Bell Gardens, CA )
Quantity updated as of 1/19/2013: 34 left (buyer bought 1 from Vladivostok, Primorskiy kray, Russia )
Quantity updated as of 1/21/2013: 33 left (buyer bought 1 from Saint-Petersburg, Saint-Petersburg, Russia )
Quantity updated as of 1/31/2013: 32 left (buyer bought 1 from Merkez, KÜTAHYA, Turkey )
Quantity updated as of 3/13/2013: 31 left (buyer bought 1 from Portland, OR )
Quantity updated as of 3/18/2013: 30 left (buyer bought 1 from Frankston, Victoria, Australia )
Quantity updated as of 3/25/2013: 29 left (buyer bought 1 from Bologoye, Tver, Russia )
Quantity updated as of 4/1/2013: 28 left (buyer bought 1 from Calgary, Alberta,Canada )
Quantity updated as of 4/18/2013: 26 left (buyer bought 2 from Cardiff, United Kingdom )
Quantity updated as of 5/3/2013: 24 left (buyer bought 2 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 5/9/2013: 23 left (buyer bought 1 from Viseu, Portugal )
Quantity updated as of 5/11/2013: 22 left (buyer bought 1 from Toronto, Ontario, Canada )
Quantity updated as of 6/7/2013: 21 left (buyer bought 1 from Manhattan Beach, CA )
Quantity updated as of 6/13/2013: 20 left (buyer bought 1 from Erie, PA )
Quantity updated as of 6/13/2013: 19 left (buyer bought 1 from Oakland, CA )
Quantity updated as of 6/18/2013: 18 left (buyer bought 1 from Philippi, WV )
Quantity updated as of 6/18/2013: 17 left (buyer bought 1 from Sylling, Norway )
Quantity updated as of 6/21/2013: 16 left (buyer bought 1 from Thomasville, GA )
Quantity updated as of 6/22/2013: 15 left (buyer bought 1 from Unionville, Ontario, Canada)
Quantity updated as of 7/7/2013: 14 left (buyer bought 1 from Korea, Seoul, South Korea )
Quantity updated as of 7/27/2013: 13 left (buyer bought 1 from Philadelphia , PA, United States )
Quantity updated as of 8/11/2013: 12 left (buyer bought 1 from Philadelphia , PA )
Quantity updated as of 8/15/2013: 11 left (buyer bought 1 from Porta Westfalica, Neesen, Germany )
Quantity updated as of 8/19/2013: 10 left (buyer bought 1 from Portland, OR )
Quantity updated as of 8/20/2013: 9 left (buyer bought 1 from Avellino, Montoro Inferiore, Italy )
Quantity updated as of 8/23/2013: 8 left (buyer bought 1 from SURREY B.C., Canada )
Quantity updated as of 8/23/2013: 7 left (buyer bought 1 from San Francisco, CA, United States )
Quantity updated as of 8/31/2013: 3 left (buyer bought 4 from Philadelphia , PA, United States )
Quantity updated as of 9/1/2013: 2 left (buyer bought 1 from Torvastad, Norway )
Quantity updated as of 9/19/2013: 1 left (buyer bought 1 from New York, NY, United States )
Edited by Lyen on Sat Sep 21, 2013 5:39 pm.
Items For Sale
Lyen
Revision 28: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Edited by Lyen on Thu Sep 19, 2013 5:40 pm.
Items For Sale
Lyen
Revision 27: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: September 14th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Edited by Lyen on Sat Sep 14, 2013 11:44 am.
Items For Sale
Lyen
Revision 26: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: September 5th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Edited by Lyen on Thu Sep 05, 2013 5:20 pm.
Items For Sale
Lyen
Revision 25: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: September 3rd, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Edited by Lyen on Tue Sep 03, 2013 7:16 pm.
Items For Sale
Lyen
Revision 24: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: August 31th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Edited by Lyen on Sat Aug 31, 2013 7:26 pm.
Items For Sale
Lyen
Revision 23: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
I have only 40 made since I am busy working on my other ebike projects. My intention for selling at such low price is to share the fun with other ES forum members instead of making them jealous. :wink: I finally understand why Methods mentioned the cost of labor is steep after all this and I have to agree with him from now on. These controllers are not generic controllers. I have every single one serialized. Quantity is limited, buy it now and upgrade later once your piggy bank is filled up if needed. :lol:
1. CA connector
Update: August 22nd, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 9/19/2012 : 39 left (buyer bought 1 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 10/8/2012: 38 left (buyer bought 1 from Athens, Greece )
Quantity updated as of 10/13/2012: 37 left (buyer bought 1 from Dana point, CA )
Quantity updated as of 11/2/2012: 36 left (buyer bought 1 from Stockholm, Solna, Sweden )
Quantity updated as of 11/2/2012: 35 left (buyer bought 1 from kitchener, Ontario, Canada )
Quantity updated as of 11/2/2012 : 33 left (buyer bought 2 from Ekaterinburg, Sverdlovsk Oblast, Russia )
Quantity updated as of 11/8/2012: 32 left (buyer bought 1 from Sydney, New South Wales, Australia )
Quantity updated as of 11/21/2012: 31 left (buyer bought 1 from Nottingham, Nottinghamshire, United Kingdom )
Quantity updated as of 12/7/2012: 30 left (buyer bought 1 from Võru, Võrumaa, Estonia )
Quantity updated as of 12/27/2012: 29 left (buyer bought 1 from Tjodalyng, Norway )
Quantity updated as of 12/29/2012: 28 left (buyer bought 1 from Bell Gardens, CA )
Quantity updated as of 1/19/2013: 27 left (buyer bought 1 from Vladivostok, Primorskiy kray, Russia )
Quantity updated as of 1/21/2013: 26 left (buyer bought 1 from Saint-Petersburg, Saint-Petersburg, Russia )
Quantity updated as of 1/31/2013: 25 left (buyer bought 1 from Merkez, KÜTAHYA, Turkey )
Quantity updated as of 3/13/2013: 24 left (buyer bought 1 from Portland, OR )
Quantity updated as of 3/18/2013: 23 left (buyer bought 1 from Frankston, Victoria, Australia )
Quantity updated as of 3/25/2013: 22 left (buyer bought 1 from Bologoye, Tver, Russia )
Quantity updated as of 4/1/2013: 21 left (buyer bought 1 from Calgary, Alberta,Canada )
Quantity updated as of 4/18/2013: 19 left (buyer bought 2 from Cardiff, United Kingdom )
Quantity updated as of 5/3/2013: 17 left (buyer bought 2 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 5/9/2013: 16 left (buyer bought 1 from Viseu, Portugal )
Quantity updated as of 5/11/2013: 15 left (buyer bought 1 from Toronto, Ontario, Canada )
Quantity updated as of 6/7/2013: 14 left (buyer bought 1 from Manhattan Beach, CA )
Quantity updated as of 6/13/2013: 13 left (buyer bought 1 from Erie, PA )
Quantity updated as of 6/13/2013: 12 left (buyer bought 1 from Oakland, CA )
Quantity updated as of 6/18/2013: 11 left (buyer bought 1 from Philippi, WV )
Quantity updated as of 6/18/2013: 10 left (buyer bought 1 from Sylling, Norway )
Quantity updated as of 6/21/2013: 9 left (buyer bought 1 from Thomasville, GA )
Quantity updated as of 6/22/2013: 8 left (buyer bought 1 from Unionville, Ontario, Canada)
Quantity updated as of 7/7/2013: 7 left (buyer bought 1 from Korea, Seoul, South Korea )
Quantity updated as of 7/27/2013: 6 left (buyer bought 1 from Philadelphia , PA, United States )
Quantity updated as of 8/11/2013: 5 left (buyer bought 1 from Philadelphia , PA )
Quantity updated as of 8/15/2013: 4 left (buyer bought 1 from Porta Westfalica, Neesen, Germany )
Quantity updated as of 8/19/2013: 3 left (buyer bought 1 from Portland, OR )
Quantity updated as of 8/20/2013: 2 left (buyer bought 1 from Avellino, Montoro Inferiore, Italy )
Edited by Lyen on Thu Aug 22, 2013 1:22 pm.
Items For Sale
Lyen
Revision 22: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
I have only 35 made since I am busy working on my other ebike projects. My intention for selling at such low price is to share the fun with other ES forum members instead of making them jealous. :wink: I finally understand why Methods mentioned the cost of labor is steep after all this and I have to agree with him from now on. These controllers are not generic controllers. I have every single one serialized. Quantity is limited, buy it now and upgrade later once your piggy bank is filled up if needed. :lol:
1. CA connector
Update: August 3rd, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 9/04/2012 : 34 left (buyer bought 1 from Izhevsk, UR, Russia)
Quantity updated as of 9/9/2012 : 33 left (buyer bought 1 from Fremont, OH )
Quantity updated as of 9/19/2012 : 32 left (buyer bought 1 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 10/8/2012: 31 left (buyer bought 1 from Athens, Greece )
Quantity updated as of 10/13/2012: 30 left (buyer bought 1 from Dana point, CA )
Quantity updated as of 11/2/2012: 29 left (buyer bought 1 from Stockholm, Solna, Sweden )
Quantity updated as of 11/2/2012: 28 left (buyer bought 1 from kitchener, Ontario, Canada )
Quantity updated as of 11/2/2012 : 27 left (buyer bought 2 from Ekaterinburg, Sverdlovsk Oblast, Russia )
Quantity updated as of 11/8/2012: 26 left (buyer bought 1 from Sydney, New South Wales, Australia )
Quantity updated as of 11/21/2012: 25 left (buyer bought 1 from Nottingham, Nottinghamshire, United Kingdom )
Quantity updated as of 12/7/2012: 24 left (buyer bought 1 from Võru, Võrumaa, Estonia )
Quantity updated as of 12/27/2012: 23 left (buyer bought 1 from Tjodalyng, Norway )
Quantity updated as of 12/29/2012: 22 left (buyer bought 1 from Bell Gardens, CA )
Quantity updated as of 1/19/2013: 21 left (buyer bought 1 from Vladivostok, Primorskiy kray, Russia )
Quantity updated as of 1/21/2013: 20 left (buyer bought 1 from Saint-Petersburg, Saint-Petersburg, Russia )
Quantity updated as of 1/31/2013: 19 left (buyer bought 1 from Merkez, KÜTAHYA, Turkey )
Quantity updated as of 3/13/2013: 18 left (buyer bought 1 from Portland, OR )
Quantity updated as of 3/18/2013: 17 left (buyer bought 1 from Frankston, Victoria, Australia )
Quantity updated as of 3/25/2013: 16 left (buyer bought 1 from Bologoye, Tver, Russia )
Quantity updated as of 4/1/2013: 15 left (buyer bought 1 from Calgary, Alberta,Canada )
Quantity updated as of 4/18/2013: 14 left (buyer bought 2 from Cardiff, United Kingdom )
Quantity updated as of 5/3/2013: 13 left (buyer bought 2 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 5/9/2013: 12 left (buyer bought 1 from Viseu, Portugal )
Quantity updated as of 5/11/2013: 11 left (buyer bought 1 from Toronto, Ontario, Canada )
Quantity updated as of 6/7/2013: 10 left (buyer bought 1 from Manhattan Beach, CA )
Quantity updated as of 6/13/2013: 9 left (buyer bought 1 from Erie, PA )
Quantity updated as of 6/13/2013: 8 left (buyer bought 1 from Oakland, CA )
Quantity updated as of 6/18/2013: 7 left (buyer bought 1 from Philippi, WV )
Quantity updated as of 6/18/2013: 6 left (buyer bought 1 from Sylling, Norway )
Quantity updated as of 6/21/2013: 5 left (buyer bought 1 from Thomasville, GA )
Quantity updated as of 6/22/2013: 4 left (buyer bought 1 from Unionville, Ontario, Canada)
Quantity updated as of 7/7/2013: 3 left (buyer bought 1 from Korea, Seoul, South Korea )
Quantity updated as of 7/27/2013: 2 left (buyer bought 1 from Philadelphia , PA, United States )
Edited by Lyen on Sat Aug 03, 2013 5:51 pm.
Items For Sale
Lyen
Revision 21: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: July 27th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Edited by Lyen on Sat Jul 27, 2013 5:48 pm.
Items For Sale
Lyen
Revision 20: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: July 18th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Edited by Lyen on Thu Jul 18, 2013 6:28 pm.
Items For Sale
Lyen
Revision 19: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: June 18th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 5/12/2012 : 37 left (buyer bought 3 from Portland, OR)
Quantity updated as of 5/17/2012 : 36 left (buyer bought 1 from Los Angeles, CA )
Quantity updated as of 5/18/2012 : 35 left (buyer bought 1 from SANTA CLARA, CA)
Quantity updated as of 6/05/2012 : 34 left (buyer bought 1 from Jackson, NJ )
Quantity updated as of 9/04/2012 : 33 left (buyer bought 1 from Izhevsk, UR, Russia)
Quantity updated as of 9/9/2012 : 32 left (buyer bought 1 from Fremont, OH )
Quantity updated as of 9/19/2012 : 31 left (buyer bought 1 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 10/8/2012: 30 left (buyer bought 1 from Athens, Greece )
Quantity updated as of 10/13/2012: 29 left (buyer bought 1 from Dana point, CA )
Quantity updated as of 11/2/2012: 28 left (buyer bought 1 from Stockholm, Solna, Sweden )
Quantity updated as of 11/2/2012: 27 left (buyer bought 1 from kitchener, Ontario, Canada )
Quantity updated as of 11/2/2012 : 25 left (buyer bought 2 from Ekaterinburg, Sverdlovsk Oblast, Russia )
Quantity updated as of 11/8/2012: 24 left (buyer bought 1 from Sydney, New South Wales, Australia )
Quantity updated as of 11/21/2012: 23 left (buyer bought 1 from Nottingham, Nottinghamshire, United Kingdom )
Quantity updated as of 12/7/2012: 22 left (buyer bought 1 from Võru, Võrumaa, Estonia )
Quantity updated as of 12/27/2012: 21 left (buyer bought 1 from Tjodalyng, Norway )
Quantity updated as of 12/29/2012: 20 left (buyer bought 1 from Bell Gardens, CA )
Quantity updated as of 1/19/2013: 19 left (buyer bought 1 from Vladivostok, Primorskiy kray, Russia )
Quantity updated as of 1/21/2013: 18 left (buyer bought 1 from Saint-Petersburg, Saint-Petersburg, Russia )
Quantity updated as of 1/31/2013: 17 left (buyer bought 1 from Merkez, KÜTAHYA, Turkey )
Quantity updated as of 3/13/2013: 16 left (buyer bought 1 from Portland, OR )
Quantity updated as of 3/18/2013: 15 left (buyer bought 1 from Frankston, Victoria, Australia )
Quantity updated as of 3/25/2013: 14 left (buyer bought 1 from Bologoye, Tver, Russia )
Quantity updated as of 4/1/2013: 13 left (buyer bought 1 from Calgary, Alberta,Canada )
Quantity updated as of 4/18/2013: 11 left (buyer bought 2 from Cardiff, United Kingdom )
Quantity updated as of 5/3/2013: 9 left (buyer bought 2 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 5/9/2013: 8 left (buyer bought 1 from Viseu, Portugal )
Quantity updated as of 5/11/2013: 7 left (buyer bought 1 from Toronto, Ontario, Canada )
Quantity updated as of 6/7/2013: 6 left (buyer bought 1 from Manhattan Beach, CA )
Quantity updated as of 6/13/2013: 5 left (buyer bought 1 from Erie, PA )
Quantity updated as of 6/13/2013: 4 left (buyer bought 1 from Oakland, CA )
Quantity updated as of 6/18/2013: 3 left (buyer bought 1 from Philippi, WV )
Edited by Lyen on Tue Jun 18, 2013 4:33 pm.
Items For Sale
Lyen
Revision 18: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: June 8th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 3/15/2012 : 39 left (buyer bought 1 from Sofia, Sofia ,Bulgaria)
Quantity updated as of 4/05/2012 : 38 left (buyer bought 1 from KIRYAT MOTSKIN ,Israel)
Quantity updated as of 4/17/2012 : 37 left (buyer bought 1 from Yoqneam Elit ,Israel)
Quantity updated as of 5/02/2012 : 36 left (buyer bought 1 from Fort Walton Beach, FL)
Quantity updated as of 5/12/2012 : 33 left (buyer bought 3 from Portland, OR)
Quantity updated as of 5/17/2012 : 32 left (buyer bought 1 from Los Angeles, CA )
Quantity updated as of 5/18/2012 : 31 left (buyer bought 1 from SANTA CLARA, CA)
Quantity updated as of 6/05/2012 : 30 left (buyer bought 1 from Jackson, NJ )
Quantity updated as of 9/04/2012 : 29 left (buyer bought 1 from Izhevsk, UR, Russia)
Quantity updated as of 9/9/2012 : 28 left (buyer bought 1 from Fremont, OH )
Quantity updated as of 9/19/2012 : 27 left (buyer bought 1 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 10/8/2012: 26 left (buyer bought 1 from Athens, Greece )
Quantity updated as of 10/13/2012: 25 left (buyer bought 1 from Dana point, CA )
Quantity updated as of 11/2/2012: 24 left (buyer bought 1 from Stockholm, Solna, Sweden )
Quantity updated as of 11/2/2012: 23 left (buyer bought 1 from kitchener, Ontario, Canada )
Quantity updated as of 11/2/2012 : 21 left (buyer bought 2 from Ekaterinburg, Sverdlovsk Oblast, Russia )
Quantity updated as of 11/8/2012: 20 left (buyer bought 1 from Sydney, New South Wales, Australia )
Quantity updated as of 11/21/2012: 19 left (buyer bought 1 from Nottingham, Nottinghamshire, United Kingdom )
Quantity updated as of 12/7/2012: 18 left (buyer bought 1 from Võru, Võrumaa, Estonia )
Quantity updated as of 12/27/2012: 17 left (buyer bought 1 from Tjodalyng, Norway )
Quantity updated as of 12/29/2012: 16 left (buyer bought 1 from Bell Gardens, CA )
Quantity updated as of 1/19/2013: 15 left (buyer bought 1 from Vladivostok, Primorskiy kray, Russia )
Quantity updated as of 1/21/2013: 14 left (buyer bought 1 from Saint-Petersburg, Saint-Petersburg, Russia )
Quantity updated as of 1/31/2013: 13 left (buyer bought 1 from Merkez, KÜTAHYA, Turkey )
Quantity updated as of 3/13/2013: 12 left (buyer bought 1 from Portland, OR )
Quantity updated as of 3/18/2013: 11 left (buyer bought 1 from Frankston, Victoria, Australia )
Quantity updated as of 3/25/2013: 10 left (buyer bought 1 from Bologoye, Tver, Russia )
Quantity updated as of 4/1/2013: 9 left (buyer bought 1 from Calgary, Alberta,Canada )
Quantity updated as of 4/18/2013: 7 left (buyer bought 2 from Cardiff, United Kingdom )
Quantity updated as of 5/3/2013: 5 left (buyer bought 2 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 5/9/2013: 4 left (buyer bought 1 from Viseu, Portugal )
Quantity updated as of 5/11/2013: 3 left (buyer bought 1 from Toronto, Ontario, Canada )
Quantity updated as of 6/7/2013: 2 left (buyer bought 1 from Manhattan Beach, CA )
Edited by Lyen on Sat Jun 08, 2013 2:03 pm.
Items For Sale
Lyen
Revision 17: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: May 23rd, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Edited by Lyen on Thu May 23, 2013 1:08 pm.
Items For Sale
Lyen
Revision 16: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: May 2nd, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 2/18/2012 : 34 left (buyer bought 1 from Castro Valley, CA)
Quantity updated as of 3/15/2012 : 33 left (buyer bought 1 from Sofia, Sofia ,Bulgaria)
Quantity updated as of 4/05/2012 : 32 left (buyer bought 1 from KIRYAT MOTSKIN ,Israel)
Quantity updated as of 4/17/2012 : 31 left (buyer bought 1 from Yoqneam Elit ,Israel)
Quantity updated as of 5/02/2012 : 30 left (buyer bought 1 from Fort Walton Beach, FL)
Quantity updated as of 5/12/2012 : 27 left (buyer bought 3 from Portland, OR)
Quantity updated as of 5/17/2012 : 26 left (buyer bought 1 from Los Angeles, CA )
Quantity updated as of 5/18/2012 : 25 left (buyer bought 1 from SANTA CLARA, CA)
Quantity updated as of 6/05/2012 : 24 left (buyer bought 1 from Jackson, NJ )
Quantity updated as of 9/04/2012 : 23 left (buyer bought 1 from Izhevsk, UR, Russia)
Quantity updated as of 9/9/2012 : 22 left (buyer bought 1 from Fremont, OH )
Quantity updated as of 9/19/2012 : 21 left (buyer bought 1 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 10/8/2012: 20 left (buyer bought 1 from Athens, Greece )
Quantity updated as of 10/13/2012: 19 left (buyer bought 1 from Dana point, CA )
Quantity updated as of 11/2/2012: 18 left (buyer bought 1 from Stockholm, Solna, Sweden )
Quantity updated as of 11/2/2012: 17 left (buyer bought 1 from kitchener, Ontario, Canada )
Quantity updated as of 11/2/2012 : 15 left (buyer bought 2 from Ekaterinburg, Sverdlovsk Oblast, Russia )
Quantity updated as of 11/8/2012: 14 left (buyer bought 1 from Sydney, New South Wales, Australia )
Quantity updated as of 11/21/2012: 13 left (buyer bought 1 from Nottingham, Nottinghamshire, United Kingdom )
Quantity updated as of 12/7/2012: 12 left (buyer bought 1 from Võru, Võrumaa, Estonia )
Quantity updated as of 12/27/2012: 11 left (buyer bought 1 from Tjodalyng, Norway )
Quantity updated as of 12/29/2012: 10 left (buyer bought 1 from Bell Gardens, CA )
Quantity updated as of 1/19/2013: 9 left (buyer bought 1 from Vladivostok, Primorskiy kray, Russia )
Quantity updated as of 1/21/2013: 8 left (buyer bought 1 from Saint-Petersburg, Saint-Petersburg, Russia )
Quantity updated as of 1/31/2013: 7 left (buyer bought 1 from Merkez, KÜTAHYA, Turkey )
Quantity updated as of 3/13/2013: 6 left (buyer bought 1 from Portland, OR )
Quantity updated as of 3/18/2013: 5 left (buyer bought 1 from Frankston, Victoria, Australia )
Quantity updated as of 3/25/2013: 4 left (buyer bought 1 from Bologoye, Tver, Russia )
Quantity updated as of 4/1/2013: 3 left (buyer bought 1 from Calgary, Alberta,Canada )
Quantity updated as of 4/18/2013: 1 left (buyer bought 2 from Cardiff, United Kingdom )
Edited by Lyen on Thu May 02, 2013 11:34 am.
Items For Sale
Lyen
Revision 15: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: April 23rd, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Edited by Lyen on Tue Apr 23, 2013 5:24 pm.
Items For Sale
Lyen
Revision 14: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: April 13rd, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 1/24/2012 : 34 left (buyer bought 1 from Peachtree City, GA )
Quantity updated as of 2/18/2012 : 33 left (buyer bought 1 from Chicago, IL )
Quantity updated as of 2/18/2012 : 32 left (buyer bought 1 from Castro Valley, CA)
Quantity updated as of 3/15/2012 : 31 left (buyer bought 1 from Sofia, Sofia ,Bulgaria)
Quantity updated as of 4/05/2012 : 30 left (buyer bought 1 from KIRYAT MOTSKIN ,Israel)
Quantity updated as of 4/17/2012 : 29 left (buyer bought 1 from Yoqneam Elit ,Israel)
Quantity updated as of 5/02/2012 : 28 left (buyer bought 1 from Fort Walton Beach, FL)
Quantity updated as of 5/12/2012 : 25 left (buyer bought 3 from Portland, OR)
Quantity updated as of 5/17/2012 : 24 left (buyer bought 1 from Los Angeles, CA )
Quantity updated as of 5/18/2012 : 23 left (buyer bought 1 from SANTA CLARA, CA)
Quantity updated as of 6/05/2012 : 22 left (buyer bought 1 from Jackson, NJ )
Quantity updated as of 9/04/2012 : 21 left (buyer bought 1 from Izhevsk, UR, Russia)
Quantity updated as of 9/9/2012 : 20 left (buyer bought 1 from Fremont, OH )
Quantity updated as of 9/19/2012 : 19 left (buyer bought 1 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 10/8/2012: 18 left (buyer bought 1 from Athens, Greece )
Quantity updated as of 10/13/2012: 17 left (buyer bought 1 from Dana point, CA )
Quantity updated as of 11/2/2012: 16 left (buyer bought 1 from Stockholm, Solna, Sweden )
Quantity updated as of 11/2/2012: 15 left (buyer bought 1 from kitchener, Ontario, Canada )
Quantity updated as of 11/2/2012 : 13 left (buyer bought 2 from Ekaterinburg, Sverdlovsk Oblast, Russia )
Quantity updated as of 11/8/2012: 12 left (buyer bought 1 from Sydney, New South Wales, Australia )
Quantity updated as of 11/21/2012: 11 left (buyer bought 1 from Nottingham, Nottinghamshire, United Kingdom )
Quantity updated as of 12/7/2012: 10 left (buyer bought 1 from Võru, Võrumaa, Estonia )
Quantity updated as of 12/27/2012: 9 left (buyer bought 1 from Tjodalyng, Norway )
Quantity updated as of 12/29/2012: 8 left (buyer bought 1 from Bell Gardens, CA )
Quantity updated as of 1/19/2013: 7 left (buyer bought 1 from Vladivostok, Primorskiy kray, Russia )
Quantity updated as of 1/21/2013: 6 left (buyer bought 1 from Saint-Petersburg, Saint-Petersburg, Russia )
Quantity updated as of 1/31/2013: 5 left (buyer bought 1 from Merkez, KÜTAHYA, Turkey )
Quantity updated as of 3/13/2013: 4 left (buyer bought 1 from Portland, OR )
Quantity updated as of 3/18/2013: 3 left (buyer bought 1 from Frankston, Victoria, Australia )
Quantity updated as of 3/25/2013: 2 left (buyer bought 1 from Bologoye, Tver, Russia )
Quantity updated as of 4/1/2013: 1 left (buyer bought 1 from Calgary, Alberta,Canada )
Edited by Lyen on Sat Apr 13, 2013 5:40 pm.
Items For Sale
Lyen
Revision 13: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: March 29th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Edited by Lyen on Fri Mar 29, 2013 7:26 pm.
Items For Sale
Lyen
Revision 12: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: March 21st, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 1/12/2012 : 34 left (buyer bought 1 from Camillus, NY)
Quantity updated as of 1/23/2012 : 33 left (buyer bought 1 from birmingham, West Midlands ,United Kingdom)
Quantity updated as of 1/24/2012 : 32 left (buyer bought 1 from Peachtree City, GA )
Quantity updated as of 2/18/2012 : 31 left (buyer bought 1 from Chicago, IL )
Quantity updated as of 2/18/2012 : 30 left (buyer bought 1 from Castro Valley, CA)
Quantity updated as of 3/15/2012 : 29 left (buyer bought 1 from Sofia, Sofia ,Bulgaria)
Quantity updated as of 4/05/2012 : 28 left (buyer bought 1 from KIRYAT MOTSKIN ,Israel)
Quantity updated as of 4/17/2012 : 27 left (buyer bought 1 from Yoqneam Elit ,Israel)
Quantity updated as of 5/02/2012 : 26 left (buyer bought 1 from Fort Walton Beach, FL)
Quantity updated as of 5/12/2012 : 23 left (buyer bought 3 from Portland, OR)
Quantity updated as of 5/17/2012 : 22 left (buyer bought 1 from Los Angeles, CA )
Quantity updated as of 5/18/2012 : 21 left (buyer bought 1 from SANTA CLARA, CA)
Quantity updated as of 6/05/2012 : 20 left (buyer bought 1 from Jackson, NJ )
Quantity updated as of 9/04/2012 : 19 left (buyer bought 1 from Izhevsk, UR, Russia)
Quantity updated as of 9/9/2012 : 18 left (buyer bought 1 from Fremont, OH )
Quantity updated as of 9/19/2012 : 17 left (buyer bought 1 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 10/8/2012: 16 left (buyer bought 1 from Athens, Greece )
Quantity updated as of 10/13/2012: 15 left (buyer bought 1 from Dana point, CA )
Quantity updated as of 11/2/2012: 14 left (buyer bought 1 from Stockholm, Solna, Sweden )
Quantity updated as of 11/2/2012: 13 left (buyer bought 1 from kitchener, Ontario, Canada )
Quantity updated as of 11/2/2012 : 11 left (buyer bought 2 from Ekaterinburg, Sverdlovsk Oblast, Russia )
Quantity updated as of 11/8/2012: 10 left (buyer bought 1 from Sydney, New South Wales, Australia )
Quantity updated as of 11/21/2012: 9 left (buyer bought 1 from Nottingham, Nottinghamshire, United Kingdom )
Quantity updated as of 12/7/2012: 8 left (buyer bought 1 from Võru, Võrumaa, Estonia )
Quantity updated as of 12/27/2012: 7 left (buyer bought 1 from Tjodalyng, Norway )
Quantity updated as of 12/29/2012: 6 left (buyer bought 1 from Bell Gardens, CA )
Quantity updated as of 1/19/2013: 5 left (buyer bought 1 from Vladivostok, Primorskiy kray, Russia )
Quantity updated as of 1/21/2013: 4 left (buyer bought 1 from Saint-Petersburg, Saint-Petersburg, Russia )
Quantity updated as of 1/31/2013: 3 left (buyer bought 1 from Merkez, KÜTAHYA, Turkey )
Quantity updated as of 3/13/2013: 2 left (buyer bought 1 from Portland, OR )
Quantity updated as of 3/18/2013: 1 left (buyer bought 1 from Frankston, Victoria, Australia )
Edited by Lyen on Thu Mar 21, 2013 4:59 pm.
Items For Sale
Lyen
Revision 11: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: March 14th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 12/28/2011@ 5:44 PM PST: 34 left (buyer bought 1 from LUYNES ,France)
Quantity updated as of 1/12/2012 @ 2:09 PM PST: 33 left (buyer bought 1 from Camillus, NY)
Quantity updated as of 1/23/2012 @ 10:25 AM PST: 32 left (buyer bought 1 from birmingham, West Midlands ,United Kingdom)
Quantity updated as of 1/24/2012 @ 5:43 PM PST: 31 left (buyer bought 1 from Peachtree City, GA )
Quantity updated as of 2/18/2012 @ 6:20 AM PST: 30 left (buyer bought 1 from Chicago, IL )
Quantity updated as of 2/18/2012 @ 7:13 AM PST: 29 left (buyer bought 1 from Castro Valley, CA)
Quantity updated as of 3/15/2012 @ 11:36 AM PST: 28 left (buyer bought 1 from Sofia, Sofia ,Bulgaria)
Quantity updated as of 4/05/2012 @ 7:04 PM PST: 27 left (buyer bought 1 from KIRYAT MOTSKIN ,Israel)
Quantity updated as of 4/17/2012 @ 1:25 PM PST: 26 left (buyer bought 1 from Yoqneam Elit ,Israel)
Quantity updated as of 5/02/2012 @ 6:43 AM PST: 25 left (buyer bought 1 from Fort Walton Beach, FL)
Quantity updated as of 5/12/2012 @ 9:15 PM PST: 22 left (buyer bought 3 from Portland, OR)
Quantity updated as of 5/17/2012 @ 4:10 PM PST: 21 left (buyer bought 1 from Los Angeles, CA )
Quantity updated as of 5/18/2012 @ 5:15 AM PST: 20 left (buyer bought 1 from SANTA CLARA, CA)
Quantity updated as of 6/05/2012 @ 7:58 PM PST: 19 left (buyer bought 1 from Jackson, NJ )
Quantity updated as of 9/04/2012 @ 9:49 PM PST: 18 left (buyer bought 1 from Izhevsk, UR, Russia)
Quantity updated as of 9/9/2012 @ 2:01 AM PST: 17 left (buyer bought 1 from Fremont, OH )
Quantity updated as of 9/19/2012 @ 4:00 AM PST: 16 left (buyer bought 1 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 10/8/2012@ 7:00 PM PST: 15 left (buyer bought 1 from Athens, Greece )
Quantity updated as of 10/13/2012@ 9:09 AM PST: 14 left (buyer bought 1 from Dana point, CA )
Quantity updated as of 11/2/2012@ 12:24 PM PST: 13 left (buyer bought 1 from Stockholm, Solna, Sweden )
Quantity updated as of 11/2/2012@ 6:44 PM PST: 12 left (buyer bought 1 from kitchener, Ontario, Canada )
Quantity updated as of 11/2/2012 @ 4:00 AM PST: 10 left (buyer bought 2 from Ekaterinburg, Sverdlovsk Oblast, Russia )
Quantity updated as of 11/8/2012@ 1:15 PM PST: 9 left (buyer bought 1 from Sydney, New South Wales, Australia )
Quantity updated as of 11/21/2012@ 13:34 PM PST: 8 left (buyer bought 1 from Nottingham, Nottinghamshire, United Kingdom )
Quantity updated as of 12/7/2012@ 3:04 PM PST: 7 left (buyer bought 1 from Võru, Võrumaa, Estonia )
Quantity updated as of 12/27/2012@ 6:00 PM PST: 6 left (buyer bought 1 from Tjodalyng, Norway )
Quantity updated as of 12/29/2012@ 9:10 PM PST: 5 left (buyer bought 1 from Bell Gardens, CA )
Quantity updated as of 1/19/2013@ 2:20 PM PST: 4 left (buyer bought 1 from Vladivostok, Primorskiy kray, Russia )
Quantity updated as of 1/21/2013@ 7:40 PM PST: 3 left (buyer bought 1 from Saint-Petersburg, Saint-Petersburg, Russia )
Quantity updated as of 1/31/2013@ 4:30 PM PST: 2 left (buyer bought 1 from Merkez, KÜTAHYA, Turkey )
Quantity updated as of 3/13/2013@ 4:30 PM PST: 1 left (buyer bought 1 from Portland, OR )
Edited by Lyen on Thu Mar 14, 2013 6:35 pm.
Items For Sale
Lyen
Revision 10: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
Postby Lyen » Tue Mar 16, 2010 6:16 pm
These are newly hand assembled Infineon 9 FET controllers I am selling, they are new and never used. It is originally designed for long distance commute in the San Francisco area. It is also best to be used on electric bikes with smaller wheels such as those 16" to 20" wheels found on most folding bikes & scooter style ebikes for more speed. For those who owns battery packs with 10-15Ah in capacity this is the controller for you to avoid getting the battery management system circuitry (BMS) tripped or experience power protection shutdown enabling due to insufficient current flow (low discharge rate) available from the battery and low amperage designs in most 10-15Ah capacity battery packs.
The controller is like a wolf in sheep's skin because it is under tuned in order to optimize for long range. There are lots of potential and features you can unveil and twist as you go. You can program functions such as enable power regeneration, regenerate braking, pulse width modulation, low voltage cut-off, interface with a Cycle Analyst, and others. You may also add an USB to RS232 serial adapter and connect to the computer for tuning. (Electronics knowledge is required to unleash the potential however)
One unique feature of this controller is that it has an additional speed sensor circuitry built-in with an extra blue wire for output. It is to be used with the scooter style electric bike and electric scooters that have a speedometer in the dashboard. As of April 5th, 2010 the speed sensor wire has been embedded and integrated with the green wire on the CA connector since they both can share the same function now. More practical and less confusion as suggested by previous buyers. :)
If you look carefully in the photos, you will notice this version also uses lock washers to secure the FETs internally and the heat transfer bar outside to place tension against a nut after tightening. It is also to help prevent the nut from loosening. The FETs will get overheated and damaged when detached from the heat-sink which used to be the case from the previous designs.
* For the extremists, you may double and possibly triple the current output to make it a mighty wonder by adding braids wires (http://www.radioshack.com/product/index.jsp?productId=2062744),add solders to beef up the circuit board traces and shunt. It may also be needed to upgrade to larger capacitors, gauge wires for both the battery and the phase wires to the motor. However, if you are going to use a 9C (Nine Continent) motor, It is recommended to maximize the current output at 65A due to the thinner gauge wires being used with the hub motor. There is a potential that any current & voltage combination higher than the current 72V @ 65A will melt the phase wires in the hub motor and cause potential damage. A good observation and one that I think plays a big part in showing why the small 9 FET controllers can seem to pack such a punch when modded. The gate drive circuit in the Infineons I have looks to be pretty similar, certainly the 18 FET circuit doesn't look like it can provide much more gate drive than the 9 FET circuit. My guess is that this is one of the reasons why a well-modified 9 FET controller will seemingly run at upwards of 60 to 70 amps without getting hot; the 9 FET drives the FET gates harder and therefore more efficiently. On my list of things to do one day is acquire some really big FETs and see just what a 9 FET controller can do. I think that, fitted with external FET wiring and shunt, it would easily be capable of running at 65A or more, reliably.
Below is the specification:
Model: EC-094310-LYEN EDITION
Start immediate controller
Chipset: XCKJ8B116A (same chipset being used as in the 18 FET controller)
Circuit board version: EB209-A-3
9 x genuine IRFB 4310 MOSFET N-CH 100V (tested up to 110V before damage) for more information about the FET, click the link below:
http://parts.digikey.com/1/parts/1021134-mosfet-n-ch-100v-140a-220ab-irfb4310.html)
Large 100V 470uF Chengx capacitors equipped (http://dgfoley.en.alibaba.com/product/262853773-209597704/Large_electrolytic_capacitor_CD293_LP_.html)
72V battery optimized (for higher or lower voltage & current such as 24V-100V, you may need to change the resistor network to avoid damage to the LM317 linear voltage regulator)
30A is the current rate (for higher current, you may need to beef up the trace, shunt, and reprogram it via the software)
Low voltage cut-off: 62.5v
Battery and motor phase wires gauge size: 12AWG (High voltage capable wires equipped)
Dimension: 4.84" x 3.4" x 1.75" (123mm x 87mm x 45mm) plus mount extensions
Total weight: 445 gram
In case you want to upgrade it later on to became Methods-proof and Doctorbass-proof, you may need to upgrade the FETs to 4110 to achieve higher current as well as voltage above 100V. We have a friend here Steveo who do awesome controllers upgrade for a fee. :)
I have only 34 made since I am busy working on my other ebike projects. My intention for selling at such low price is to share the fun with other ES forum members instead of making them jealous. :wink: I finally understand why Methods mentioned the cost of labor is steep after all this and I have to agree with him from now on. These controllers are not generic controllers. I have every single one serialized. Quantity is limited, buy it now and upgrade later once your piggy bank is filled up if needed. :lol:
$89 USD free ground shipping in the United States & Canada. For other locations, please PM or email me at LYEN@HOTMAIL.COM. I accept PayPal, cash or money order. The controllers will be shipped out from me in San Francisco, California, USA. I will provide a tracking number and ship it out as soon as I have received the fund.
For only $10 more, I can include the the following:
1. CA connector
2. Regenerative enable/disable (Enabled simply by connect the wires together without the need to open the case)
3. USB-TTL 5 pin connector (for use with the USB-TTL adapter that is sold separate)
I also have the USB-TTL adapter for adjust and alter the controller settings on your computer. It has the extra 5 pin plug and a "SEND" button. It is also compatible with Windows XP/Vista/7 32/64 bit operating system (real 32/64bit drivers). $15 with purchase, $20 if purchase separately.
You may click on the PayPal Buy It Now link below. For accessories, please send money via PayPal or send me a private message for the total price. Thanks!
https://www.paypal.com/cgi-bin/webscr?c ... MY46WP98CG
If you are not satisfy with the results or if it is too fast for you, you may send it back to me within 30 days in an unmodified condition.
Update: February 14th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 12/28/2011@ 5:44 PM PST: 33 left (buyer bought 1 from LUYNES ,France)
Quantity updated as of 1/12/2012 @ 2:09 PM PST: 32 left (buyer bought 1 from Camillus, NY)
Quantity updated as of 1/23/2012 @ 10:25 AM PST: 31 left (buyer bought 1 from birmingham, West Midlands ,United Kingdom)
Quantity updated as of 1/24/2012 @ 5:43 PM PST: 30 left (buyer bought 1 from Peachtree City, GA )
Quantity updated as of 2/18/2012 @ 6:20 AM PST: 29 left (buyer bought 1 from Chicago, IL )
Quantity updated as of 2/18/2012 @ 7:13 AM PST: 28 left (buyer bought 1 from Castro Valley, CA)
Quantity updated as of 3/15/2012 @ 11:36 AM PST: 27 left (buyer bought 1 from Sofia, Sofia ,Bulgaria)
Quantity updated as of 4/05/2012 @ 7:04 PM PST: 26 left (buyer bought 1 from KIRYAT MOTSKIN ,Israel)
Quantity updated as of 4/17/2012 @ 1:25 PM PST: 25 left (buyer bought 1 from Yoqneam Elit ,Israel)
Quantity updated as of 5/02/2012 @ 6:43 AM PST: 24 left (buyer bought 1 from Fort Walton Beach, FL)
Quantity updated as of 5/12/2012 @ 9:15 PM PST: 21 left (buyer bought 3 from Portland, OR)
Quantity updated as of 5/17/2012 @ 4:10 PM PST: 20 left (buyer bought 1from Los Angeles, CA )
Quantity updated as of 5/18/2012 @ 5:15 AM PST: 19 left (buyer bought 1from SANTA CLARA, CA)
Quantity updated as of 6/05/2012 @ 7:58 PM PST: 18 left (buyer bought 1from Jackson, NJ )
Quantity updated as of 9/04/2012 @ 9:49 PM PST: 17 left (buyer bought 1 from Izhevsk, UR, Russia)
Quantity updated as of 9/9/2012 @ 2:01 AM PST: 16 left (buyer bought 1 from Fremont, OH )
Quantity updated as of 9/19/2012 @ 4:00 AM PST: 15 left (buyer bought 1 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 10/8/2012@ 7:00 PM PST: 14 left (buyer bought 1 from Athens, Greece )
Quantity updated as of 10/13/2012@ 9:09 AM PST: 13 left (buyer bought 1 from Dana point, CA )
Quantity updated as of 11/2/2012@ 12:24 PM PST: 12 left (buyer bought 1 from Stockholm, Solna, Sweden )
Quantity updated as of 11/2/2012@ 6:44 PM PST: 11 left (buyer bought 1 from kitchener, Ontario, Canada )
Quantity updated as of 11/2/2012 @ 4:00 AM PST: 9 left (buyer bought 2 from Ekaterinburg, Sverdlovsk Oblast, Russia )
Quantity updated as of 11/8/2012@ 1:15 PM PST: 8 left (buyer bought 1 from Sydney, New South Wales, Australia )
Quantity updated as of 11/21/2012@ 13:34 PM PST: 7 left (buyer bought 1 from Nottingham, Nottinghamshire, United Kingdom )
Quantity updated as of 12/7/2012@ 3:04 PM PST: 6 left (buyer bought 1 from Võru, Võrumaa, Estonia )
Quantity updated as of 12/27/2012@ 6:00 PM PST: 5 left (buyer bought 1 from Tjodalyng, Norway )
Quantity updated as of 12/29/2012@ 9:10 PM PST: 4 left (buyer bought 1 from Bell Gardens, CA )
Quantity updated as of 1/19/2013@ 2:20 PM PST: 3 left (buyer bought 1 from Vladivostok, Primorskiy kray, Russia )
Quantity updated as of 1/21/2013@ 7:40 PM PST: 2 left (buyer bought 1 from Saint-Petersburg, Saint-Petersburg, Russia )
Quantity updated as of 1/31/2013@ 4:30 PM PST: 1 left (buyer bought 1 from Merkez, KÜTAHYA, Turkey )
Attached are the pictures of the controller. Please allow time for the images to load
For a comparable actual value of controllers using the IRFB4310 MOSFET,check here > http://www.ebikes.ca/store/store_controllers.php and here > http://www.electricbikekitz.com/product_info.php?products_id=47
Additional accessories (prices are reflected with controller purchase only. Please contact if you are interested to buy without controller):
$15 throttle (full/half/thumb) with mated left rubber grip (very good quality) (ebikekit retails @ $36)
$19 cruise control (manually installation required)
$15 three way speed switch (manually installation required)
$15 PAS - Pedal Assist System add-on (manually installation required)
$15 electric brake levers a pair
$29 motor/controller hall/phase/throttle tester
Edited by Lyen on Thu Feb 14, 2013 6:00 pm.
Items For Sale
Please sign up here and donate your marrow to save life.
Lyen
Revision 9: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: February 2nd, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Edited by Lyen on Sat Feb 02, 2013 7:04 pm.
Items For Sale
Lyen
Revision 8: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Quantity updated as of 1/21/2012@ 7:40 PM PST: 2 left (buyer bought 1 from Saint-Petersburg, Saint-Petersburg, Russia )
Edited by Lyen on Sat Feb 02, 2013 6:14 pm.
Items For Sale
Lyen
Revision 7: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
I have only 33 made since I am busy working on my other ebike projects. My intention for selling at such low price is to share the fun with other ES forum members instead of making them jealous. :wink: I finally understand why Methods mentioned the cost of labor is steep after all this and I have to agree with him from now on. These controllers are not generic controllers. I have every single one serialized. Quantity is limited, buy it now and upgrade later once your piggy bank is filled up if needed. :lol:
1. CA connector
Update: January 19th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 12/28/2011@ 5:44 PM PST: 32 left (buyer bought 1 from LUYNES ,France)
Quantity updated as of 1/12/2012 @ 2:09 PM PST: 31 left (buyer bought 1 from Camillus, NY)
Quantity updated as of 1/23/2012 @ 10:25 AM PST: 30 left (buyer bought 1 from birmingham, West Midlands ,United Kingdom)
Quantity updated as of 1/24/2012 @ 5:43 PM PST: 29 left (buyer bought 1 from Peachtree City, GA )
Quantity updated as of 2/18/2012 @ 6:20 AM PST: 28 left (buyer bought 1 from Chicago, IL )
Quantity updated as of 2/18/2012 @ 7:13 AM PST: 27 left (buyer bought 1 from Castro Valley, CA)
Quantity updated as of 3/15/2012 @ 11:36 AM PST: 26 left (buyer bought 1 from Sofia, Sofia ,Bulgaria)
Quantity updated as of 4/05/2012 @ 7:04 PM PST: 25 left (buyer bought 1 from KIRYAT MOTSKIN ,Israel)
Quantity updated as of 4/17/2012 @ 1:25 PM PST: 24 left (buyer bought 1 from Yoqneam Elit ,Israel)
Quantity updated as of 5/02/2012 @ 6:43 AM PST: 23 left (buyer bought 1 from Fort Walton Beach, FL)
Quantity updated as of 5/12/2012 @ 9:15 PM PST: 20 left (buyer bought 3 from Portland, OR)
Quantity updated as of 5/17/2012 @ 4:10 PM PST: 19 left (buyer bought 1from Los Angeles, CA )
Quantity updated as of 5/18/2012 @ 5:15 AM PST: 18 left (buyer bought 1from SANTA CLARA, CA)
Quantity updated as of 6/05/2012 @ 7:58 PM PST: 17 left (buyer bought 1from Jackson, NJ )
Quantity updated as of 9/04/2012 @ 9:49 PM PST: 16 left (buyer bought 1 from Izhevsk, UR, Russia)
Quantity updated as of 9/9/2012 @ 2:01 AM PST: 15 left (buyer bought 1 from Fremont, OH )
Quantity updated as of 9/19/2012 @ 4:00 AM PST: 14 left (buyer bought 1 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 10/8/2012@ 7:00 PM PST: 13 left (buyer bought 1 from Athens, Greece )
Quantity updated as of 10/13/2012@ 9:09 AM PST: 12 left (buyer bought 1 from Dana point, CA )
Quantity updated as of 11/2/2012@ 12:24 PM PST: 11 left (buyer bought 1 from Stockholm, Solna, Sweden )
Quantity updated as of 11/2/2012@ 6:44 PM PST: 10 left (buyer bought 1 from kitchener, Ontario, Canada )
Quantity updated as of 11/2/2012 @ 4:00 AM PST: 8 left (buyer bought 2 from Ekaterinburg, Sverdlovsk Oblast, Russia )
Quantity updated as of 11/8/2012@ 1:15 PM PST: 7 left (buyer bought 1 from Sydney, New South Wales, Australia )
Quantity updated as of 11/21/2012@ 13:34 PM PST: 6 left (buyer bought 1 from Nottingham, Nottinghamshire, United Kingdom )
Quantity updated as of 12/7/2012@ 3:04 PM PST: 5 left (buyer bought 1 from Võru, Võrumaa, Estonia )
Quantity updated as of 12/27/2012@ 6:00 PM PST: 4 left (buyer bought 1 from Tjodalyng, Norway )
Quantity updated as of 12/29/2012@ 9:10 PM PST: 3 left (buyer bought 1 from Bell Gardens, CA )
Quantity updated as of 1/19/2013@ 2:20 PM PST: 2 left (buyer bought 1 from Vladivostok, Primorskiy kray, Russia )
Edited by Lyen on Sat Jan 19, 2013 5:36 pm.
Items For Sale
Lyen
Revision 6: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: January 15th, 2013 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Edited by Lyen on Tue Jan 15, 2013 5:49 pm.
Items For Sale
Lyen
Revision 5: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
I have only 30 made since I am busy working on my other ebike projects. My intention for selling at such low price is to share the fun with other ES forum members instead of making them jealous. :wink: I finally understand why Methods mentioned the cost of labor is steep after all this and I have to agree with him from now on. These controllers are not generic controllers. I have every single one serialized. Quantity is limited, buy it now and upgrade later once your piggy bank is filled up if needed. :lol:
1. CA connector
Update: December 27th, 2012 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 12/28/2011@ 5:44 PM PST: 29 left (buyer bought 1 from LUYNES ,France)
Quantity updated as of 1/12/2012 @ 2:09 PM PST: 28 left (buyer bought 1 from Camillus, NY)
Quantity updated as of 1/23/2012 @ 10:25 AM PST: 27 left (buyer bought 1 from birmingham, West Midlands ,United Kingdom)
Quantity updated as of 1/24/2012 @ 5:43 PM PST: 26 left (buyer bought 1 from Peachtree City, GA )
Quantity updated as of 2/18/2012 @ 6:20 AM PST: 25 left (buyer bought 1 from Chicago, IL )
Quantity updated as of 2/18/2012 @ 7:13 AM PST: 24 left (buyer bought 1 from Castro Valley, CA)
Quantity updated as of 3/15/2012 @ 11:36 AM PST: 23 left (buyer bought 1 from Sofia, Sofia ,Bulgaria)
Quantity updated as of 4/05/2012 @ 7:04 PM PST: 22 left (buyer bought 1 from KIRYAT MOTSKIN ,Israel)
Quantity updated as of 4/17/2012 @ 1:25 PM PST: 21 left (buyer bought 1 from Yoqneam Elit ,Israel)
Quantity updated as of 5/02/2012 @ 6:43 AM PST: 20 left (buyer bought 1 from Fort Walton Beach, FL)
Quantity updated as of 5/12/2012 @ 9:15 PM PST: 17 left (buyer bought 3 from Portland, OR)
Quantity updated as of 5/17/2012 @ 4:10 PM PST: 16 left (buyer bought 1from Los Angeles, CA )
Quantity updated as of 5/18/2012 @ 5:15 AM PST: 15 left (buyer bought 1from SANTA CLARA, CA)
Quantity updated as of 6/05/2012 @ 7:58 PM PST: 14 left (buyer bought 1from Jackson, NJ )
Quantity updated as of 9/04/2012 @ 9:49 PM PST: 13 left (buyer bought 1 from Izhevsk, UR, Russia)
Quantity updated as of 9/9/2012 @ 2:01 AM PST: 12 left (buyer bought 1 from Fremont, OH )
Quantity updated as of 9/19/2012 @ 4:00 AM PST: 11 left (buyer bought 1 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 10/8/2012@ 7:00 PM PST: 10 left (buyer bought 1 from Athens, Greece )
Quantity updated as of 10/13/2012@ 9:09 AM PST: 9 left (buyer bought 1 from Dana point, CA )
Quantity updated as of 11/2/2012@ 12:24 PM PST: 8 left (buyer bought 1 from Stockholm, Solna, Sweden )
Quantity updated as of 11/2/2012@ 6:44 PM PST: 7 left (buyer bought 1 from kitchener, Ontario, Canada )
Quantity updated as of 11/2/2012 @ 4:00 AM PST: 5 left (buyer bought 2 from Ekaterinburg, Sverdlovsk Oblast, Russia )
Quantity updated as of 11/8/2012@ 1:15 PM PST: 4 left (buyer bought 1 from Sydney, New South Wales, Australia )
Quantity updated as of 11/21/2012@ 13:34 PM PST: 3 left (buyer bought 1 from Nottingham, Nottinghamshire, United Kingdom )
Quantity updated as of 12/7/2012@ 3:04 PM PST: 2 left (buyer bought 1 from Võru, Võrumaa, Estonia )
Quantity updated as of 12/27/2012@ 6:00 PM PST: 1 left (buyer bought 1 from Tjodalyng, Norway )
Edited by Lyen on Thu Dec 27, 2012 5:09 pm.
Items For Sale
Lyen
Revision 4: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: December 11st 2012 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 10/13/2012@ 6:04 AM PST: 9 left (buyer bought 1 from Dana point, CA )
Quantity updated as of 11/2/2012@ 12:04 PM PST: 8 left (buyer bought 1 from Stockholm, Solna, Sweden )
Quantity updated as of 11/2/2012@ 6:04 PM PST: 7 left (buyer bought 1 from kitchener, Ontario, Canada )
Quantity updated as of 11/21/2012@ 3:04 PM PST: 3 left (buyer bought 1 from Nottingham , Nottinghamshire, United Kingdom )
Edited by Lyen on Tue Dec 11, 2012 1:30 pm.
Items For Sale
Lyen
Revision 3: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: November 27th 2012 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Edited by Lyen on Tue Nov 27, 2012 6:38 pm.
Items For Sale
Lyen
Revision 2: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Update: June 16 st 2012 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Edited by Lyen on Tue Nov 27, 2012 5:04 pm.
Items For Sale
Lyen
Revision 1: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Quantity updated as of 7/23/2011 @ 7:18 AM PST: 29 left (buyer bought 1 from Клин, Московская обл.Russia)
Quantity updated as of 8/23/2011 @ 3:02 PM PST: 28 left (buyer bought 1 from St-Petersburg, St-Petersburg ,Russia)
Quantity updated as of 11/16/2011 @ 6:39 AM PST: 27 left (buyer bought 1 from San Clemente, CA)
Quantity updated as of 11/23/2011 @ 2:01 AM PST: 26 left (buyer bought 1 from Haarlem Netherlands)
Quantity updated as of 11/27/2011 @ 4:00 AM PST: 25 left (buyer bought 1 from Krasnoyarsk,Russia)
Quantity updated as of 12/28/2011@ 6:04 PM PST: 24 left (buyer bought 1 from LUYNES ,France)
Quantity updated as of 1/12/2012 @ 2:09 PM PST: 23 left (buyer bought 1 from Camillus, NY)
Quantity updated as of 1/23/2012 @ 10:25 AM PST: 22 left (buyer bought 1 from birmingham, West Midlands ,United Kingdom)
Quantity updated as of 1/24/2012 @ 5:43 PM PST: 21 left (buyer bought 1 from Peachtree City, GA )
Quantity updated as of 2/18/2012 @ 6:20 AM PST: 20 left (buyer bought 1 from Chicago, IL )
Quantity updated as of 2/18/2012 @ 7:13 AM PST: 19 left (buyer bought 1 from Castro Valley, CA)
Quantity updated as of 3/15/2012 @ 11:36 AM PST: 18 left (buyer bought 1 from Sofia, Sofia ,Bulgaria)
Quantity updated as of 4/05/2012 @ 7:04 PM PST: 17 left (buyer bought 1 from KIRYAT MOTSKIN ,Israel)
Quantity updated as of 4/17/2012 @ 1:25 PM PST: 16 left (buyer bought 1 from Yoqneam Elit ,Israel)
Quantity updated as of 5/02/2012 @ 6:43 AM PST: 15 left (buyer bought 1 from Fort Walton Beach, FL)
Quantity updated as of 5/12/2012 @ 9:15 PM PST: 12 left (buyer bought 3 from Portland, OR)
Quantity updated as of 5/17/2012 @ 4:10 PM PST: 11 left (buyer bought 1from Los Angeles, CA )
Quantity updated as of 5/18/2012 @ 5:15 AM PST: 10 left (buyer bought 1from SANTA CLARA, CA)
Quantity updated as of 6/05/2012 @ 7:58 PM PST: 9 left (buyer bought 1from Jackson, NJ )
Quantity updated as of 9/04/2012 @ 9:49 PM PST: 8 left (buyer bought 1 from Izhevsk, UR, Russia)
Quantity updated as of 9/9/2012 @ 2:01 AM PST: 7 left (buyer bought 1 from Fremont, OH )
Quantity updated as of 9/19/2012 @ 4:00 AM PST: 6 left (buyer bought 1 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 10/8/2012@ 6:04 PM PST: 5 left (buyer bought 1 from Athens, Greece )
Quantity updated as of 10/14/2012@ 6:04 PM PST: 4 left (buyer bought 1 from Hanford, CA )
Edited by Lyen on Tue Oct 30, 2012 5:09 pm.
Items For Sale
Lyen
Original post: 9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
1. CA connector
Items For Sale
Lyen
Users browsing this forum: Bing [Bot] and 6 guests
