Lyen
The safety claim of the LifePO4 is a liar when duck-taped and caused my pants on fire.
I had an incident while I was riding my ebike home from work earlier in the morning. While I was traveling at 31MPH for the last 6 miles, there was a car driver shouting at me telling me my ass was on fire. I immediately pull over to the sidewalk and put off the fire with my motorcycle glove. Fortunately, only one of my finger had a minor burn on the skin when trying to put off the fire. My underwear had also saved my butt. LOL
The ducktape 48v 20Ah LifePO4 battery inside the Sunlite rack bag becomes a fireball and very much burned everything inside the bag including the BMS, Topeak tool, charger, and the rack bag.
It took me five minutes to put off the fire with a piece of ceramic brick I picked of the ground.
It then start investigate and noticed a few of the cells in parallel of are down to 0.1v. The BMS could not detect it and continue to discharge. The out of balance cells heated up the ducktapes and started the fire.
I was not able to take pictures of the Sunlite rack bag since it is totally burned to ash.
So my conclusion to the safety claim of using the LifePO4 is a liar if it is being wrapped with ducktape.
Lastly, my advice to the people using any ducktape battery should check their cells periodically if possible to avoid having the incident like I did.
Regards,
Lyen
Regards,
Lyen
