Hyena, I'm not sure about the stock wires, nothing written on them, pretty lite on though.
I decided to do some upgrades on the keys and the sun gear pins after reading Mark_A_W's problems with these two areas.
I had to pull the wires out of the axle and start again unfortunately.
To stop the keys from moving in the keyways I welded them at each end so the components could still slide onto the axle.
I had to grind off some of the weld shown in the photos, so the hub side plates could still side up near the keys.
The other weakness is the sun gear pins, they can work loose as they are only peened over on the end like a rivet. So I welded those too.
I also slotted the other end of the axle like the factory slot on the end.
Here is a photo showing the use of a cable tie to encourage the wires out of the inner hole on the axle.
I have not finished assembly yet. I will post more later.
Cheers,
Matt.P.
