Viewing post history: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
This page shows all versions of the post, starting with the most current version.
Current post: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Postby Lyen » Fri May 21, 2010 6:44 pm
If you have any hope of driving the latest motors in their full glory (by which I mean max'ed out potential) and at high native speed, I can’t overstate how important it is to have a powerful controller in your electric bike. For my purpose here, I would choose the 18 FET controller from using the latest IRFB4115 MOSFET.
Introducing the newly brewed 18 FET 84-132V Infineon Programmable Brushless Controllers with high voltage IRFB4115 MOSFETs (EC184115-LYEN EDITION)
This is for a new, never used high voltage controller for racing in mind. It is originally designed people who have the gut for going above 50mph or 80kph.
There are other reasons for utilize the controller below:
1. You want to give higher speed to your beefy and robust high torque low speed motors such as the Crystalyte 5306, 5305, 5304, 4011, 409, 408, BMC V2 Torque version, Nine Continent - 9C 2807, Golden Motor HBS36 series, etc.
2. You have hub motors 20” or smaller high torque wheels and need to find a way to boost significant speed
3. You have a hall sensors added RC motor (Turnigy & Astro in this case) but want to take the advantage of higher RPM or to improve the gear ratios for more torque and/or speed
4. You hate getting horned by cars behind you telling you to get out of their way
5. You think high voltage is cool
6. You want to horn cars in front of you telling them they are too slow
7. You want a high voltage high speed controller in a small enclosure/chassis
8. You want to win the Spooky Tooth Death Race and compete against gas engine cycles after all
9. You want to combine your two 48v battery packs in series together for the high speed experience at 96v
10. You want to combine your three 36v battery packs in series together for the even higher speed experience at 108v
Another unique feature of this controller is that it has an additional speed sensor circuitry built-in with an extra output lead/pin. It is to be used with the scooter style electric bike and electric scooters that have a speedometer in the dashboard that reads electrical pulses.
This version also uses lock washers to secure the MOSFET transistors internally and the heat transfer bar outside to place tension against a nut after tightening. It is also to help prevent the nut from loosening. The MOSFET transistors will get overheated and damaged when detached from the heat-sink which used to be the case from the previous designs.
By purchasing the controller, you understand the following:
1. Your electric bike may classify as a motorcycle class vehicle in most states
2. Riding at high speed may not be legal on public road without proper driver’s license and auto insurance.
3. Risk of high voltage shock with improper high voltage batteries handling
4. Safety wears is advised and may required in most states by law
5. Typical bicycle cantilever, rim, and even disc brakes may not have sufficient stopping power
6. Typical bicycle frames are not designed for high speed application
7. Motorcycle class/training course(s) is highly recommended to ride safely at high speed
Note: Do not use a regular Cycle Analyst due to high voltage will destroy the internal circuitry. You should use the controller with the CA-LS model only.
This is a top of the line controller that comes with all the bells and whistles that are typical needed for the racing application including the CA connector, regen enable/disable jumper, USB-TTL plug, USB-TTL programming adapter with a push to send button and connector. Windows XP/Vista/7 32/64 bit operating system (real 32/64bit drivers). A special LVC calculation formula will be provided via PM or email upon purchase.
Below is the specification:
Model: EC-184115-LYEN EDITION
Start immediate controller
Chipset: XCKJ8B116A (same chipset being used as in the 18 FET controller)
Circuit board version: Confidential
18 x genuine IRFB 4115 MOSFET N-CH 150V (tested up to 150V before damage) for more information about the FET, click the link below:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=IRFB4115PBF-ND)
120V battery optimized (for higher or lower voltage & current such as 84V-132V, you may need to program the low voltage cutoff. Be aware the absolute battery topped off or fully charged voltage cannot exceed 150v)
45A is the current rate (for higher current, you may need to beef up the trace, shunt, and reprogram it via the software)
Low voltage cut-off at default: 95v
Battery and motor phase wires gauge size: 12AWG (High voltage capable wires equipped) Silicon wires installed!
Dimension: 9" x 3.4" x 1.75"( 229mm x 87mm x 45mm) plus mount extensions
Total weight: 805 gram
I have only 35 made since I am busy working on my other ebike projects. My intention for selling at such low price is to share the fun with other ES forum members instead of making them jealous. :wink: I finally understand why Methods mentioned the cost of labor is steep after all this and I have to agree with him from now on. These controllers are not generic controllers. I have every single one serialized. Quantity is limited, buy it as soon as your piggy bank is filled up. :lol:
$259 USD free ground shipping in the United States & Canada. For other locations, please PM or email me at LYEN@HOTMAIL.COM. I accept PayPal, cash or money order. The controllers will be shipped out from me in San Francisco, California, USA. I will provide a tracking number and ship it out as soon as I have received the fund.
You may click on the PayPal Buy It Now link below. For accessories, please send money via PayPal or send me a private message for the total price. Thanks!
https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=2Z7VY2LDRPLMQ
If you are not satisfy with the results or if it is too fast for you, you may send it back to me within 30 days in an unmodified condition.
Updates as March 21st, 2015
Quantity updated as of 12/28/2013 : 34 left (buyer bought 1 from Cambridge, MA, United States )
Quantity updated as of 1/8/2014 : 33 left (buyer bought 1 from Kyabram, Victoria, Australia )
Quantity updated as of 1/8/2014 : 32 left (buyer bought 1 from Morpeth, Northumberland, United Kingdom )
Quantity updated as of 1/30/2014 : 30 left (buyer bought 2 from Kyabram, VIC, Australia )
Quantity updated as of 2/4/2014 : 29 left (buyer bought 1 from Vilamoura, Quarteira, Portugal )
Quantity updated as of 2/9/2014 : 28 left (buyer bought 1 from Tittmoning, Germany )
Quantity updated as of 3/1/2014 : 27 left (buyer bought 1 from Kyabram, Victoria, Australia)
Quantity updated as of 3/13/2014 : 26 left (buyer bought 1 from Norman Park, Queensland, Australia )
Quantity updated as of 3/15/2014 : 25 left (buyer bought 1 from Landsdale, Western Australia, Australia )
Quantity updated as of 4/4/2014 : 24 left (buyer bought 1 from Gordonsville, VA, United States)
Quantity updated as of 4/5/2014 : 23 left (buyer bought 1 from Norfolk, VA, United States )
Quantity updated as of 4/12/2014 : 22 left (buyer bought 1 from Saint-paul, Quebec, Canada )
Quantity updated as of 4/19/2014 : 21 left (buyer bought 1 from Carthage, NY, United States )
Quantity updated as of 4/25/2014 : 19 left (buyer bought 2 from Brooklyn, NY, United States)
Quantity updated as of 5/7/2014 : 18 left (buyer bought 1 from Vancouver, CT, United States )
Quantity updated as of 5/9/2014 : 17 left (buyer bought 1 from West Des Moines, IA, United States )
Quantity updated as of 8/19/2014 : 16 left (buyer bought 1 from MONROVIA, CA, United States )
Quantity updated as of 8/30/2014 : 15 left (buyer bought 1 from Greenwich, CT, United States )
Quantity updated as of 9/16/2014 : 14 left (buyer bought 1 from Swanton, OH, United States )
Quantity updated as of 10/11/2014 : 13 left (buyer bought 1 from Unna, Germany )
Quantity updated as of 11/9/2014 : 12 left (buyer bought 1 from Unna , Germany )
Quantity updated as of 11/16/2014 : 11 left (buyer bought 1 from Fort Washington, PA, United States )
Quantity updated as of 11/25/2014 : 10 left (buyer bought 1 from maastricht, Netherlands )
Quantity updated as of 11/22/2014 : 9 left (buyer bought 1 from Berlin, Germany )
Quantity updated as of 12/8/2014 : 8 left (buyer bought 1 from roma, Italy )
Quantity updated as of 12/13/2014 : 7 left (buyer bought 1 from Greenwood, IN, United States )
Quantity updated as of 12/19/2014 : 6 left (buyer bought 1 from Cap-Santé, Quebec, Canada )
Quantity updated as of 12/23/2014 : 5 left (buyer bought 1 from Temple City, CA, United States )
Additional accessories (prices are reflected with controller purchase only. Please contact if you are interested to buy without controller):
$15 throttle (full/half/thumb) with mated left rubber grip (very good quality) (ebikekit retails @ $36)
$19 cruise control (manually installation required)
$15 three way speed switch (manually installation required)
$15 PAS - Pedal Assist System add-on (manually installation required)
$15 electric brake levers a pair
$29 motor/controller hall/phase/throttle tester
Edited by Lyen on Sat Mar 21, 2015 7:02 pm.
Items For Sale
Please sign up here and donate your marrow to save life.
Lyen
Revision 29: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Edited by Lyen on Sat Jan 31, 2015 3:39 pm.
Items For Sale
Lyen
Revision 28: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
I have only 40 made since I am busy working on my other ebike projects. My intention for selling at such low price is to share the fun with other ES forum members instead of making them jealous. :wink: I finally understand why Methods mentioned the cost of labor is steep after all this and I have to agree with him from now on. These controllers are not generic controllers. I have every single one serialized. Quantity is limited, buy it as soon as your piggy bank is filled up. :lol:
Quantity updated as of 7/5/2013 : 39 left (buyer bought 1 from Godvik, Norway )
Quantity updated as of 7/15/2013 : 38 left (buyer bought 1 from APO, AE )
Quantity updated as of 7/30/2013 : 37 left (buyer bought 1 from whitstable, Kent, United Kingdom )
Quantity updated as of 8/6/2013 : 36 left (buyer bought 1 from Vilamoura, Quarteira, Portugal )
Quantity updated as of 8/14/2013 : 35 left (buyer bought 1 from Wrexham, United Kingdom )
Quantity updated as of 8/15/2013 : 34 left (buyer bought 1 from Porta Westfalica, Neesen, Germany)
Quantity updated as of 8/28/2013 : 33 left (buyer bought 1 from Montreal , Quebec, Canada )
Quantity updated as of 8/29/2013 : 30 left (buyer bought 3 from Kyabram, Victoria, Australia )
Quantity updated as of 9/12/2013 : 29 left (buyer bought 1 from MERMAID Beach, Qld, Australia )
Quantity updated as of 9/23/2013 : 28 left (buyer bought 1 from Issaquah, WA, United States)
Quantity updated as of 9/25/2013 : 27 left (buyer bought 1 from Wettswil a.A, Switzerland)
Quantity updated as of 10/20/2013 : 26 left (buyer bought 1 from O'Halloran Hill, South Australia, Australia )
Quantity updated as of 10/30/2013 : 25 left (buyer bought 1 from Fort Lauderdale, FL, United States )
Quantity updated as of 11/8/2013 : 24 left (buyer bought 1 from Carthage, NY, United States)
Quantity updated as of 11/30/2013 : 23 left (buyer bought 1 from Kyabram Victoria, Australia )
Quantity updated as of 12/3/2013 : 22 left (buyer bought 1 from Wrexham, Wrexham, United Kingdom )
Quantity updated as of 12/26/2013 : 21 left (buyer bought 1 from Roskilde, Denmark )
Quantity updated as of 12/28/2013 : 20 left (buyer bought 1 from Cambridge, MA, United States )
Quantity updated as of 1/8/2014 : 19 left (buyer bought 1 from Kyabram, Victoria, Australia )
Quantity updated as of 1/8/2014 : 18 left (buyer bought 1 from Morpeth, Northumberland, United Kingdom )
Quantity updated as of 1/30/2014 : 16 left (buyer bought 2 from Kyabram, VIC, Australia )
Quantity updated as of 2/4/2014 : 15 left (buyer bought 1 from Vilamoura, Quarteira, Portugal )
Quantity updated as of 2/9/2014 : 14 left (buyer bought 1 from Tittmoning, Germany )
Quantity updated as of 3/1/2014 : 13 left (buyer bought 1 from Kyabram, Victoria, Australia)
Quantity updated as of 3/13/2014 : 12 left (buyer bought 1 from Norman Park, Queensland, Australia )
Quantity updated as of 3/15/2014 : 11 left (buyer bought 1 from Landsdale, Western Australia, Australia )
Quantity updated as of 4/4/2014 : 10 left (buyer bought 1 from Gordonsville, VA, United States)
Quantity updated as of 4/5/2014 : 9 left (buyer bought 1 from Norfolk, VA, United States )
Quantity updated as of 4/12/2014 : 8 left (buyer bought 1 from Saint-paul, Quebec, Canada )
Quantity updated as of 4/19/2014 : 7 left (buyer bought 1 from Carthage, NY, United States )
Quantity updated as of 4/25/2014 : 5 left (buyer bought 2 from Brooklyn, NY, United States)
Quantity updated as of 5/7/2014 : 4 left (buyer bought 1 from Vancouver, CT, United States )
Quantity updated as of 5/9/2014 : 3 left (buyer bought 1 from West Des Moines, IA, United States )
Edited by Lyen on Sun Jun 22, 2014 11:27 am.
Items For Sale
Lyen
Revision 27: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
I have only 25 made since I am busy working on my other ebike projects. My intention for selling at such low price is to share the fun with other ES forum members instead of making them jealous. :wink: I finally understand why Methods mentioned the cost of labor is steep after all this and I have to agree with him from now on. These controllers are not generic controllers. I have every single one serialized. Quantity is limited, buy it as soon as your piggy bank is filled up. :lol:
Quantity updated as of 6/6/2013 : 24 left (buyer bought 1 from Saskatoon, Saskatchewan, Canada )
Quantity updated as of 6/14/2013 : 23 left (buyer bought 1 from Richmond, CA )
Quantity updated as of 6/17/2013 : 22 left (buyer bought 1 from Strathroy, Ontario, Canada )
Quantity updated as of 6/28/2013 : 21 left (buyer bought 1 from Labrador, Queensland, Australia )
Quantity updated as of 7/5/2013 : 20 left (buyer bought 1 from Godvik, Norway )
Quantity updated as of 7/15/2013 : 19 left (buyer bought 1 from APO, AE )
Quantity updated as of 7/30/2013 : 18 left (buyer bought 1 from whitstable, Kent, United Kingdom )
Quantity updated as of 8/6/2013 : 17 left (buyer bought 1 from Vilamoura, Quarteira, Portugal )
Quantity updated as of 8/14/2013 : 16 left (buyer bought 1 from Wrexham, United Kingdom )
Quantity updated as of 8/15/2013 : 15 left (buyer bought 1 from Porta Westfalica, Neesen, Germany)
Quantity updated as of 8/28/2013 : 14 left (buyer bought 1 from Montreal , Quebec, Canada )
Quantity updated as of 8/29/2013 : 11 left (buyer bought 3 from Kyabram, Victoria, Australia )
Quantity updated as of 9/12/2013 : 10 left (buyer bought 1 from MERMAID Beach, Qld, Australia )
Quantity updated as of 9/23/2013 : 9 left (buyer bought 1 from Issaquah, WA, United States)
Quantity updated as of 9/25/2013 : 8 left (buyer bought 1 from Wettswil a.A, Switzerland)
Quantity updated as of 10/20/2013 : 7 left (buyer bought 1 from O'Halloran Hill, South Australia, Australia )
Quantity updated as of 10/30/2013 : 6 left (buyer bought 1 from Fort Lauderdale, FL, United States )
Quantity updated as of 11/8/2013 : 5 left (buyer bought 1 from Carthage, NY, United States)
Quantity updated as of 11/30/2013 : 4 left (buyer bought 1 from Kyabram Victoria, Australia )
Quantity updated as of 12/3/2013 : 3 left (buyer bought 1 from Wrexham, Wrexham, United Kingdom )
Edited by Lyen on Sat Dec 14, 2013 8:08 pm.
Items For Sale
Lyen
Revision 26: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
I have only 30 made since I am busy working on my other ebike projects. My intention for selling at such low price is to share the fun with other ES forum members instead of making them jealous. :wink: I finally understand why Methods mentioned the cost of labor is steep after all this and I have to agree with him from now on. These controllers are not generic controllers. I have every single one serialized. Quantity is limited, buy it as soon as your piggy bank is filled up. :lol:
Quantity updated as of 4/18/2013 : 29 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 4/20/2013 : 28 left (buyer bought 1 from City Brest,Belarus )
Quantity updated as of 4/27/2013 : 27 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 4/30/2013 : 25 left (buyer bought 2 from Porta Westfalica, Germany )
Quantity updated as of 4/30/2013 : 24 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 5/9/2013 : 23 left (buyer bought 1 from Acireale,Catania,Italy )
Quantity updated as of 5/10/2013 : 22 left (buyer bought 1 from Sengenthal,Germany )
Quantity updated as of 6/2/2013 : 21 left (buyer bought 1 from Quincy, MA )
Quantity updated as of 6/6/2013 : 20 left (buyer bought 1 from Saskatoon, Saskatchewan, Canada )
Quantity updated as of 6/14/2013 : 19 left (buyer bought 1 from Richmond, CA )
Quantity updated as of 6/17/2013 : 18 left (buyer bought 1 from Strathroy, Ontario, Canada )
Quantity updated as of 6/28/2013 : 17 left (buyer bought 1 from Labrador, Queensland, Australia )
Quantity updated as of 7/5/2013 : 16 left (buyer bought 1 from Godvik, Norway )
Quantity updated as of 7/15/2013 : 15 left (buyer bought 1 from APO, AE )
Quantity updated as of 7/30/2013 : 14 left (buyer bought 1 from whitstable, Kent, United Kingdom )
Quantity updated as of 8/6/2013 : 13 left (buyer bought 1 from Vilamoura, Quarteira, Portugal )
Quantity updated as of 8/14/2013 : 12 left (buyer bought 1 from Wrexham, United Kingdom )
Quantity updated as of 8/15/2013 : 11 left (buyer bought 1 from Porta Westfalica, Neesen, Germany)
Quantity updated as of 8/28/2013 : 10 left (buyer bought 1 from Montreal , Quebec, Canada )
Quantity updated as of 8/29/2013 : 7 left (buyer bought 3 from Kyabram, Victoria, Australia )
Quantity updated as of 9/12/2013 : 6 left (buyer bought 1 from MERMAID Beach, Qld, Australia )
Quantity updated as of 9/23/2013 : 5 left (buyer bought 1 from Issaquah, WA, United States)
Quantity updated as of 9/25/2013 : 4 left (buyer bought 1 from Wettswil a.A, Switzerland)
Quantity updated as of 10/20/2013 : 3 left (buyer bought 1 from O'Halloran Hill, South Australia, Australia )
Quantity updated as of 10/30/2013 : 2 left (buyer bought 1 from Fort Lauderdale, FL, United States )
Edited by Lyen on Thu Nov 07, 2013 5:46 pm.
Items For Sale
Lyen
Revision 25: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Quantity updated as of 3/26/2013 : 29 left (buyer bought 1 from Carleton-sur-mer, Quebec, Canada )
Quantity updated as of 4/4/2013 : 28 left (buyer bought 1 from Zwingenberg, Baden-Württemberg, Germany )
Quantity updated as of 4/18/2013 : 27 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 4/20/2013 : 26 left (buyer bought 1 from City Brest,Belarus )
Quantity updated as of 4/27/2013 : 25 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 4/30/2013 : 23 left (buyer bought 2 from Porta Westfalica, Germany )
Quantity updated as of 4/30/2013 : 22 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 5/9/2013 : 21 left (buyer bought 1 from Acireale,Catania,Italy )
Quantity updated as of 5/10/2013 : 20 left (buyer bought 1 from Sengenthal,Germany )
Quantity updated as of 6/2/2013 : 19 left (buyer bought 1 from Quincy, MA )
Quantity updated as of 6/6/2013 : 18 left (buyer bought 1 from Saskatoon, Saskatchewan, Canada )
Quantity updated as of 6/14/2013 : 17 left (buyer bought 1 from Richmond, CA )
Quantity updated as of 6/17/2013 : 16 left (buyer bought 1 from Strathroy, Ontario, Canada )
Quantity updated as of 6/28/2013 : 15 left (buyer bought 1 from Labrador, Queensland, Australia )
Quantity updated as of 7/5/2013 : 14 left (buyer bought 1 from Godvik, Norway )
Quantity updated as of 7/15/2013 : 13 left (buyer bought 1 from APO, AE )
Quantity updated as of 7/30/2013 : 12 left (buyer bought 1 from whitstable, Kent, United Kingdom )
Quantity updated as of 8/6/2013 : 11 left (buyer bought 1 from Vilamoura, Quarteira, Portugal )
Quantity updated as of 8/14/2013 : 10 left (buyer bought 1 from Wrexham, United Kingdom )
Quantity updated as of 8/15/2013 : 9 left (buyer bought 1 from Porta Westfalica, Neesen, Germany)
Quantity updated as of 8/28/2013 : 8 left (buyer bought 1 from Montreal , Quebec, Canada )
Quantity updated as of 8/29/2013 : 5 left (buyer bought 3 from Kyabram, Victoria, Australia )
Quantity updated as of 9/12/2013 : 4 left (buyer bought 1 from MERMAID Beach, Qld, Australia )
Quantity updated as of 9/23/2013 : 3 left (buyer bought 1 from Issaquah, WA, United States)
Quantity updated as of 9/25/2013 : 2 left (buyer bought 1 from Wettswil a.A, Switzerland)
Quantity updated as of 10/20/2013 : 1 left (buyer bought 1 from O'Halloran Hill, South Australia, Australia )
Edited by Lyen on Thu Oct 24, 2013 5:51 pm.
Items For Sale
Lyen
Revision 24: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Edited by Lyen on Thu Oct 10, 2013 6:15 pm.
Items For Sale
Lyen
Revision 23: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Edited by Lyen on Thu Sep 26, 2013 7:16 pm.
Items For Sale
Lyen
Revision 22: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Quantity updated as of 3/10/2013 : 29 left (buyer bought 1 from Wien, Austria )
Quantity updated as of 3/21/2013 : 28 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 3/26/2013 : 27 left (buyer bought 1 from Carleton-sur-mer, Quebec, Canada )
Quantity updated as of 4/4/2013 : 26 left (buyer bought 1 from Zwingenberg, Baden-Württemberg, Germany )
Quantity updated as of 4/18/2013 : 25 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 4/20/2013 : 24 left (buyer bought 1 from City Brest,Belarus )
Quantity updated as of 4/27/2013 : 23 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 4/30/2013 : 21 left (buyer bought 2 from Porta Westfalica, Germany )
Quantity updated as of 4/30/2013 : 20 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 5/9/2013 : 19 left (buyer bought 1 from Acireale,Catania,Italy )
Quantity updated as of 5/10/2013 : 18 left (buyer bought 1 from Sengenthal,Germany )
Quantity updated as of 6/2/2013 : 17 left (buyer bought 1 from Quincy, MA )
Quantity updated as of 6/6/2013 : 16 left (buyer bought 1 from Saskatoon, Saskatchewan, Canada )
Quantity updated as of 6/14/2013 : 15 left (buyer bought 1 from Richmond, CA )
Quantity updated as of 6/17/2013 : 14 left (buyer bought 1 from Strathroy, Ontario, Canada )
Quantity updated as of 6/28/2013 : 13 left (buyer bought 1 from Labrador, Queensland, Australia )
Quantity updated as of 7/5/2013 : 12 left (buyer bought 1 from Godvik, Norway )
Quantity updated as of 7/15/2013 : 11 left (buyer bought 1 from APO, AE )
Quantity updated as of 7/30/2013 : 10 left (buyer bought 1 from whitstable, Kent, United Kingdom )
Quantity updated as of 8/6/2013 : 9 left (buyer bought 1 from Vilamoura, Quarteira, Portugal )
Quantity updated as of 8/14/2013 : 8 left (buyer bought 1 from Wrexham, United Kingdom )
Quantity updated as of 8/15/2013 : 7 left (buyer bought 1 from Porta Westfalica, Neesen, Germany)
Quantity updated as of 8/28/2013 : 6 left (buyer bought 1 from Montreal , Quebec, Canada )
Quantity updated as of 8/29/2013 : 3 left (buyer bought 3 from Kyabram, Victoria, Australia )
Quantity updated as of 9/12/2013 : 2 left (buyer bought 1 from MERMAID Beach, Qld, Australia )
Edited by Lyen on Sat Sep 21, 2013 5:41 pm.
Items For Sale
Lyen
Revision 21: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Edited by Lyen on Thu Sep 19, 2013 5:46 pm.
Items For Sale
Lyen
Revision 20: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Edited by Lyen on Sat Sep 14, 2013 11:55 am.
Items For Sale
Lyen
Revision 19: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Quantity updated as of 3/5/2013 : 29 left (buyer bought 1 from Waterloo, Ontario, Canada )
Quantity updated as of 3/10/2013 : 28 left (buyer bought 1 from Wien, Austria )
Quantity updated as of 3/21/2013 : 27 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 3/26/2013 : 26 left (buyer bought 1 from Carleton-sur-mer, Quebec, Canada )
Quantity updated as of 4/4/2013 : 25 left (buyer bought 1 from Zwingenberg, Baden-Württemberg, Germany )
Quantity updated as of 4/18/2013 : 24 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 4/20/2013 : 23 left (buyer bought 1 from City Brest,Belarus )
Quantity updated as of 4/27/2013 : 22 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 4/30/2013 : 20 left (buyer bought 2 from Porta Westfalica, Germany )
Quantity updated as of 4/30/2013 : 19 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 5/9/2013 : 18 left (buyer bought 1 from Acireale,Catania,Italy )
Quantity updated as of 5/10/2013 : 17 left (buyer bought 1 from Sengenthal,Germany )
Quantity updated as of 6/2/2013 : 16 left (buyer bought 1 from Quincy, MA )
Quantity updated as of 6/6/2013 : 15 left (buyer bought 1 from Saskatoon, Saskatchewan, Canada )
Quantity updated as of 6/14/2013 : 14 left (buyer bought 1 from Richmond, CA )
Quantity updated as of 6/17/2013 : 13 left (buyer bought 1 from Strathroy, Ontario, Canada )
Quantity updated as of 6/28/2013 : 12 left (buyer bought 1 from Labrador, Queensland, Australia )
Quantity updated as of 7/5/2013 : 11 left (buyer bought 1 from Godvik, Norway )
Quantity updated as of 7/15/2013 : 10 left (buyer bought 1 from APO, AE )
Quantity updated as of 7/30/2013 : 9 left (buyer bought 1 from whitstable, Kent, United Kingdom )
Quantity updated as of 8/6/2013 : 8 left (buyer bought 1 from Vilamoura, Quarteira, Portugal )
Quantity updated as of 8/14/2013 : 7 left (buyer bought 1 from Wrexham, United Kingdom )
Quantity updated as of 8/15/2013 : 6 left (buyer bought 1 from Porta Westfalica, Neesen, Germany)
Quantity updated as of 8/28/2013 : 2 left (buyer bought 1 from Montreal , Quebec, Canada )
Edited by Lyen on Tue Sep 03, 2013 7:18 pm.
Items For Sale
Lyen
Revision 18: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Edited by Lyen on Sat Aug 31, 2013 7:31 pm.
Items For Sale
Lyen
Revision 17: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Quantity updated as of 3/5/2013 : 24 left (buyer bought 1 from Waterloo, Ontario, Canada )
Quantity updated as of 3/10/2013 : 23 left (buyer bought 1 from Wien, Austria )
Quantity updated as of 3/21/2013 : 22 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 3/26/2013 : 21 left (buyer bought 1 from Carleton-sur-mer, Quebec, Canada )
Quantity updated as of 4/4/2013 : 20 left (buyer bought 1 from Zwingenberg, Baden-Württemberg, Germany )
Quantity updated as of 4/18/2013 : 19 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 4/20/2013 : 18 left (buyer bought 1 from City Brest,Belarus )
Quantity updated as of 4/27/2013 : 17 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 4/30/2013 : 16 left (buyer bought 2 from Porta Westfalica, Germany )
Quantity updated as of 4/30/2013 : 15 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 5/9/2013 : 14 left (buyer bought 1 from Acireale,Catania,Italy )
Quantity updated as of 5/10/2013 : 13 left (buyer bought 1 from Sengenthal,Germany )
Quantity updated as of 6/2/2013 : 12 left (buyer bought 1 from Quincy, MA )
Quantity updated as of 6/6/2013 : 11 left (buyer bought 1 from Saskatoon, Saskatchewan, Canada )
Quantity updated as of 6/14/2013 : 10 left (buyer bought 1 from Richmond, CA )
Quantity updated as of 6/17/2013 : 9 left (buyer bought 1 from Strathroy, Ontario, Canada )
Quantity updated as of 6/28/2013 : 8 left (buyer bought 1 from Labrador, Queensland, Australia )
Quantity updated as of 7/5/2013 : 7 left (buyer bought 1 from Godvik, Norway )
Quantity updated as of 7/15/2013 : 6 left (buyer bought 1 from APO, AE )
Quantity updated as of 7/30/2013 : 5 left (buyer bought 1 from whitstable, Kent, United Kingdom )
Quantity updated as of 8/6/2013 : 4 left (buyer bought 1 from Vilamoura, Quarteira, Portugal )
Quantity updated as of 8/14/2013 : 3 left (buyer bought 1 from Wrexham, United Kingdom )
Quantity updated as of 8/15/2013 : 2 left (buyer bought 1 from Porta Westfalica, Neesen, Germany)
Edited by Lyen on Thu Aug 22, 2013 1:30 pm.
Items For Sale
Lyen
Revision 16: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Quantity updated as of 1/13/2013 : 24 left (buyer bought 1 from Lansdale, PA )
Quantity updated as of 1/30/2013 : 23 left (buyer bought 1 from adelaide, South Australia, Australia )
Quantity updated as of 1/30/2013 : 22 left (buyer bought 1 from Pruszkow, Poland )
Quantity updated as of 2/27/2013 : 21 left (buyer bought 1 from Fresno, CA )
Quantity updated as of 3/5/2013 : 20 left (buyer bought 1 from Waterloo, Ontario, Canada )
Quantity updated as of 3/10/2013 : 19 left (buyer bought 1 from Wien, Austria )
Quantity updated as of 3/21/2013 : 18 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 3/26/2013 : 17 left (buyer bought 1 from Carleton-sur-mer, Quebec, Canada )
Quantity updated as of 4/4/2013 : 16 left (buyer bought 1 from Zwingenberg, Baden-Württemberg, Germany )
Quantity updated as of 4/18/2013 : 15 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 4/20/2013 : 14 left (buyer bought 1 from City Brest,Belarus )
Quantity updated as of 4/27/2013 : 13 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 4/30/2013 : 12 left (buyer bought 2 from Porta Westfalica, Germany )
Quantity updated as of 4/30/2013 : 11 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 5/9/2013 : 10 left (buyer bought 1 from Acireale,Catania,Italy )
Quantity updated as of 5/10/2013 : 9 left (buyer bought 1 from Sengenthal,Germany )
Quantity updated as of 6/2/2013 : 8 left (buyer bought 1 from Quincy, MA )
Quantity updated as of 6/6/2013 : 7 left (buyer bought 1 from Saskatoon, Saskatchewan, Canada )
Quantity updated as of 6/14/2013 : 6 left (buyer bought 1 from Richmond, CA )
Quantity updated as of 6/17/2013 : 5 left (buyer bought 1 from Strathroy, Ontario, Canada )
Quantity updated as of 6/28/2013 : 4 left (buyer bought 1 from Labrador, Queensland, Australia )
Quantity updated as of 7/5/2013 : 3 left (buyer bought 1 from Godvik, Norway )
Quantity updated as of 7/15/2013 : 2 left (buyer bought 1 from APO, AE )
Quantity updated as of 7/30/2013 : 1 left (buyer bought 1 from whitstable, Kent, United Kingdom )
Edited by Lyen on Thu Aug 01, 2013 6:38 pm.
Items For Sale
Lyen
Revision 15: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Edited by Lyen on Sat Jul 27, 2013 5:51 pm.
Items For Sale
Lyen
Revision 14: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Edited by Lyen on Sat Jul 20, 2013 5:24 pm.
Items For Sale
Lyen
Revision 13: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Quantity updated as of 12/21/2012 : 24 left (buyer bought 1 from Moscow, Russia )
Quantity updated as of 1/8/2013 : 23 left (buyer bought 1 from Clarkdale, AZ)
Quantity updated as of 1/9/2013 : 22 left (buyer bought 1 from Winnipeg, MB, Canada )
Quantity updated as of 1/13/2013 : 21 left (buyer bought 1 from Lansdale, PA )
Quantity updated as of 1/30/2013 : 20 left (buyer bought 1 from adelaide, South Australia, Australia )
Quantity updated as of 1/30/2013 : 19 left (buyer bought 1 from Pruszkow, Poland )
Quantity updated as of 2/27/2013 : 18 left (buyer bought 1 from Fresno, CA )
Quantity updated as of 3/5/2013 : 17 left (buyer bought 1 from Waterloo, Ontario, Canada )
Quantity updated as of 3/10/2013 : 16 left (buyer bought 1 from Wien, Austria )
Quantity updated as of 3/21/2013 : 15 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 3/26/2013 : 14 left (buyer bought 1 from Carleton-sur-mer, Quebec, Canada )
Quantity updated as of 4/4/2013 : 13 left (buyer bought 1 from Zwingenberg, Baden-Württemberg, Germany )
Quantity updated as of 4/18/2013 : 12 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 4/20/2013 : 11 left (buyer bought 1 from City Brest,Belarus )
Quantity updated as of 4/27/2013 : 10 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 4/30/2013 : 8 left (buyer bought 2 from Porta Westfalica, Germany )
Quantity updated as of 4/30/2013 : 7 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 5/9/2013 : 6 left (buyer bought 1 from Acireale,Catania,Italy )
Quantity updated as of 5/10/2013 : 5 left (buyer bought 1 from Sengenthal,Germany )
Quantity updated as of 6/2/2013 : 4 left (buyer bought 1 from Quincy, MA )
Quantity updated as of 6/6/2013 : 3 left (buyer bought 1 from Saskatoon, Saskatchewan, Canada )
Quantity updated as of 6/14/2013 : 2 left (buyer bought 1 from Richmond, CA )
Quantity updated as of 6/17/2013 : 1 left (buyer bought 1 from Strathroy, Ontario, Canada )
Edited by Lyen on Thu Jun 20, 2013 6:35 pm.
Items For Sale
Lyen
Revision 12: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Quantity updated as of 12/16/2012 @ 1:46 PM PST: 24 left (buyer bought 1 from Katy, TX )
Quantity updated as of 12/21/2012 @ 4:07 PM PST: 23 left (buyer bought 1 from Moscow, Russia )
Quantity updated as of 1/8/2013 @ 4:30 PM PST: 22 left (buyer bought 1 from Clarkdale, AZ)
Quantity updated as of 1/9/2013 @ 1:46 PM PST: 21 left (buyer bought 1 from Winnipeg, MB, Canada )
Quantity updated as of 1/13/2013 @ 4:30 PM PST: 20 left (buyer bought 1 from Lansdale, PA )
Quantity updated as of 1/30/2013 @ 4:07 PM PST: 19 left (buyer bought 1 from adelaide, South Australia, Australia )
Quantity updated as of 1/30/2013 @ 1:46 PM PST: 18 left (buyer bought 1 from Pruszkow, Poland )
Quantity updated as of 2/27/2013 @ 4:30 PM PST: 17 left (buyer bought 1 from Fresno, CA )
Quantity updated as of 3/5/2013 @ 4:07 PM PST: 16 left (buyer bought 1 from Waterloo, Ontario, Canada )
Quantity updated as of 3/10/2013 @ 1:46 PM PST: 15 left (buyer bought 1 from Wien, Austria )
Quantity updated as of 3/21/2013 @ 4:30 PM PST: 14 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 3/26/2013 @ 4:07 PM PST: 13 left (buyer bought 1 from Carleton-sur-mer, Quebec, Canada )
Quantity updated as of 4/4/2013 @ 1:46 PM PST: 12 left (buyer bought 1 from Zwingenberg, Baden-Württemberg, Germany )
Quantity updated as of 4/18/2013 @ 4:07 PM PST: 11 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 4/20/2013 @ 1:46 PM PST: 10 left (buyer bought 1 from City Brest,Belarus )
Quantity updated as of 4/27/2013 @ 4:07 PM PST: 9 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 4/30/2013 @ 4:30 PM PST: 7 left (buyer bought 2 from Porta Westfalica, Germany )
Quantity updated as of 4/30/2013 @ 1:46 PM PST: 6 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 5/9/2013 @ 4:07 PM PST: 5 left (buyer bought 1 from Acireale,Catania,Italy )
Quantity updated as of 5/10/2013 @ 1:46 PM PST: 4 left (buyer bought 1 from Sengenthal,Germany )
Quantity updated as of 6/2/2013 @ 4:07 PM PST: 3 left (buyer bought 1 from Quincy, MA )
Quantity updated as of 6/6/2013 @ 1:46 PM PST: 2 left (buyer bought 1 from saskatoon, Saskatchewan, Canada )
Edited by Lyen on Sat Jun 08, 2013 6:56 pm.
Items For Sale
Lyen
Revision 11: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Quantity updated as of 10/9/2012 @ 2:00 PM PST: 24 left (buyer bought 1 from Chevy Chase, MD )
Quantity updated as of 11/7/2012 @ 1:15 PM PST: 23 left (buyer bought 1 from Singapore )
Quantity updated as of 12/7/2012 @ 3:27 PM PST: 22 left (buyer bought 1 from Labrador, Queensland, Australia )
Quantity updated as of 12/16/2012 @ 1:46 PM PST: 21 left (buyer bought 1 from Katy, TX )
Quantity updated as of 12/21/2012 @ 4:07 PM PST: 20 left (buyer bought 1 from Moscow, Russia )
Quantity updated as of 1/8/2013 @ 4:30 PM PST: 19 left (buyer bought 1 from Clarkdale, AZ)
Quantity updated as of 1/9/2013 @ 1:46 PM PST: 18 left (buyer bought 1 from Winnipeg, MB, Canada )
Quantity updated as of 1/13/2013 @ 4:30 PM PST: 17 left (buyer bought 1 from Lansdale, PA )
Quantity updated as of 1/30/2013 @ 4:07 PM PST:16 left (buyer bought 1 from adelaide, South Australia, Australia )
Quantity updated as of 1/30/2013 @ 1:46 PM PST: 15 left (buyer bought 1 from Pruszkow, Poland )
Quantity updated as of 2/27/2013 @ 4:30 PM PST: 14 left (buyer bought 1 from Fresno, CA )
Quantity updated as of 3/5/2013 @ 4:07 PM PST: 13 left (buyer bought 1 from Waterloo, Ontario, Canada )
Quantity updated as of 3/10/2013 @ 1:46 PM PST: 12 left (buyer bought 1 from Wien, Austria )
Quantity updated as of 3/21/2013 @ 4:30 PM PST: 11 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 3/26/2013 @ 4:07 PM PST: 10 left (buyer bought 1 from Carleton-sur-mer, Quebec, Canada )
Quantity updated as of 4/4/2013 @ 1:46 PM PST: 9 left (buyer bought 1 from Zwingenberg, Baden-Württemberg, Germany )
Quantity updated as of 4/18/2013 @ 4:07 PM PST: 8 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 4/20/2013 @ 1:46 PM PST: 7 left (buyer bought 1 from City Brest,Belarus )
Quantity updated as of 4/27/2013 @ 4:07 PM PST: 6 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 4/30/2013 @ 4:30 PM PST: 4 left (buyer bought 2 from Porta Westfalica, Germany )
Quantity updated as of 4/30/2013 @ 1:46 PM PST: 3 left (buyer bought 1 from Grosseto, Italy )
Quantity updated as of 5/9/2013 @ 4:07 PM PST: 2 left (buyer bought 1 from Acireale,Catania,Italy )
Quantity updated as of 5/10/2013 @ 1:46 PM PST: 1 left (buyer bought 1 from Sengenthal,Germany )
Edited by Lyen on Tue May 28, 2013 5:23 pm.
Items For Sale
Lyen
Revision 10: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Quantity updated as of 9/27/2012 @ 1:46 PM PST: 29 left (buyer bought 1 from San Francisco, CA )
Quantity updated as of 10/3/2012 @ 8:27 PM PST: 28 left (buyer bought 1 from Singapore)
Quantity updated as of 10/6/2012 @ 2:40 PM PST: 27 left (buyer bought 1 from Penzance, Cornwall, United Kingdom )
Quantity updated as of 10/9/2012 @ 2:00 PM PST: 26 left (buyer bought 1 from Chevy Chase, MD )
Quantity updated as of 11/7/2012 @ 1:15 PM PST: 25 left (buyer bought 1 from Singapore )
Quantity updated as of 12/7/2012 @ 3:27 PM PST: 24 left (buyer bought 1 from Labrador, Queensland, Australia )
Quantity updated as of 12/16/2012 @ 1:46 PM PST: 23 left (buyer bought 1 from Katy, TX )
Quantity updated as of 12/21/2012 @ 4:07 PM PST: 22 left (buyer bought 1 from Moscow, Russia )
Quantity updated as of 1/8/2013 @ 4:30 PM PST: 21 left (buyer bought 1 from Clarkdale, AZ)
Quantity updated as of 1/9/2013 @ 1:46 PM PST: 20 left (buyer bought 1 from Winnipeg, MB, Canada )
Quantity updated as of 1/13/2013 @ 4:30 PM PST: 19 left (buyer bought 1 from Lansdale, PA )
Quantity updated as of 1/30/2013 @ 4:07 PM PST:18 left (buyer bought 1 from adelaide, South Australia, Australia )
Quantity updated as of 1/30/2013 @ 1:46 PM PST: 17 left (buyer bought 1 from Pruszkow, Poland )
Quantity updated as of 2/27/2013 @ 4:30 PM PST: 16 left (buyer bought 1 from Fresno, CA )
Quantity updated as of 3/5/2013 @ 4:07 PM PST: 15 left (buyer bought 1 from Waterloo, Ontario, Canada )
Quantity updated as of 3/10/2013 @ 1:46 PM PST: 14 left (buyer bought 1 from Wien, Austria )
Quantity updated as of 3/21/2013 @ 4:30 PM PST: 13 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 3/26/2013 @ 4:07 PM PST: 12 left (buyer bought 1 from Carleton-sur-mer, Quebec, Canada )
Quantity updated as of 4/4/2013 @ 1:46 PM PST: 11 left (buyer bought 1 from Zwingenberg, Baden-Württemberg, Germany )
Quantity updated as of 4/30/2013 @ 4:30 PM PST: 5 left (buyer bought 2 from Porta Westfalica, Germany )
Edited by Lyen on Sat May 25, 2013 7:41 pm.
Items For Sale
Lyen
Revision 9: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Quantity updated as of 9/17/2012 @ 2:51 AM PST: 24 left (buyer bought 1 from Vilnius, Lithuania Republic )
Quantity updated as of 9/20/2012 @ 4:22 AM PST: 23 left (buyer bought 1 from Kyabram, victoria, Australia )
Quantity updated as of 9/21/2012 @ 5:17 PM PST: 22 left (buyer bought 1 from Spencer, MA )
Quantity updated as of 9/27/2012 @ 1:46 PM PST: 21 left (buyer bought 1 from San Francisco, CA )
Quantity updated as of 10/3/2012 @ 8:27 PM PST: 20 left (buyer bought 1 from Singapore)
Quantity updated as of 10/6/2012 @ 2:40 PM PST: 19 left (buyer bought 1 from Penzance, Cornwall, United Kingdom )
Quantity updated as of 10/9/2012 @ 2:00 PM PST: 18 left (buyer bought 1 from Chevy Chase, MD )
Quantity updated as of 11/7/2012 @ 1:15 PM PST: 17 left (buyer bought 1 from Singapore )
Quantity updated as of 12/7/2012 @ 3:27 PM PST: 16 left (buyer bought 1 from Labrador, Queensland, Australia )
Quantity updated as of 12/16/2012 @ 1:46 PM PST: 15 left (buyer bought 1 from Katy, TX )
Quantity updated as of 12/21/2012 @ 4:07 PM PST: 14 left (buyer bought 1 from Moscow, Russia )
Quantity updated as of 1/8/2013 @ 4:30 PM PST: 13 left (buyer bought 1 from Clarkdale, AZ)
Quantity updated as of 1/9/2013 @ 1:46 PM PST: 12 left (buyer bought 1 from Winnipeg, MB, Canada )
Quantity updated as of 1/13/2013 @ 4:30 PM PST: 11 left (buyer bought 1 from Lansdale, PA )
Quantity updated as of 1/30/2013 @ 4:07 PM PST:10 left (buyer bought 1 from adelaide, South Australia, Australia )
Quantity updated as of 1/30/2013 @ 1:46 PM PST: 9 left (buyer bought 1 from Pruszkow, Poland )
Quantity updated as of 2/27/2013 @ 4:30 PM PST: 8 left (buyer bought 1 from Fresno, CA )
Quantity updated as of 3/5/2013 @ 4:07 PM PST: 7 left (buyer bought 1 from Waterloo, Ontario, Canada )
Quantity updated as of 3/10/2013 @ 1:46 PM PST: 6 left (buyer bought 1 from Wien, Austria )
Quantity updated as of 3/21/2013 @ 4:30 PM PST: 5 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 3/26/2013 @ 4:07 PM PST: 4 left (buyer bought 1 from Carleton-sur-mer, Quebec, Canada )
Quantity updated as of 4/4/2013 @ 1:46 PM PST: 3 left (buyer bought 1 from Zwingenberg, Baden-Württemberg, Germany )
Quantity updated as of 4/18/2013 @ 4:07 PM PST: 2 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 4/20/2013 @ 1:46 PM PST: 1 left (buyer bought 1 from City Brest,Belarus )
Edited by Lyen on Tue Apr 23, 2013 5:47 pm.
Items For Sale
Lyen
Revision 8: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Quantity updated as of 9/11/2012 @ 1:46 PM PST: 24 left (buyer bought 1 from Henderson, NV )
Quantity updated as of 9/17/2012 @ 2:51 AM PST: 23 left (buyer bought 1 from Vilnius, Lithuania Republic )
Quantity updated as of 9/20/2012 @ 4:22 AM PST: 22 left (buyer bought 1 from Kyabram, victoria, Australia )
Quantity updated as of 9/21/2012 @ 5:17 PM PST: 21 left (buyer bought 1 from Spencer, MA )
Quantity updated as of 9/27/2012 @ 1:46 PM PST: 20 left (buyer bought 1 from San Francisco, CA )
Quantity updated as of 10/3/2012 @ 8:27 PM PST: 19 left (buyer bought 1 from Singapore)
Quantity updated as of 10/6/2012 @ 2:40 PM PST: 18 left (buyer bought 1 from Penzance, Cornwall, United Kingdom )
Quantity updated as of 10/9/2012 @ 2:00 PM PST: 17 left (buyer bought 1 from Chevy Chase, MD )
Quantity updated as of 11/7/2012 @ 1:15 PM PST: 16 left (buyer bought 1 from Singapore )
Quantity updated as of 12/7/2012 @ 3:27 PM PST: 15 left (buyer bought 1 from Labrador, Queensland, Australia )
Quantity updated as of 12/16/2012 @ 1:46 PM PST: 14 left (buyer bought 1 from Katy, TX )
Quantity updated as of 12/21/2012 @ 4:07 PM PST: 13 left (buyer bought 1 from Moscow, Russia )
Quantity updated as of 1/8/2013 @ 4:30 PM PST: 12 left (buyer bought 1 from Clarkdale, AZ)
Quantity updated as of 1/9/2013 @ 1:46 PM PST: 11 left (buyer bought 1 from Winnipeg, MB, Canada )
Quantity updated as of 1/13/2013 @ 4:30 PM PST: 10 left (buyer bought 1 from Lansdale, PA )
Quantity updated as of 1/30/2013 @ 4:07 PM PST:9 left (buyer bought 1 from adelaide, South Australia, Australia )
Quantity updated as of 1/30/2013 @ 1:46 PM PST: 8 left (buyer bought 1 from Pruszkow, Poland )
Quantity updated as of 2/27/2013 @ 4:30 PM PST: 7 left (buyer bought 1 from Fresno, CA )
Quantity updated as of 3/5/2013 @ 4:07 PM PST: 6 left (buyer bought 1 from Waterloo, Ontario, Canada )
Quantity updated as of 3/10/2013 @ 1:46 PM PST: 5 left (buyer bought 1 from Wien, Austria )
Quantity updated as of 3/21/2013 @ 4:30 PM PST: 4 left (buyer bought 1 from Richmond British, Columbia, Canada )
Quantity updated as of 3/26/2013 @ 4:07 PM PST: 3 left (buyer bought 1 from Carleton-sur-mer, Quebec, Canada )
Quantity updated as of 4/4/2013 @ 1:46 PM PST: 2 left (buyer bought 1 from Zwingenberg, Baden-Württemberg, Germany )
Edited by Lyen on Sat Apr 13, 2013 6:33 pm.
Items For Sale
Lyen
Revision 7: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Quantity updated as of 8/7/2012 @ 4:17 AM PST: 24 left (buyer bought 1 from Malissard, France )
Quantity updated as of 8/10/2012 @ 4:08 PM PST: 23 left (buyer bought 1 from City Brest, Belarus BY )
Quantity updated as of 9/11/2012 @ 1:46 PM PST: 22 left (buyer bought 1 from Henderson, NV )
Quantity updated as of 9/17/2012 @ 2:51 AM PST: 21 left (buyer bought 1 from Vilnius, Lithuania Republic )
Quantity updated as of 9/20/2012 @ 4:22 AM PST: 20 left (buyer bought 1 from Kyabram, victoria, Australia )
Quantity updated as of 9/21/2012 @ 5:17 PM PST: 19 left (buyer bought 1 from Spencer, MA )
Quantity updated as of 9/27/2012 @ 1:46 PM PST: 18 left (buyer bought 1 from San Francisco, CA )
Quantity updated as of 10/3/2012 @ 8:27 PM PST: 17 left (buyer bought 1 from Singapore)
Quantity updated as of 10/6/2012 @ 2:40 PM PST: 16 left (buyer bought 1 from Penzance, Cornwall, United Kingdom )
Quantity updated as of 10/9/2012 @ 2:00 PM PST: 15 left (buyer bought 1 from Chevy Chase, MD )
Quantity updated as of 11/7/2012 @ 1:15 PM PST: 14 left (buyer bought 1 from Singapore )
Quantity updated as of 12/7/2012 @ 3:27 PM PST: 13 left (buyer bought 1 from Labrador, Queensland, Australia )
Quantity updated as of 12/16/2012 @ 1:46 PM PST: 12 left (buyer bought 1 from Katy, TX )
Quantity updated as of 12/21/2012 @ 4:07 PM PST: 11 left (buyer bought 1 from Moscow, Russia )
Quantity updated as of 1/8/2013 @ 4:30 PM PST: 10 left (buyer bought 1 from Clarkdale, AZ)
Quantity updated as of 1/9/2013 @ 1:46 PM PST: 9 left (buyer bought 1 from Winnipeg, MB, Canada )
Quantity updated as of 1/13/2013 @ 4:30 PM PST: 8 left (buyer bought 1 from Lansdale, PA )
Quantity updated as of 1/30/2013 @ 4:07 PM PST: 7 left (buyer bought 1 from adelaide, South Australia, Australia )
Quantity updated as of 1/30/2013 @ 1:46 PM PST: 6 left (buyer bought 1 from Pruszkow, Poland )
Quantity updated as of 2/27/2013 @ 4:30 PM PST: 5 left (buyer bought 1 from Fresno, CA )
Quantity updated as of 3/5/2013 @ 4:07 PM PST: 4 left (buyer bought 1 from Waterloo, Ontario, Canada )
Quantity updated as of 3/10/2013 @ 1:46 PM PST: 3 left (buyer bought 1 from Wien, Austria )
Edited by Lyen on Thu Mar 21, 2013 2:01 pm.
Items For Sale
Lyen
Revision 6: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Quantity updated as of 6/26/2012 @ 3:23 PM PST: 24 left (buyer bought 1 from byron bay, New South Wales, Australia)
Quantity updated as of 7/11/2012 @ 12:40 PM PST: 22 left (buyer bought 2 from Waterloo, Ontario, Canada )
Quantity updated as of 7/17/2012 @ 12:07 AM PST: 21 left (buyer bought 1 from Ferndown, Dorset, United Kingdom)
Quantity updated as of 8/7/2012 @ 4:17 AM PST: 20 left (buyer bought 1 from Malissard, France )
Quantity updated as of 8/10/2012 @ 4:08 PM PST: 19 left (buyer bought 1 from City Brest, Belarus BY )
Quantity updated as of 9/11/2012 @ 1:46 PM PST: 18 left (buyer bought 1 from Henderson, NV )
Quantity updated as of 9/17/2012 @ 2:51 AM PST: 17 left (buyer bought 1 from Vilnius, Lithuania Republic )
Quantity updated as of 9/20/2012 @ 4:22 AM PST: 16 left (buyer bought 1 from Kyabram, victoria, Australia )
Quantity updated as of 9/21/2012 @ 5:17 PM PST: 15 left (buyer bought 1 from Spencer, MA )
Quantity updated as of 9/27/2012 @ 1:46 PM PST: 14 left (buyer bought 1 from San Francisco, CA )
Quantity updated as of 10/3/2012 @ 8:27 PM PST: 13 left (buyer bought 1 from Singapore)
Quantity updated as of 10/6/2012 @ 2:40 PM PST: 12 left (buyer bought 1 from Penzance, Cornwall, United Kingdom )
Quantity updated as of 10/9/2012 @ 2:00 PM PST: 11 left (buyer bought 1 from Chevy Chase, MD )
Quantity updated as of 11/7/2012 @ 1:15 PM PST: 10 left (buyer bought 1 from Singapore )
Quantity updated as of 12/7/2012 @ 3:27 PM PST: 9 left (buyer bought 1 from Labrador, Queensland, Australia )
Quantity updated as of 12/16/2012 @ 1:46 PM PST: 8 left (buyer bought 1 from Katy, TX )
Quantity updated as of 12/21/2012 @ 4:07 PM PST: 7 left (buyer bought 1 from Moscow, Russia )
Quantity updated as of 1/8/2013 @ 4:30 PM PST: 6 left (buyer bought 1 from Clarkdale, AZ)
Quantity updated as of 1/9/2013 @ 1:46 PM PST: 5 left (buyer bought 1 from Winnipeg, MB, Canada )
Quantity updated as of 1/13/2013 @ 4:30 PM PST: 4 left (buyer bought 1 from Lansdale, PA )
Quantity updated as of 1/30/2013 @ 4:07 PM PST: 3 left (buyer bought 1 from adelaide, South Australia, Australia )
Quantity updated as of 1/30/2013 @ 1:46 PM PST: 2 left (buyer bought 1 from Pruszkow, Poland )
Edited by Lyen on Tue Mar 05, 2013 7:59 pm.
Items For Sale
Lyen
Revision 5: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=S2SKKQ3F72HNW
Edited by Lyen on Sat Feb 02, 2013 7:00 pm.
Items For Sale
Lyen
Revision 4: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Quantity updated as of 5/27/2012 @ 6:50 PM PST: 24 left (buyer bought 1 from Winnipeg Manitoba ,Canada)
Quantity updated as of 6/03/2012 @ 11:35 PM PST: 23 left (buyer bought 1 from thousand oaks, CA)
Quantity updated as of 6/23/2012 @ 5:30 AM PST: 22 left (buyer bought 1 from Milwaukee, WI )
Quantity updated as of 6/26/2012 @ 3:23 PM PST: 21 left (buyer bought 1 from byron bay, New South Wales, Australia)
Quantity updated as of 7/11/2012 @ 12:40 PM PST: 19 left (buyer bought 2 from Waterloo, Ontario, Canada )
Quantity updated as of 7/17/2012 @ 12:07 AM PST: 18 left (buyer bought 1 from Ferndown, Dorset, United Kingdom)
Quantity updated as of 8/7/2012 @ 4:17 AM PST: 17 left (buyer bought 1 from Malissard, France )
Quantity updated as of 8/10/2012 @ 4:08 PM PST: 16 left (buyer bought 1 from City Brest, Belarus BY )
Quantity updated as of 9/11/2012 @ 1:46 PM PST: 15 left (buyer bought 1 from Henderson, NV )
Quantity updated as of 9/17/2012 @ 2:51 AM PST: 14 left (buyer bought 1 from Vilnius, Lithuania Republic )
Quantity updated as of 9/20/2012 @ 4:22 AM PST: 13 left (buyer bought 1 from Kyabram, victoria, Australia )
Quantity updated as of 9/21/2012 @ 5:17 PM PST: 12 left (buyer bought 1 from Spencer, MA )
Quantity updated as of 9/27/2012 @ 1:46 PM PST: 11 left (buyer bought 1 from San Francisco, CA )
Quantity updated as of 10/3/2012 @ 8:27 PM PST: 10 left (buyer bought 1 from Singapore)
Quantity updated as of 10/6/2012 @ 2:40 PM PST: 9 left (buyer bought 1 from Penzance, Cornwall, United Kingdom )
Quantity updated as of 10/9/2012 @ 2:00 PM PST: 8 left (buyer bought 1 from Chevy Chase, MD )
Quantity updated as of 11/7/2012 @ 1:15 PM PST: 7 left (buyer bought 1 from Singapore )
Quantity updated as of 12/7/2012 @ 3:27 PM PST: 6 left (buyer bought 1 from Labrador, Queensland, Australia )
Quantity updated as of 12/16/2012 @ 1:46 PM PST: 5 left (buyer bought 1 from Katy, TX )
Quantity updated as of 12/21/2012 @ 4:07 PM PST: 4 left (buyer bought 1 from Moscow, Russia )
Quantity updated as of 1/9/2013 @ 1:46 PM PST: 3 left (buyer bought 1 from Winnipeg, MB, Canada )
Quantity updated as of 1/13/2013 @ 4:30 PM PST: 2 left (buyer bought 1 from Lansdale, PA )
Edited by Lyen on Sat Jan 19, 2013 8:12 pm.
Items For Sale
Lyen
Revision 3: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
I have only 26 made since I am busy working on my other ebike projects. My intention for selling at such low price is to share the fun with other ES forum members instead of making them jealous. :wink: I finally understand why Methods mentioned the cost of labor is steep after all this and I have to agree with him from now on. These controllers are not generic controllers. I have every single one serialized. Quantity is limited, buy it as soon as your piggy bank is filled up. :lol:
Quantity updated as of 5/01/2012 @ 11:07 AM PST: 25 left (buyer bought 1 from Waterloo Ontario, Canada)
Quantity updated as of 5/21/2012 @ 12:46 PM PST: 24 left (buyer bought 1 from Kemptville Ontario ,Canada)
Quantity updated as of 5/27/2012 @ 6:50 PM PST: 23 left (buyer bought 1 from Winnipeg Manitoba ,Canada)
Quantity updated as of 6/03/2012 @ 11:35 PM PST: 22 left (buyer bought 1 from thousand oaks, CA)
Quantity updated as of 6/23/2012 @ 5:30 AM PST: 21 left (buyer bought 1 from Milwaukee, WI )
Quantity updated as of 6/26/2012 @ 3:23 PM PST: 20 left (buyer bought 1 from byron bay, New South Wales, Australia)
Quantity updated as of 7/11/2012 @ 12:40 PM PST: 18 left (buyer bought 2 from Waterloo, Ontario, Canada )
Quantity updated as of 7/17/2012 @ 12:07 AM PST: 17 left (buyer bought 1 from Ferndown, Dorset, United Kingdom)
Quantity updated as of 8/7/2012 @ 4:17 AM PST: 16 left (buyer bought 1 from Malissard, France )
Quantity updated as of 8/10/2012 @ 4:08 PM PST: 15 left (buyer bought 1 from City Brest, Belarus BY )
Quantity updated as of 9/11/2012 @ 1:46 PM PST: 14 left (buyer bought 1 from Henderson, NV )
Quantity updated as of 9/17/2012 @ 2:51 AM PST: 13 left (buyer bought 1 from Vilnius, Lithuania Republic )
Quantity updated as of 9/20/2012 @ 4:22 AM PST: 12 left (buyer bought 1 fromKyabram, victoria, Australia )
Quantity updated as of 9/21/2012 @ 5:17 PM PST: 11 left (buyer bought 1 from Spencer, MA )
Quantity updated as of 9/27/2012 @ 1:46 PM PST: 10 left (buyer bought 1 from San Francisco, CA )
Quantity updated as of 10/3/2012 @ 8:27 PM PST: 9 left (buyer bought 1 from Singapore)
Quantity updated as of 10/6/2012 @ 2:40 PM PST: 8 left (buyer bought 1 from Penzance, Cornwall, United Kingdom )
Quantity updated as of 10/9/2012 @ 2:00 PM PST: 7 left (buyer bought 1 from Chevy Chase, MD )
Quantity updated as of 11/7/2012 @ 1:15 PM PST: 6 left (buyer bought 1 from Singapore )
Quantity updated as of 12/7/2012 @ 3:27 PM PST: 5 left (buyer bought 1 from Labrador, Queensland, Australia )
Quantity updated as of 12/16/2012 @ 1:46 PM PST: 4 left (buyer bought 1 from Katy, TX )
Quantity updated as of 12/21/2012 @ 4:07 PM PST: 3 left (buyer bought 1 from Moscow, Russia )
Edited by Lyen on Thu Dec 27, 2012 5:43 pm.
Items For Sale
Lyen
Revision 2: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Quantity updated as of 3/29/2012 @ 2:04 AM PST: 25 left (buyer bought 1 from columbus, OH)
Quantity updated as of 3/30/2012 @ 5:29 AM PST: 24 left (buyer bought 1 from Ottawa ON ,Canada)
Quantity updated as of 5/01/2012 @ 7:23 AM PST: 23 left (buyer bought 1 from swadlincote, Derbyshire,United Kingdom)
Quantity updated as of 5/01/2012 @ 11:07 AM PST: 22 left (buyer bought 1 from Waterloo Ontario, Canada)
Quantity updated as of 5/21/2012 @ 12:46 PM PST: 21 left (buyer bought 1 from Kemptville Ontario ,Canada)
Quantity updated as of 5/27/2012 @ 6:50 PM PST: 20 left (buyer bought 1 from Winnipeg Manitoba ,Canada)
Quantity updated as of 6/03/2012 @ 11:35 PM PST: 19 left (buyer bought 1 from thousand oaks, CA)
Quantity updated as of 6/23/2012 @ 5:30 AM PST: 18 left (buyer bought 1 from Milwaukee, WI )
Quantity updated as of 6/26/2012 @ 3:23 PM PST: 17 left (buyer bought 1 from byron bay, New South Wales, Australia)
Quantity updated as of 7/11/2012 @ 12:40 PM PST: 16 left (buyer bought 2 from Waterloo, Ontario, Canada )
Quantity updated as of 7/17/2012 @ 12:07 AM PST: 14 left (buyer bought 1 from Ferndown, Dorset, United Kingdom)
Quantity updated as of 8/7/2012 @ 4:17 AM PST: 13 left (buyer bought 1 from Malissard, France )
Quantity updated as of 8/10/2012 @ 4:08 PM PST: 12 left (buyer bought 1 from City Brest, Belarus BY )
Quantity updated as of 9/11/2012 @ 1:46 PM PST: 11 left (buyer bought 1 from Henderson, NV )
Quantity updated as of 9/17/2012 @ 2:51 AM PST: 10 left (buyer bought 1 from Vilnius, Lithuania Republic )
Quantity updated as of 9/20/2012 @ 4:22 AM PST: 9 left (buyer bought 1 fromKyabram, victoria, Australia )
Quantity updated as of 9/21/2012 @ 8:27 PM PST: 8 left (buyer bought 1 from Spencer, MA )
Quantity updated as of 9/27/2012 @ 1:46 PM PST: 7 left (buyer bought 1 from San Francisco, CA )
Quantity updated as of 10/3/2012 @ 8:27 PM PST: 6 left (buyer bought 1 from Singapore)
Quantity updated as of 10/6/2012 @ 2:47 PM PST: 5 left (buyer bought 1 from Penzance, Cornwall, United Kingdom )
Quantity updated as of 10/9/2012 @ 2:47 PM PST: 4 left (buyer bought 1 from Chevy Chase, MD )
Quantity updated as of 11/7/2012 @ 1:15 PM PST: 3 left (buyer bought 1 from Singapore )
Edited by Lyen on Tue Nov 27, 2012 6:11 pm.
Items For Sale
Lyen
Revision 1: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Edited by Lyen on Thu Nov 01, 2012 12:26 pm.
Items For Sale
Lyen
Original post: 18 x 4115 MOSFET 84-132V Real Highway Speed Controller $259
Quantity updated as of 2/08/2012 @ 10:27 AM PST:25 left (buyer bought 1 from Yoshkar-Ola, Mari El ,Russia)
Quantity updated as of 3/09/2012 @ 4:59 PM PST: 24 left (buyer bought 1 from Katy, TX )
Quantity updated as of 3/29/2012 @ 2:04 AM PST: 23 left (buyer bought 1 from columbus, OH)
Quantity updated as of 3/30/2012 @ 5:29 AM PST: 22 left (buyer bought 1 from Ottawa ON ,Canada)
Quantity updated as of 5/01/2012 @ 7:23 AM PST: 21 left (buyer bought 1 from swadlincote, Derbyshire,United Kingdom)
Quantity updated as of 5/01/2012 @ 11:07 AM PST: 20 left (buyer bought 1 from Waterloo Ontario, Canada)
Quantity updated as of 5/21/2012 @ 12:46 PM PST: 19 left (buyer bought 1 from Kemptville Ontario ,Canada)
Quantity updated as of 5/27/2012 @ 6:50 PM PST: 18 left (buyer bought 1 from Winnipeg Manitoba ,Canada)
Quantity updated as of 6/03/2012 @ 11:35 PM PST: 17 left (buyer bought 1 from thousand oaks, CA)
Quantity updated as of 6/23/2012 @ 5:30 AM PST: 16 left (buyer bought 1 from Milwaukee, WI )
Quantity updated as of 6/26/2012 @ 3:23 PM PST: 15 left (buyer bought 1 from byron bay, New South Wales, Australia)
Quantity updated as of 7/11/2012 @ 12:40 PM PST: 13 left (buyer bought 2 from Waterloo, Ontario, Canada )
Quantity updated as of 7/17/2012 @ 12:07 AM PST: 12 left (buyer bought 1 from Ferndown, Dorset, United Kingdom)
Quantity updated as of 8/7/2012 @ 4:17 AM PST: 11 left (buyer bought 1 from Malissard, France )
Quantity updated as of 8/10/2012 @ 4:08 PM PST: 10 left (buyer bought 1 from City Brest, Belarus BY )
Quantity updated as of 9/17/2012 @ 2:51 AM PST: 9 left (buyer bought 1 from Vilnius, Lithuania Republic )
Quantity updated as of 9/20/2012 @ 4:22 AM PST: 8 left (buyer bought 1 fromKyabram, victoria, Australia )
Items For Sale
Lyen
Users browsing this forum: DanGT86, Google [Bot] and 3 guests
