9 FET 72V Infineon Brushless Controller (LYEN's Edition) $89
Lyen
Post by Lyen » Mar 16, 2010 6:16 pm
These are newly hand assembled Infineon 9 FET controllers I am selling, they are new and never used. It is originally designed for long distance commute in the San Francisco area. It is also best to be used on electric bikes with smaller wheels such as those 16" to 20" wheels found on most folding bikes & scooter style ebikes for more speed. For those who owns battery packs with 10-15Ah in capacity this is the controller for you to avoid getting the battery management system circuitry (BMS) tripped or experience power protection shutdown enabling due to insufficient current flow (low discharge rate) available from the battery and low amperage designs in most 10-15Ah capacity battery packs.
The controller is like a wolf in sheep's skin because it is under tuned in order to optimize for long range. There are lots of potential and features you can unveil and twist as you go. You can program functions such as enable power regeneration, regenerate braking, pulse width modulation, low voltage cut-off, interface with a Cycle Analyst, and others. You may also add an USB to RS232 serial adapter and connect to the computer for tuning. (Electronics knowledge is required to unleash the potential however)
One unique feature of this controller is that it has an additional speed sensor circuitry built-in with an extra blue wire for output. It is to be used with the scooter style electric bike and electric scooters that have a speedometer in the dashboard. As of April 5th, 2010 the speed sensor wire has been embedded and integrated with the green wire on the CA connector since they both can share the same function now. More practical and less confusion as suggested by previous buyers. :)
If you look carefully in the photos, you will notice this version also uses lock washers to secure the FETs internally and the heat transfer bar outside to place tension against a nut after tightening. It is also to help prevent the nut from loosening. The FETs will get overheated and damaged when detached from the heat-sink which used to be the case from the previous designs.
* For the extremists, you may double and possibly triple the current output to make it a mighty wonder by adding braids wires (http://www.radioshack.com/product/index ... Id=2062744),add solders to beef up the circuit board traces and shunt. It may also be needed to upgrade to larger capacitors, gauge wires for both the battery and the phase wires to the motor. However, if you are going to use a 9C (Nine Continent) motor, It is recommended to maximize the current output at 65A due to the thinner gauge wires being used with the hub motor. There is a potential that any current & voltage combination higher than the current 72V @ 65A will melt the phase wires in the hub motor and cause potential damage. A good observation and one that I think plays a big part in showing why the small 9 FET controllers can seem to pack such a punch when modded. The gate drive circuit in the Infineons I have looks to be pretty similar, certainly the 18 FET circuit doesn't look like it can provide much more gate drive than the 9 FET circuit. My guess is that this is one of the reasons why a well-modified 9 FET controller will seemingly run at upwards of 60 to 70 amps without getting hot; the 9 FET drives the FET gates harder and therefore more efficiently. On my list of things to do one day is acquire some really big FETs and see just what a 9 FET controller can do. I think that, fitted with external FET wiring and shunt, it would easily be capable of running at 65A or more, reliably.
Below is the specification:
Model: EC-094310-LYEN EDITION
Start immediate controller
Chipset: XCKJ8B116A (same chipset being used as in the 18 FET controller)
Circuit board version: EB209-A-3
9 x genuine IRFB 4310 MOSFET N-CH 100V (tested up to 110V before damage) for more information about the FET, click the link below:
http://parts.digikey.com/1/parts/102113 ... b4310.html)
Large 100V 470uF Chengx capacitors equipped (http://dgfoley.en.alibaba.com/product/2 ... 3_LP_.html)
72V battery optimized (for higher or lower voltage & current such as 24V-100V, you may need to change the resistor network to avoid damage to the LM317 linear voltage regulator)
30A is the current rate (for higher current, you may need to beef up the trace, shunt, and reprogram it via the software)
Low voltage cut-off: 62.5v
Battery and motor phase wires gauge size: 12AWG (High voltage capable wires equipped)
Dimension: 4.84" x 3.4" x 1.75" (123mm x 87mm x 45mm) plus mount extensions
Total weight: 445 gram
In case you want to upgrade it later on to became Methods-proof and Doctorbass-proof, you may need to upgrade the FETs to 4110 to achieve higher current as well as voltage above 100V. We have a friend here Steveo who do awesome controllers upgrade for a fee. :)
I have only 50 made since I am busy working on my other ebike projects. My intention for selling at such low price is to share the fun with other ES forum members instead of making them jealous. :wink: I finally understand why Methods mentioned the cost of labor is steep after all this and I have to agree with him from now on. These controllers are not generic controllers. I have every single one serialized. Quantity is limited, buy it now and upgrade later once your piggy bank is filled up if needed. :lol:
$89 USD free ground shipping in the United States & Canada. For other locations, please PM or email me at LYEN@HOTMAIL.COM. I accept PayPal, cash or money order. The controllers will be shipped out from me in San Francisco, California, USA. I will provide a tracking number and ship it out as soon as I have received the fund.
For only $10 more, I can include the the following:
1. CA connector
2. Regenerative enable/disable (Enabled simply by connect the wires together without the need to open the case)
3. USB-TTL 5 pin connector (for use with the USB-TTL adapter that is sold separate)
I also have the USB-TTL adapter for adjust and alter the controller settings on your computer. It has the extra 5 pin plug and a "SEND" button. It is also compatible with Windows XP/Vista/7 32/64 bit operating system (real 32/64bit drivers). $15 with purchase, $20 if purchase separately.
You may click on the PayPal Buy It Now link below. For accessories, please send money via PayPal or send me a private message for the total price. Thanks!
https://www.paypal.com/cgi-bin/webscr?c ... MY46WP98CG
If you are not satisfy with the results or if it is too fast for you, you may send it back to me within 30 days in an unmodified condition.
Update: Jan 28th, 2015 > I can adjust the controller for 24V, 33V, 36V, 48V, 60V, 66V, 72V, 84V, and other battery settings upon request.
Quantity updated as of 1/21/2013: 49 left (buyer bought 1 from Saint-Petersburg, Saint-Petersburg, Russia )
Quantity updated as of 1/31/2013: 48 left (buyer bought 1 from Merkez, KÜTAHYA, Turkey )
Quantity updated as of 3/13/2013: 47 left (buyer bought 1 from Portland, OR )
Quantity updated as of 3/18/2013: 46 left (buyer bought 1 from Frankston, Victoria, Australia )
Quantity updated as of 3/25/2013: 45 left (buyer bought 1 from Bologoye, Tver, Russia )
Quantity updated as of 4/1/2013: 44 left (buyer bought 1 from Calgary, Alberta,Canada )
Quantity updated as of 4/18/2013: 42 left (buyer bought 2 from Cardiff, United Kingdom )
Quantity updated as of 5/3/2013: 40 left (buyer bought 2 from Hertford, Hertfordshire, United Kingdom )
Quantity updated as of 5/9/2013: 39 left (buyer bought 1 from Viseu, Portugal )
Quantity updated as of 5/11/2013: 38 left (buyer bought 1 from Toronto, Ontario, Canada )
Quantity updated as of 6/7/2013: 37 left (buyer bought 1 from Manhattan Beach, CA )
Quantity updated as of 6/13/2013: 36 left (buyer bought 1 from Erie, PA )
Quantity updated as of 6/13/2013: 35 left (buyer bought 1 from Oakland, CA )
Quantity updated as of 6/18/2013: 34 left (buyer bought 1 from Philippi, WV )
Quantity updated as of 6/18/2013: 33 left (buyer bought 1 from Sylling, Norway )
Quantity updated as of 6/21/2013: 32 left (buyer bought 1 from Thomasville, GA )
Quantity updated as of 6/22/2013: 31 left (buyer bought 1 from Unionville, Ontario, Canada)
Quantity updated as of 7/7/2013: 30 left (buyer bought 1 from Korea, Seoul, South Korea )
Quantity updated as of 7/27/2013: 29 left (buyer bought 1 from Philadelphia , PA, United States )
Quantity updated as of 8/11/2013: 28 left (buyer bought 1 from Philadelphia , PA )
Quantity updated as of 8/15/2013: 27 left (buyer bought 1 from Porta Westfalica, Neesen, Germany )
Quantity updated as of 8/19/2013: 26 left (buyer bought 1 from Portland, OR )
Quantity updated as of 8/20/2013: 25 left (buyer bought 1 from Avellino, Montoro Inferiore, Italy )
Quantity updated as of 8/23/2013: 24 left (buyer bought 1 from SURREY B.C., Canada )
Quantity updated as of 8/23/2013: 23 left (buyer bought 1 from San Francisco, CA, United States )
Quantity updated as of 8/31/2013: 19 left (buyer bought 4 from Philadelphia , PA, United States )
Quantity updated as of 9/1/2013: 18 left (buyer bought 1 from Torvastad, Norway )
Quantity updated as of 9/19/2013: 17 left (buyer bought 1 from New York, NY, United States )
Quantity updated as of 9/25/2013: 16 left (buyer bought 1 from Rancho Cordova, CA, United States )
Quantity updated as of 9/27/2013: 15 left (buyer bought 1 from Moscow, MO, Russia )
Quantity updated as of 9/29/2013: 14 left (buyer bought 1 from Kirn Dunoon , Scotland, United Kingdom )
Quantity updated as of 10/2/2013: 13 left (buyer bought 1 from Stream wood, IL, United States )
Quantity updated as of 10/8/2013: 12 left (buyer bought 1 from Toms River, NJ, United States)
Quantity updated as of 10/31/2013: 11 left (buyer bought 1 from Izhevsk, UR, Russia)
Quantity updated as of 11/14/2013: 10 left (buyer bought 1 from Valbonne, France)
Quantity updated as of 11/17/2013: 9 left (buyer bought 1 from Pretoria, Gauteng, South Africa)
Quantity updated as of 12/24/2013: 8 left (buyer bought 1 from Tel Aviv, Israel)
Quantity updated as of 1/6/2014: 7 left (buyer bought 1 from stockton, CA, United States)
Quantity updated as of 1/23/2014: 6 left (buyer bought 1 from Fremont, CA, United States )
Quantity updated as of 1/29/2014: 5 left (buyer bought 1 from Garden Grove, CA, United States )
Quantity updated as of 8/28/2014: 4 left (buyer bought 1 from land o lakes, FL, United States )
Quantity updated as of 10/14/2014: 3 left (buyer bought 1 from Manhattan Beach, CA, United States )
Attached are the pictures of the controller. Please allow time for the images to load
For a comparable actual value of controllers using the IRFB4310 MOSFET,check here > http://www.ebikes.ca/store/store_controllers.php and here > http://www.electricbikekitz.com/product ... ucts_id=47
Additional accessories (prices are reflected with controller purchase only. Please contact if you are interested to buy without controller):
$15 throttle (full/half/thumb) with mated left rubber grip (very good quality) (ebikekit retails @ $36)
$19 cruise control (manually installation required)
$15 three way speed switch (manually installation required)
$15 PAS - Pedal Assist System add-on (manually installation required)
$15 electric brake levers a pair
$29 motor/controller hall/phase/throttle tester
Items For Sale
Please sign up here and donate your marrow to save life.
kevo
Re: Any Voltage 9 FET Brushless Controller (LYEN's Edition)
Post by kevo » Mar 20, 2010 5:01 pm
Lyen,
I've installed the software components, but need a little help to build the TTL/USB cable out for my EC 094110-Lyen #1009L004. I have a cable TTL/USB (that has a DB9 serial input), but I'm not sure what lands to solder on the board to a connector hooked up. Do you have a link or can you forward me instructions?
Thanks,
Kevo
Thanks Justin of http://ebikes.ca for your amazing talents, dedication and contributions to ES!
Post licensed under "Open Source" http://creativecommons.org/licenses/by-nc-nd/3.0/
Lyen
Post by Lyen » Mar 20, 2010 8:09 pm
kevo wrote:Lyen,
Thanks,
Kevin
Hi Kevin! Please see the link below on how to add connector. The pin layout is the same for your 9 FET connector as well. Thanks!
https://endless-sphere.com/forums/viewto ... =2&t=16950
Items For Sale
Mark_A_W
Re: 9 FET 72V Infineon Brushless Controller (LYEN's Edition)
Post by Mark_A_W » Mar 23, 2010 11:08 pm
Have you got 12 and 18 FET versions too Lyen?
You should put a link to your sales thread in your signature :)
Under construction: Giant DH Team, MAC Shanghai, Infineon 18 FET controller, 64v Headway battery. LINK!!
Retired: Kona Dawg Dually + Bomber Triple Clamp forks with Nine Continents front hub motor, 48v 10Ah Headway LiFePO4 Pack + 12v 10Ah Headway LiFePO4 booster pack (nominal 64v).
Powered by the sun :)
Dead: Jamis Dakar frame, Mongoose Pro Downhill frame, cooked Lipo booster pack....and various other bits and pieces...
Lyen
Post by Lyen » Mar 24, 2010 2:38 am
Mark_A_W wrote:Have you got 12 and 18 FET versions too Lyen?
Hi Mark! That is a very good idea. I was never a salesperson. I will put up a sales thread in my signature. BTW, I do have the 12 FET & 18 FET versions as well. Thank you! :)
Items For Sale
cord
Post by cord » Mar 24, 2010 12:17 pm
Lyen,
Can this controller run at ~100V? I want to use this with 24s lipo.
Lyen
Post by Lyen » Mar 24, 2010 1:13 pm
cord wrote:Lyen,
Hello Cord!
Thanks for you interest in this awesome controller. Yes, this controller can runs at 100V with your 24s LiPo battery packs. However, please be very careful when working at high voltage. High voltage application like this can shock you to death. So wear protective glove is advise during installation and testing. :)
Best Regards,
Lyen
Items For Sale
chroot
Post by chroot » Mar 24, 2010 1:55 pm
Hi Lyen,
How much the 18FET controller and I will run 24s 72v 10Ah LiPo 200 amp continous and 400 amp burst 15 sec with 9c motor hub.
Lyen
Post by Lyen » Mar 24, 2010 2:07 pm
chroot wrote:Hi Lyen,
Hello Chroot!
The price for the 18FET controller is only $199. It is perfect for your monster 24s 72V battery pack. Please see and/or purchase directly from the link below:
https://endless-sphere.com/forums/viewto ... 31&t=16605
Thank you! :)
Lyen
Items For Sale
SpeedEBikes
Post by SpeedEBikes » Mar 24, 2010 9:43 pm
I'd be very surprised if a 9c can handle that much current. I'd be surprised if you could even rewire it with thick enough phase leads due to the fairly narrow axle bore the leads must be threaded through. But if you succeed, be sure to post of your exploits.
Kevinator
Post by Kevinator » Apr 01, 2010 11:56 am
darn, I was too late!
Kevin's "K7 Clown Bike" - 2009 Dahon Boardwalk S1 on steroids, crack, and mountain dew.
Build thread: http://www.bikeforums.net/showthread.ph ... ner!/page2
chroot
Post by chroot » Apr 01, 2010 12:36 pm
I am curious, more number of FET (18 FET) more powerful than 9 FET?
-c
Lyen
Post by Lyen » Apr 01, 2010 2:39 pm
Kevinator wrote:darn, I was too late!
Hi Kevinator!
May I ask if you are interested in getting the 9 FET controller? If so, please let me know. Thanks! :)
Regards,
Lyen
Items For Sale
Lyen
Post by Lyen » Apr 01, 2010 2:43 pm
chroot wrote:I am curious, more number of FET (18 FET) more powerful than 9 FET?
-c
Hi Chroot!
Yes, you are correct that with the more number of MOSFET (18 FET), the more powerful it is than the 9 FET controller. Your electric bike will never be the same. :wink:
Please let me know if you have any other questions. :)
Your Truly,
Lyen
Items For Sale
auraslip
1.21 GW
1.21 GW
Post by auraslip » May 14, 2010 9:24 pm
Lyen,
I'd like to get this one. If I run it at 48 volts do I need to change anything on it?
THANKS TO EVERYONE HERE WHO TAUGHT ME ABOUT EBIKES. I'M IN YOUR DEBT.
I sell Ebike Brake levers and throttles with custom connectors crimped on! $10 shipped!
ES facebook group
r/ebikes ebikes on reddit
Lyen
Post by Lyen » May 15, 2010 9:00 am
auraslip wrote:Lyen,
Dear Auraslip,
Technically, it is a good practice to bypass a resistor to maintain the voltage to the regulator. But in reality, the controller does works without making any changes. :)
I have just sent you a PM for more info. :)
Regards,
Edward Lyen
Items For Sale
ecodean
Post by ecodean » May 15, 2010 8:11 pm
I also am interested, but will be running 48V. How is the low voltage cutoff adjusted? Thanks.
Lyen
Post by Lyen » May 15, 2010 8:25 pm
ecodean wrote:I also am interested, but will be running 48V. How is the low voltage cutoff adjusted? Thanks.
Hi Ecodean!
Thanks for your interest in the controller. You can simply bypass or short a resistor on the circuit board and program it via the software. I can pre-program it and bypass a resistor for you before I ship it out. :)
Best Regards,
Edward Lyen
Items For Sale
johnnythefox
Post by johnnythefox » May 16, 2010 9:11 am
Hello Lyen
I was wondering if the 9FET will do 36/72 volt on the fly?
I will be running 4 dewalt 36 volts now,but when I find more money I'm thinking of going to 72
volt.
I'll be using a 6x10 from ebikekits.
What conserns me is LVC at 36volts isn't the same at 72volts.
Don't want to blow up my new to me A123's :wink:
I would like to just flip a switch to go from 36volts to 72volts while I ride 8)
I know this 6X10 is not a monster motor so I'm not expecting a lot from it ,but but otoh
there's always the delta Y switch :)
Lyen
Post by Lyen » May 16, 2010 11:16 am
Dear Johnnythefox,
Thanks for your interest in the controller! Yes, it can be done. In fact, it has already been done. :)
The additional cost to add the flip switch and modify the circuitry for dual 36v/72vLVC settings is only $10. This way, you can accompany both your 36v and 72v without the risk of damage. :)
Please let me if you have any other questions. Thank you!
Best Regards,
Edward Lyen
johnnythefox wrote:Hello Lyen
volt.
Items For Sale
grindz145
1 GW
1 GW
Post by grindz145 » Jul 06, 2010 12:48 pm
I don't understand how a 9 FET controller would work. Since you need 1 fet per phase, for both the push and pull, you need 6 per set of fets. How are the 9 fets distributed among the 3 phases? I am very curious.
Lyen
Post by Lyen » Jul 06, 2010 5:08 pm
grindz145 wrote:I don't understand how a 9 FET controller would work. Since you need 1 fet per phase, for both the push and pull, you need 6 per set of fets. How are the 9 fets distributed among the 3 phases? I am very curious.
Hi Grindz,
Thanks for your interest in the 9 FET controller. As for your curiosity, please refer to the related technical topic below:
https://endless-sphere.com/forums/viewto ... =2&t=19642
Thanks!
Lyen
Items For Sale
grindz145
1 GW
1 GW
Post by grindz145 » Jul 07, 2010 6:34 am
Hi Grindz,
Thanks!
Lyen
Ahh perfect. Thanks for that!
wineboyrider
Post by wineboyrider » Jul 14, 2010 4:43 pm
Hi Lyen is there a link to wire this to the ebikekit (minimotor)? 8)
ES IS SAVED! THANK YOU JUSTIN.
Lyen
Post by Lyen » Jul 14, 2010 8:19 pm
wineboyrider wrote:Hi Lyen is there a link to wire this to the ebikekit (minimotor)? 8)
Hello Wineboyrider,
I have just sent you a PM on the possibile color lining to wire your Ebikekit mini motor. :)
Regards,
Lyen
Items For Sale
